| Craftsman GT 6000 Build | |
+15mowerjunkie03 Creepycrawler ConfederaSears mrshaft696 Double W Cross Ranch prancstaman RichieRichOverdrive biggasmowers Crazy_Carl mr.modified CraftsmanQuad19 MightyRaze TheBeal MatthewD AllisKidD21 19 posters |
| Subject: Re: Craftsman GT 6000 Build March 20th 2018, 11:35 am | |
| I forget, is it only 3 hi or both hi and lo?
Also, I wonder if there is another snap ring loose in there.
EDIT: Or maybe a little rust keeping the ball from falling into the detent on the shift fork?
Last edited by MightyRaze on March 20th 2018, 11:54 am; edited 2 times in total | |
Age : 25 Join date : 2016-07-10 Points : 8586 Posts : 5190 Location : Ontario Canada
| Subject: Re: Craftsman GT 6000 Build March 20th 2018, 11:37 am | |
| Oh, yeah I forgot to mention it does it in both hi an low range. Haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5332 Posts : 2561 Location : Rochester, New York
| Subject: Re: Craftsman GT 6000 Build March 20th 2018, 11:50 am | |
| That's what I figured. The hi/lo in this tractor and Ol Red is kinda like having a two speed rear end that doubles the amount of gears you have. 3rd gear functions the same whether you're in hi or lo. | |
| Subject: Re: Craftsman GT 6000 Build March 20th 2018, 11:59 am | |
| I could check the detent ball, but that doesnt explain why it makes that sound when I hold it in gear. When I put it in third it doesn't move as much as it does when I put it in second. Is that normal? Or should the amount of throw be equal for both gears? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman GT 6000 Build March 20th 2018, 12:42 pm | |
| That is normal for a Wheel Horse. The amount of "throw" for third gear is almost half as much as it is for any of my other gears. I do know enough about these 633s and their variants.
I'm thinking your shift fork might be bent or in the wrong spot because while you're holding it in gear you hear a grinding as if the transmission is trying to shift into two gears at once.
Last edited by Crazy_Carl on March 20th 2018, 12:59 pm; edited 1 time in total | |
Age : 49 Join date : 2016-09-06 Points : 15668 Posts : 10983 Location : Oklahoma
| Subject: Re: Craftsman GT 6000 Build March 20th 2018, 12:51 pm | |
| No, they should be pretty different. Sounds like you may be grinding another gear? | |
| Subject: Re: Craftsman GT 6000 Build March 20th 2018, 12:54 pm | |
| I'm thinking it is a shifter fork issue because it will drive if I hold it in gear, it just won't stay in by itself. But it does make that noise when I hold it in gear..... "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Buck Member
Join date : 2017-11-01 Points : 2881 Posts : 282 Location : Eastern Ontario
| Subject: Re: Craftsman GT 6000 Build March 20th 2018, 7:05 pm | |
| Thanks for taking the time to make that video mighty! It should help, I don't think I have the correct amount of movement into 3rd gear. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman GT 6000 Build April 2nd 2018, 11:18 pm | |
| So I went parts robbing again today... Got three wheels from this old trailer, two with the hubs and bearings. Figured they might look okay on the GT and the tapered roller bearings will be a nice upgrade as well. Gonna get the leaves off of that trailer someday too, hehe. Not positive on the look, but I do kinda like it. They're on 12" rims so worst case scenario I could put some ATV tires on instead of the trailer tires, but they should be okay for now. What do you fellas think? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman GT 6000 Build April 3rd 2018, 7:22 am | |
| They kinda have a cool old school tractor look to them. That just might fit the purpose of this tractor. Some wider atv tires would be cool too but those rims are pretty narrow, but there's wider 8" rims out there that should fit those hubs. | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5752 Posts : 1993 Location : Northern Ireland
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4929 Posts : 1944 Location : Kansas
| Subject: Re: Craftsman GT 6000 Build April 3rd 2018, 11:18 am | |
| They look cool, but one question. Would they sink in the field? Then again, they would be less resistance and cut through muck? Definitely more rugged maybe than the turfs. | |
| Subject: Re: Craftsman GT 6000 Build April 3rd 2018, 12:50 pm | |
| - Crazy_Carl wrote:
- They kinda have a cool old school tractor look to them. That just might fit the purpose of this tractor. Some wider atv tires would be cool too but those rims are pretty narrow, but there's wider 8" rims out there that should fit those hubs.
Yeah I kinda thought it looked like and old school tractor a bit, haha. The trailer tires don't look too bad, but like you said I could always find different rims to fit on the hubs. - MatthewD wrote:
- Those front wheels looks pretty good! I think they suit the GT a lot.
Thanks Matt! I suppose thwy do kinda suit it, haha. - MightyRaze wrote:
- They look cool, but one question. Would they sink in the field? Then again, they would be less resistance and cut through muck? Definitely more rugged maybe than the turfs.
I'm not too sure, they should cut through muck better but they might sink a bit too. We'll have to see, haha. They should help it crawl over bigger objects though and once I get some better tires for the rear it should perform much nicer. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| - biggasmowers wrote:
- Huh. Interesting look.
In a good or a bad way? Hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 24 Join date : 2016-04-12 Points : 5980 Posts : 2645 Location : Indiana
| Subject: Re: Craftsman GT 6000 Build April 3rd 2018, 1:58 pm | |
| Yeah go with a real tractor look!!! Ribbed tires and some monstrous aggs wpuld really make this thing look neat. Then a antique tractor paint job with a external air filter box and muffler sticking out the side. | |
| Subject: Re: Craftsman GT 6000 Build April 3rd 2018, 2:01 pm | |
| Ags on the back would look cool for sure. Executioners would look even better though, hahaha. If I could get some nice 25x10-12 Ag tires for the back I would probably put them on this thing. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman GT 6000 Build April 3rd 2018, 2:36 pm | |
| Yeah for sure, haha. Better than the turfs. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman GT 6000 Build April 3rd 2018, 4:25 pm | |
| Tri-ribs would look cool, but I kinda like the saw tooth tread pattern on these trailer tires. Haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
