| 38 MPH DRIFTING DYNAMARK Trail and Drift Mower | |
+8AllisKidD21 MightyRaze Kinky_Dee Double W Cross Ranch MatthewD CraftsmanQuad19 Crazy_Carl biggasmowers 12 posters | |
What kind of Engine should it get? | Diesel Dynamark | | 30% | [ 3 ] | 420 Clone Dynamark | | 20% | [ 2 ] | Boring stock mower with the Tecumseh 11HP | | 50% | [ 5 ] |
| Total Votes : 10 | | Poll closed |
| Author | Message |
2020 Build-Off Top 3 Winner
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower November 4th 2018, 11:07 pm | |
| like @prancstaman said, strip down everything on that scooter, you may even be able to use the tires as front tires if you could find wheels that will fit them and your hubs/axles, they would make good road tires and should easily handle the speeds you want to achieve, just about anything off that scooter may be usable | |
| | | Double W Cross Ranch Veteran Member
Age : 20 Join date : 2017-06-09 Points : 5494 Posts : 2640 Location : Literally Nowhere, Texas
| | | | The author of this message was banned from the forum - See the message | SebastianAlbrecht Veteran Member
Age : 23 Join date : 2018-02-27 Points : 3848 Posts : 1299
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower November 5th 2018, 10:49 pm | |
| - prancstaman wrote:
- I'd strip that scooter down and bag everything for inventory. See what you got before buying anything. Could probably use a couple other things off it too. Maybe even the wiring harness too, since you will be using the ignition key and gauges off it.
maybe, AFAIK the new Engine I want to use uses CDI Ignition, this POS too, but it doesn't really work on that POS here, that's why I gave up on it A new harness that would fit the Engine I waht to use is about 30$ with switches and stuff but it's for a motorcycle or ATV, so I would have to mod it. - darkside0914 wrote:
- like @prancstaman said, strip down everything on that scooter, you may even be able to use the tires as front tires if you could find wheels that will fit them and your hubs/axles, they would make good road tires and should easily handle the speeds you want to achieve, just about anything off that scooter may be usable
finding rims that will fit them would be really hard, since not much good stuff is available here, and if it is, it's really expensive - Double W Cross Ranch wrote:
- Is there no engine on that scooter? I'd say go for it.
it has a 50cc 2 stroke Engine. I could sell it for 105$ like it is now. Sell it or would that be stupid since the most parts I need are on it, and they're expensive? | |
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower January 1st 2019, 12:41 pm | |
| New Year, New Plans! This build will be paused for a longer Period of time since I'm so sick of work rn and too much other work to do! The Ressurection of this Build will also include engine and drivetrain changes! BUT THAT S*** WILL BE SECRET TIL THE RESURRECTION OF THIS POS BEGINS! | |
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower January 1st 2019, 9:15 pm | |
| - MightyRaze wrote:
- Glad you got some Ideas. I know the building funk and lots of life getting in the way.
Yes, some things happen, some stuff changes, the money part is a big problem,.... | |
| Who is online? | In total there are 13 users online :: 0 Registered, 0 Hidden and 13 Guests
