| MrShaft696 Tractor buying Sellin Mowing....Projects | |
+13diddie Murraymountain prancstaman Crazy_Carl mrshaft696 RichieRichOverdrive MightyRaze biggasmowers CraftsmanQuad19 MatthewD Buck AllisKidD21 Double W Cross Ranch 17 posters |
Crazy_Carl Veteran Member
![MrShaft696 Tractor buying Sellin Mowing....Projects - Page 7 Empty](https://2img.net/i/empty.gif) | |
mrshaft696 Established Member
![mrshaft696](https://2img.net/u/2812/37/66/46/avatars/2642-63.jpg)
Join date : 2016-07-10 Points : 3985 Posts : 870 Location : Phillydelphia
![MrShaft696 Tractor buying Sellin Mowing....Projects - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects July 7th 2018, 8:14 pm | |
| - Crazy_Carl wrote:
- Great I like to hear success.
Ha me too, now I have two more with bad head gaskets, but its running good..... Anyway got some big mowing done today...ground is really hard now and the horse footprints make for some brutal/bouncy mowing in the fields but hey what can you do... 1956 International D300 Utility... ![MrShaft696 Tractor buying Sellin Mowing....Projects - Page 7 Img_0312](https://i.servimg.com/u/f48/19/84/00/07/img_0312.jpg) ![MrShaft696 Tractor buying Sellin Mowing....Projects - Page 7 Img_0313](https://i.servimg.com/u/f48/19/84/00/07/img_0313.jpg) | |
![CraftsmanQuad19](https://2img.net/u/2812/37/66/46/avatars/2588-88.jpg)
![MrShaft696 Tractor buying Sellin Mowing....Projects - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects July 15th 2018, 9:05 pm | |
| - Crazy_Carl wrote:
- worth saving or parts machines?
there is a gibson that is old and ruff....runs! a simplicity rear engine with a bagger and 8hp unknown running condition... simplicity 12RTH ran on carb spray... Craftsman LT Grey 38" deck runs ok needs carb cleaned... | |
![MrShaft696 Tractor buying Sellin Mowing....Projects - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects July 15th 2018, 9:45 pm | |
I think it's a Gilson actually, haha. Looks pretty cool though! What does it have for a transaxle? ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![MrShaft696 Tractor buying Sellin Mowing....Projects - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects July 16th 2018, 7:45 am | |
| - AllisKidD21 wrote:
I think it's a Gilson actually, haha. Looks pretty cool though! What does it have for a transaxle? . Yes giLson, I see & read what I want sometimes. It has a "H" shift pattern, 3 forward speeds and reverse. I does have a piece of plywood mounted under the seat for some reason... its a little rough but all there for the most part. The rear of the tractor flips up too. | |
MatthewD Veteran Member
![MrShaft696 Tractor buying Sellin Mowing....Projects - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects July 16th 2018, 12:40 pm | |
| That Gilson looks cool, nice 8hp Briggs as well. The trans could be a 3spd Foote H shift trans, and a chain drive to the rear axle. Mowers with smaller engines like an 8hp sometimes have those chain driven type trans. | |
![MrShaft696 Tractor buying Sellin Mowing....Projects - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects July 17th 2018, 7:15 am | |
| - Crazy_Carl wrote:
- yep that be a 600 under there
Only thing that sucks about it for me is that it is really slow, on my property I like a tractor that can crawl thru the woods and go pretty quick thru the fields. 3 speeds kind of limits it.... | |
![MrShaft696 Tractor buying Sellin Mowing....Projects - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects July 19th 2018, 8:06 am | |
| I have the worst luck working on Tecumseh engines.... I spent 2 nights cleaning and checking this carb, trying to start the thing over and over, and no matter what it will still only run on carb spray for a few seconds. It sounds good when its running but I want to throw it in the river... I have another Tecumseh same 12hp ohv that does the same, what gives? Never have these issues with briggs engines. I know I have gas in the bowl, because when I disconnect the fuel line & drop the bowl gas comes out. I do know now that the float is working...I tried a different gas tank and fuel line to be sure. Could the jet still be clogged possibly not drawing fuel into the intake? ![MrShaft696 Tractor buying Sellin Mowing....Projects - Page 7 Img_0415](https://i.servimg.com/u/f48/19/84/00/07/img_0415.jpg) ![MrShaft696 Tractor buying Sellin Mowing....Projects - Page 7 Img_0416](https://i.servimg.com/u/f48/19/84/00/07/img_0416.jpg) | |
![MrShaft696 Tractor buying Sellin Mowing....Projects - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects July 23rd 2018, 9:07 pm | |
| - Crazy_Carl wrote:
- I'm starting to think this is getting out of hand.
Are you starting a mower junkyard? Flipping these? Or just straight up hoarding? hahah all of the above... just trying to stock up before winter I guess... I want to start spending more time on my build off tractor at the end of the summer, since now is prime cutting season. I have a couple for sale now, but it does make it allot easier to fix stuff when you have allot more parts on hand....I do advertise on CL for tractor removal and get allot of these for free or almost nothing... I have not paid more than 20-50 dollars for a single tractor since I can remember.... The snowblower was 20 bucks and I did get it to run, the red one seems promising.... | |
