| Talk About Anything Thread V3 | |
+14muckmudd Double W Cross Ranch CraftsmanQuad19 itsBella Doug darkside0914 muddstir TheBeal prancstaman Osco MatthewD RichieRichOverdrive biggasmowers AllisKidD21 18 posters |
Crazy_Carl Veteran Member
Age : 20 Join date : 2017-06-09 Points : 5489 Posts : 2640 Location : Literally Nowhere, Texas
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4927 Posts : 1944 Location : Kansas
| Subject: Re: Talk About Anything Thread V3 April 14th 2018, 2:13 pm | |
| Well it's been interesting lol. Might go pick up the trannys today, am getting the 820, a 930, and hopefully a few more various ones and in exchange I am going to pulley swap one of his mowers and make it go about 25 ish mph as a trade. | |
| Subject: Re: Talk About Anything Thread V3 April 14th 2018, 5:27 pm | |
| You know, that stream was fun last night. We could all collab one night via Google Hangouts and live stream on YT all at the same time. | |
| Subject: Re: Talk About Anything Thread V3 April 14th 2018, 6:25 pm | |
| - CraftsmanQuad19 wrote:
- That’s an awesome trade man!
Yeah i think its pretty good. Its snowing here....... 87 degrees yesterday and high of 40 today Found out my broken puller was hardened steel , it doesnt weld.... i might make my own puller out of 3/4" steel plate and a 1/2" bolt in the center cause i only have drill bits up to that size. | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5093 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: Talk About Anything Thread V3 April 15th 2018, 10:56 pm | |
| Huh cool. Man I am loving this 820 life. Guess what I paid for em!! The 930 was cracked from probably freezing with water In it so he threw in the 2300 (The model is 2345 lol!!!) Not sure if I should put the 2300 in the quag mower or the 820 after I take it apart and clean it up and possible doc locker. Whatta yall think? | |
| Subject: Re: Talk About Anything Thread V3 April 16th 2018, 12:34 am | |
| Really it wpuld be cool to put the 2300 in the Murray and say goodbye to broke Trannys. Wouldn't be too bad to stuff in but I will need to use a ragb to connect it . I have some 5 bolt tires that the rims should work . .. great, another project.
Oh and if I fix 3 engines I will get a craftsman 2 with another 820 in it. It's a 6 speed with a 20 hp oppy but the engine isn't all together. I was like sign me up! The side was super cool and had a bunch of awesome mowers and old ford trucks . Nice to have found a mower friend nearby finally. | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5750 Posts : 1993 Location : Northern Ireland
| Subject: Re: Talk About Anything Thread V3 April 16th 2018, 8:07 pm | |
| Nice 820! How many is that now haha? I think you could run a twisted belt setup if you wanted to use the 2300 on the Murray - I think @Mightraze did that on his Sasquatch. | |
Age : 49 Join date : 2016-09-06 Points : 15660 Posts : 10979 Location : Oklahoma
| Subject: Re: Talk About Anything Thread V3 April 16th 2018, 11:10 pm | |
| Man what a day.... lots of personal stuff that I'd rather not get into. On the other hand, today is my day off so I had planned on mowing the yard as it has needed it all week and today was going to be a nice day. Got half way through mowing and I hear an odd noise and my mower deck was slowing down. I disengage it. I try to reengage and it will not start up.
I looked under the mower and my engagement pulley had worn in half. Then that ate up my belt. Quick run to TSC resolved that issue and I am mowing again! Before I went to the TSC I did finish with the LT4000 AWS craftsman. Ran good although I have not spring serviced it yet. I will do that soon. Red, Blue, and Kal are the only ones that I have changed oil in at this point. I need to change the AWS and my suburban for the season too. Suburban needs a valve adjustment. | |
| Subject: Re: Talk About Anything Thread V3 April 17th 2018, 12:20 am | |
| That’s the thing with a ton of machines. At any given time at least one is running, but a couple will always need maintenance | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-07 Points : 5714 Posts : 1402 Location : Central PA
| Subject: Re: Talk About Anything Thread V3 April 17th 2018, 7:32 pm | |
| Ive mentioned this trailer Im putting fenders on, well heres a picture of the fenderless unit. Grinding down old weld sucks! | |
