 [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]
George Gooding
RockeyDA
tinkering bob
SteamNut247
swampduck03
19 posters
Go to page : Previous  1 ... 9 ... 14, 15, 16, 17  Next
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Empty
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeSeptember 30th 2018, 11:14 am
SebastianAlbrecht wrote:
WOW, Hadn't expected that! Do it like he pre owner of my MUD MURRAY 4X4 did. Make a front weight from concrete! Heavy as [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 252588580  and small.
I might do that, we'll see.
MightyRaze wrote:
Use the lower hitch point when pulling.  It will help keep your tires on the ground maybe.
Yeah, that's the plan, but as I stated above, the chain hook won't fit in the bottom hole.
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeSeptember 30th 2018, 8:26 pm
maybe you can find you a shackle for it.
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Sig115PROJECTS:
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Sig214[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Sig314
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 1st 2018, 11:44 am
I plan to.
So I think the front belt is the wrong size, it keeps throwing the rear belt, and I don't have much tension on it, the tensioner is maxed out, and it won't turn the tires in 3rd or 4th gear.  The front belt is too small, I knew that, I only have one vari drive speed (which happens to be fastest), so I should get a 40 later, instead of a 42.
I also need to bypass the low oil cutoff, because whenever the engine is not level, it stalls out, even coasting downhill.  But when I unplug the wire going to ground, it doesn't do it anymore.
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 1st 2018, 6:54 pm
Sounds like you need to dial in your belt sizes.  Do you think you can get the vari drive working again with the right belt sizes?
I think you have to disconnect that box that is slightly above the oil sensor to bypass that.  You do have enough oil right? lol!
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 10th 2018, 2:23 pm
Yes I have enough oil lol.  Yeah, I did that, and now the switch doesn't work anymore either.  So until I rewire it directly from the coil-switch-ground I am pulling back on the governor arm to shut it off.  It'll be fine.
Got the right belt:
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 20181010
For my reference: 39".
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 20181012
Took her for a ride!
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 20181011
Went down my "mud trail", its literally 300 feet of nothing but mud, and it gets pretty bad in some parts.
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 20181013
When I came back later that puddle had about 3x that much water in it, and you are climbing a 45* hill halfway through it.  She went through it like a champ.  The vari drive now works great, and in 4th gear on the trans and 1st on the vari-drive at about 3/4 throttle (what I typically run the engine at), it goes 4 mph with lots of torque.  In 4th gear on the trans and 7th on the vari-drive at full throttle it will do a surprising 15 mph!!
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 43524410
I later got it up to 16, but forgot to screenshot it.  I think if I messed with the governor a bit I could get more, but steering it is very sketchy.  Toed out, quite a bit of play, and like 4.5 turns lock to lock.  You're like turning the wheel the entire time just to make small adjustments.  Going to try to tighten that up a bit.
Today I got that annoying crooked tow hitch off.
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 20181014
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 20181016
Surprisingly good welds for being so crooked.
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 20181015
Cleaned that up a bit.
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 20181017
After paint:
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 20181018
Going to cover up those ugly plasma cutter/torch holes up with this contemporary 1975 motorcycle license plate I found in a pasture....  scratch
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 20181019
Can't decide if I should leave the patina, or paint it to match the rest of the build.
The rust on the seat pan was bothering me, so I painted it black again.
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 20181020
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 20181021
Going to repaint the seat springs soon, but I decided to save that for another day.
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 20181022
The seat is neat on this, you can slide it forward or backward about 6" just by pulling on a spring-loaded pin and sliding it the desired direction, then let go of the pin and it locks into place.  Not necessary but convenient.
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 11th 2018, 10:06 am
your john deere makes me miss my cast iron tank. you got a mud hole to hit up?
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 13th 2018, 12:01 pm
I like the old license plate patch.
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 21st 2018, 9:08 pm
Well, this rig is almost done. Couple of kinks and then I'll start filming for the build off vid.
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 22nd 2018, 4:14 am
i can here shaggy and scooby freaking out already. they were picking out of season berries when you went by.
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 25th 2018, 10:28 am
Ha.
Was out driving it yesterday having a grand old time, things were going great, then the engine started sputtering real wierd.  About 200 feet later I started going up a bit of a hill and the engine stalled and wouldn't start again till I put the choke on.  Then it would start and run great until I turned the choke off.  So I drove it home half choked.  It only sat for 4 days, and there is a fuel filter on it.  I'm going to drop the bowl later and see what's up.
Need to start filming for the build off video too.  All this rain is kinda putting a wrench in my gears of progress.
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 25th 2018, 11:38 am
Okay, so I dropped the bowl, it was dirty, so I cleaned it up, reinstalled it, and took it for a ride.  Got 20 feet and the thing died like I hit the kill switch.  It has no spark and I can't figure out why not.
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 25th 2018, 12:56 pm
did you try swapping the spark plug? maby somthing is arching out in there.
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 25th 2018, 12:59 pm
Ain't got a replacement.  I will buy one later but rn I can't get off my property in a car because of all the mud.
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 25th 2018, 1:02 pm
huh, i proboboly got 20-30 spark plugs arround i cold test swap with. about more then 10 are loose plugs just sitting around.
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 25th 2018, 1:03 pm
Well I don't have any that will thread into the head, otherwise I'd steal one off the mower.
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 25th 2018, 1:05 pm
it dont take a normal small 4 stroke spark plug?
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 25th 2018, 1:06 pm
I don't think so, it looks thinner than my other ones.
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 25th 2018, 1:18 pm
Stupid question will it spark with the kill wire off the coil?
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 25th 2018, 1:31 pm
actually, will the high voltage cable arch to the frame if you disconnect it from the plug entirely?
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 25th 2018, 6:00 pm
No and no
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 25th 2018, 6:12 pm
Hmm, something to do with the wiring for the low oil switch?
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 25th 2018, 7:36 pm
a quick test for that wold be is unplug that master kill wire to your magneto and see if you get spark then, if no, you might be having magneto trouble.
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 26th 2018, 12:00 pm
That was what I was leaning towards, if kill wire is off and you are not getting spark it is either the magneto or plug. I don't know anything about that engine but that's what I think. Also just put any plug from any other tractor on it if you are testing & hold against the block. (don't light your leg on fire like I did.)
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 26th 2018, 8:23 pm
Well I didn't change a thing but now it runs. Ok....
Wondering if the magnets were hot or something, carsandcameras had that issue with their 670
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 15 Icon_minitimeOctober 26th 2018, 9:05 pm
Coil could be overheating?
Page 15 of 17Go to page : Previous  1 ... 9 ... 14, 15, 16, 17  Next
» Rays customs. Build name Oh Deere [2018 Build-Off Entry]
» [Complete] Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]
» [Complete] Redzz02's Haspin Build [2018 Build-Off Entry]
» [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]
» [Complete] Highboy77's DIESEL CRAFTSMAN! [2018 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2018 Archive :: Finalist Archive-
