| 5hp Briggs flathead build | |
TheGreenHornet Member
Age : 23 Join date : 2016-04-16 Points : 3413 Posts : 227 Location : Indiana
| Subject: 5hp Briggs flathead build August 8th 2017, 2:11 pm | |
| Okay everyone so i was given a 5hp briggs flathead by my uncle. it had a broken crank, so its been sitting on a shelf for the past 6 years or so. Recently, while i was working in the shop at school, i came across an identical engine. so i stole the crank from it, pulled mine off the shelf, and slammed the new crank into the engine. bolted everything up, and without the cover on, turned it over a few times to make sure everything was going to be alright. it turned over easily, good compression, goes through all the strokes without hitting anything. so i put the crank cover back on. All of a sudden it is very stiff to turn over. if i loosen the top bolts on the cover, it turns freely. Anybody have any idea what is causing this? BTW the reason it needed a new crank is because it used to be a pump motor, with no hole drilled in the crank, and someone drilled a hole and put it on a gokart, but their hole was off center and it snapped the crank off. Any help is appreciated, as i would like to build this engine and put it on my gokart. | |
| | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8581 Posts : 5190 Location : Ontario Canada
| Subject: Re: 5hp Briggs flathead build August 8th 2017, 3:14 pm | |
| Were there shims between the crank and the crankcase cover? Maybe there's one too many on there now. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: 5hp Briggs flathead build August 8th 2017, 4:14 pm | |
| no, i dont believe so. it is starting to loosen up just a little bit, since i let it sit these past few hours. i guess maybe the new crank has to get broken into the engine? i guess i should probably keep an eye on the oil for the first hours of running it | |
| Who is online? | In total there are 19 users online :: 0 Registered, 0 Hidden and 19 Guests
