| Honda GX160 woes | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5730 Posts : 1993 Location : Northern Ireland
| Subject: Honda GX160 woes February 16th 2017, 2:53 pm | |
| Hi, I have a Honda GX160 on a gokart. I'm experiencing a problem, I think it is an air leak. The engine runs on the choke, but once you let the choke off, it sometimes idles slow and sometime high, it doesn't rev up very well and stalls very easily. I've put rtv on the plastic carb insulator and the gaskets which seems to have improved it a little bit but not much. It has a brand new carb as well. I'm thinking it might be a cracked head but before I take it all apart, is there any other causes of this? | |
| | | TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5694 Posts : 1402 Location : Central PA
| Subject: Re: Honda GX160 woes February 16th 2017, 6:03 pm | |
| I don't think there is one on those carbs. I'll go check now
Edit: There seems to be one. There is an idle screw and beside it there is a slotted brass screw. I'll try adjusting that tomorrow | |
| Subject: Re: Honda GX160 woes February 17th 2017, 7:58 pm | |
| Nope it's not the fuel/air mixture. I'm thinking either a leaking valve or a cracked head. | |
Age : 24 Join date : 2016-04-12 Points : 5954 Posts : 2641 Location : Indiana
| Subject: Re: Honda GX160 woes February 17th 2017, 9:39 pm | |
| Check your valve lash. The rocker arms should be just slightly loose | |
| Subject: Re: Honda GX160 woes February 17th 2017, 9:42 pm | |
| Good idea. It does make quite a bit of valve clatter when it runs so the valves could be too loose. | |
| Subject: Re: Honda GX160 woes May 16th 2017, 5:56 pm | |
| Problem solved. It was a combination of a cheap carburettor and a cracked insulator gasket.
I have another problem with another honda, this time a 5.5 clone on a go kart. It is really sluggish off the line and stalls if you rev it too quickly. It's also really hard to start from warm. I've replaced all the carb gaskets which didn't really help. I'm going to try a carb I know works to see if that's the problem. | |
| Who is online? | In total there are 4 users online :: 0 Registered, 0 Hidden and 4 Guests
