| Biggasmower's "Lawn Gone lawn boy" [2018 Build-Off Entry | |
+8MatthewD RichieRichOverdrive AllisKidD21 Double W Cross Ranch CraftsmanQuad19 Crazy_Carl MightyRaze biggasmowers 12 posters |
Crazy_Carl Veteran Member
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4926 Posts : 1944 Location : Kansas
Age : 20 Join date : 2017-06-09 Points : 5488 Posts : 2640 Location : Literally Nowhere, Texas
Age : 35 Join date : 2017-10-30 Points : 5329 Posts : 2561 Location : Rochester, New York
| Subject: Re: Biggasmower's "Lawn Gone lawn boy" [2018 Build-Off Entry April 13th 2018, 8:30 am | |
| It already had a vent tube butbi didn't have the vent line on the fitting. I put 5w 30 motor oil in it because I thought I was put of gear oil then after that I found my gear oil. Lol . So I will probably suck out the old stuff and put in the right oil. It's 75w 90 gear oil. The engine oil should have helped clean it up on the gears too.i did clean out the case and wipe off the gears bit it still wasn't perfect.
Yeah double I have life insurance to cover my funeral costs. Don't need much else lol. My first high speed test run will be along the tree row where there's grass and it's pretty smooth in case of failure and it doesn't have wash board like tgecgravel road. The belt is loose but it still drives without a clutch but there is belt slippage when turning and when I rev it up wuick. | |
| Subject: Re: Biggasmower's "Lawn Gone lawn boy" [2018 Build-Off Entry April 13th 2018, 11:18 am | |
| Yup . You too!
I almost got a seat on it, but drill battery died. And the belt is finally stretching out a bit but it still kinda drives in 1rt gear , hopefully wears enough to stop that so I don't need to buy another belt | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5749 Posts : 1993 Location : Northern Ireland
| Subject: Re: Biggasmower's "Lawn Gone lawn boy" [2018 Build-Off Entry April 13th 2018, 1:39 pm | |
| Well lol.made a clutch, put on the seat, and took her out .....
Pretty scary, the clutch works but I do need a 1 inch longer belt cause it's still not setting still in gear with the clutch alot eh way in . I o my went up through forth but man , it gets going. I'd say 60 mph is very achievable because this engine handles the rpms very well and in 3rd gear I think it's around 38 mph in the high rpm range. The oil is still flinging everywhere, might need to put some grease in it to thicken it up or something. There aren't any seals on the outputs anyway | |
| Subject: Re: Biggasmower's "Lawn Gone lawn boy" [2018 Build-Off Entry April 18th 2018, 2:21 pm | |
| Got a 47 inch belt instead of the 46 inch that was on it. Now I need to make a new double pulley clutch but at least it will clutch now lol. Got it at tsc for$ 6:99 . Also was looking through the clearance bin and found a 5 pack of dewalt cutting discs marked down to 5.29 then when they rang it up it was 2.29!! That was a good deal lol they are the ones that have the arbor raised to extend the cutting sheep out for deeper cuts. | |
Age : 25 Join date : 2016-07-10 Points : 8583 Posts : 5190 Location : Ontario Canada
| Subject: Re: Biggasmower's "Lawn Gone lawn boy" [2018 Build-Off Entry April 19th 2018, 9:25 am | |
| That's probably the better option really. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Biggasmower's "Lawn Gone lawn boy" [2018 Build-Off Entry April 19th 2018, 11:32 am | |
| bearings? like the ones for the inputshafts ? i guess the diameter is similar , i will dig through my parts pile and see what ive got. i mean i have literally tubs of tranny parts from all the trannys i have broken or gotten when they were broken. | |
Age : 34 Join date : 2013-11-02 Points : 7165 Posts : 2910 Location : New Jersey USA
| Subject: Re: Biggasmower's "Lawn Gone lawn boy" [2018 Build-Off Entry April 19th 2018, 4:31 pm | |
| I didn't read every post but for your belt dragging issue, a guide or guard fairly close around the engine pulley may help to stop it. Sometimes they pull themselves tight if they don't have a guard around them, which keeps it dragging. Looks cool though. Nifty exhaust. | |
