| atv hub on lawn mower rear axle | |
+10Crazymudder gearheadmike canadianromper Bigal biscuit dangeroustoys56 redneckcarrow killer4051 Jamus Dustin138 14 posters |
Dustin138 Member
Age : 27 Join date : 2011-06-15 Points : 4899 Posts : 40 Location : Upstate NY
Jamus Established Member
Age : 44 Join date : 2010-06-28 Points : 5730 Posts : 511 Location : Southern WV
| Subject: Re: atv hub on lawn mower rear axle July 17th 2011, 10:20 pm | |
| I wouldn't weld them on, but I did on mine, if that makes sense. I did it because I was lazy, and would probably do it again, but there's better ways of doing the same thing. | |
killer4051 New Member
| Subject: Re: atv hub on lawn mower rear axle July 24th 2011, 12:47 pm | |
| dont weld them i did that once and it did not work good. cuz when i killed the tractor i had to get rid of the tires cuz they wont come off. i would cut the center of the stock rim and drill holes and bolt them to that so u can take them off if u need to. | |
Dustin138 Member
| Subject: Re: atv hub on lawn mower rear axle July 25th 2011, 6:29 pm | |
| I am not welding the wheels/tires just the a 4 bolt hub. I saw Arild uses c-clips and other parts like standard lawn mower tires. | |
redneckcarrow Member
Age : 54 Join date : 2010-12-22 Points : 5048 Posts : 30 Location : maine
| Subject: Re: atv hub on lawn mower rear axle July 25th 2011, 7:30 pm | |
| will the atv hubs fit over the center part of the lawnmower wheel (the part that slides on the axle) if it does weld the atv hub on the it then slide on axle just like lawnmower tire then bolt on atv wheel
thought about doing this to mine if i ever get a chance to build one | |
Age : 53 Join date : 2010-02-10 Points : 7000 Posts : 1726 Location : Florida, USA
| Subject: Re: atv hub on lawn mower rear axle July 30th 2011, 7:37 am | |
| I mounted a set of hubs on my 70 toro that came off a tractor with bolt on wheels - i wanted the bigger tires for better traction- it had the keyway and also the axles were drilled for a cotter key- so i drilled a hole in the hub, used a couple grade 8 bolts and bolted the hubs on ( thru the hub and axle- i kept a few extra bolts when i was in the rough stuff in case they broke on me tho. I planned on returning the tractor to stock someday and welding the hubs on the axles wasnt an option. Heres a pic of it: The rear wheels on it are the bolted on hubs- the front wheels were actually the original rear wheels... | |
biscuit Member
Age : 57 Join date : 2010-11-29 Points : 5090 Posts : 41 Location : Lincoln, RI
| Subject: Re: atv hub on lawn mower rear axle November 24th 2011, 5:11 pm | |
| Im not a.big fan of using.the c clips if you are going to. Be doing faster speeds. They will wear out quicker and you will lose a Wheel when you least expect it. Happened to me. Kinda wakes you up. I cut the heads off bolts and welded the threaded part to the end of the spindles and rear axle. Then put large washers and double nylock nuts. | |
Bigal Member
Join date : 2012-02-04 Points : 4670 Posts : 56 Location : ME
canadianromper Member
Age : 25 Join date : 2011-11-30 Points : 4784 Posts : 114 Location : ontario canada
| Subject: Re: atv hub on lawn mower rear axle February 7th 2012, 7:03 pm | |
| i would get a hub and weld it on and then you can just bolt on the rim. look at arild365 and fearlessfront they have good videos and all of the guys on here have good ideas aswell. | |
gearheadmike Member
Age : 34 Join date : 2011-11-18 Points : 5130 Posts : 392 Location : west chazy ny
| Subject: Re: atv hub on lawn mower rear axle February 8th 2012, 9:03 am | |
| if you got key way axels then do what i did this only works for steel hubs tho. i took the atv hub on the back of it i welded on another hub. You can get them at TSC there for the weld in pulleys. example my axle was 3/4 i got a 3/4 hub with a key way weled it to atv hub slide it on then set the set screw . i then put a washer and the c clip on. just make sure its welded on stright lol | |
Crazymudder Member
Age : 111 Join date : 2011-03-30 Points : 4946 Posts : 31 Location : United States
trout New Member
| Subject: Re: atv hub on lawn mower rear axle February 11th 2012, 11:35 pm | |
| A broach cutter will make most applications possible easy to use too on wheels pulleys shafts whatever needs keyed I would recommend a higher quality kit . | |
RanchKing New Member
Join date : 2012-01-14 Points : 4635 Posts : 12 Location : Dayton, Ohio
CityRedneck Member
Age : 28 Join date : 2011-08-13 Points : 5068 Posts : 241 Location : Winter Park
| Subject: Re: atv hub on lawn mower rear axle February 27th 2012, 7:45 pm | |
| hey guys im having the same ponder but im putting heavy tires on. like maybe MudLites or some 25" Outlaws but i read up on some hubs and they break really easy. i dont have alot of money to blow around experimenting so i need to know what wont snap or break under the pressure of 25"outlaws in thick mud? | |
Bigal Member
| Subject: Re: atv hub on lawn mower rear axle February 27th 2012, 8:39 pm | |
| Hey that web site that you posted was very good planing to get somefrom there what a very good web site thanks very helpful | |
Crazymudder Member
FOSWMT Member
| Subject: Re: atv hub on lawn mower rear axle July 28th 2013, 7:30 am | |
| I have been reading this with interest We have a Westwood W11 which I have just purchased some hubs for having spent 4.5 hours with a puller pulling of one of the wheels to get at the brake. I am not aware of the PCD of these as get but am hoping they are the same PCD as ATV wheels I know I can cross drill them but am wondering if any one has the PCD of 20" wheels please? | |
