| | 97ish cub cadet | |
SmallBlockKohler New Member
![SmallBlockKohler](https://2img.net/u/2812/37/66/46/avatars/2699-86.jpg)
Age : 28 Join date : 2016-10-02 Points : 2908 Posts : 6 Location : Nehawka, Ne
![97ish cub cadet Empty](https://2img.net/i/empty.gif) | Subject: 97ish cub cadet December 5th 2016, 1:26 pm | |
| Not quiet sure how to start this off so bear with me.This is my 97ish cub cadet i picked up one day on CL for 90$, The guy said it dint run but i jumped the solenoid and it fired right up when i got home. Its got a shaft driven hydro gear behind a 13hp kohler. ![97ish cub cadet <a href=](<a href=) ![97ish cub cadet 20160410](https://i.servimg.com/u/f37/19/58/18/18/20160410.jpg) " /> A few things ive done already are. Move the front axle forward about 6 inches Made some pretty neat steering arms Made a rear plate for shackles to hook to Slapped some alright tires on it Currently re-doing the dash and wiring. ![97ish cub cadet 20160911](https://i.servimg.com/u/f37/19/58/18/18/th/20160911.jpg) And much much more planned. | |
| ![Go down](https://2img.net/i/empty.gif) | | Doug Site Owner
![97ish cub cadet Empty](https://2img.net/i/empty.gif) | Subject: Re: 97ish cub cadet December 5th 2016, 1:35 pm | |
| That long arm looks like it would be a great brake handle. Good deal for $90. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| ![Go down](https://2img.net/i/empty.gif) | | MatthewD Veteran Member
![97ish cub cadet Empty](https://2img.net/i/empty.gif) | Subject: Re: 97ish cub cadet December 5th 2016, 3:16 pm | |
| Pretty good for $90. Something like that around here would cost upwards of £300. What's the Craftsman with the ATV tyres in the backround? | |
| ![Go down](https://2img.net/i/empty.gif) | | AllisKidD21 Moderator
![97ish cub cadet Empty](https://2img.net/i/empty.gif) | Subject: Re: 97ish cub cadet December 5th 2016, 5:36 pm | |
| Cool! I'd be interested to see how that drive train would do for all-terrain use. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![97ish cub cadet Empty](https://2img.net/i/empty.gif) | Subject: Re: 97ish cub cadet December 5th 2016, 5:48 pm | |
| Hydro's burn out very quickly when sped up, so not very suitable for off-road. But if you enjoy running around at stock speed, it could work, who knows? | |
![97ish cub cadet Empty](https://2img.net/i/empty.gif) | Subject: Re: 97ish cub cadet December 5th 2016, 6:06 pm | |
| Cub hydros are pretty quick. If its not the belt driven driveshaft it should do great. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| ![Go down](https://2img.net/i/empty.gif) | | CraftsmanQuad19 Veteran Member
![CraftsmanQuad19](https://2img.net/u/2812/37/66/46/avatars/2588-88.jpg)
![97ish cub cadet Empty](https://2img.net/i/empty.gif) | Subject: Re: 97ish cub cadet December 5th 2016, 6:15 pm | |
| Looks a lot like the one @TheGreenHornet and I tore apart. The hydro is shaft driven from the flywheel correct? Some people build pullers with these things, they're the exception to the "hydros are weak" rule | |
| ![Go down](https://2img.net/i/empty.gif) | | SmallBlockKohler New Member
![97ish cub cadet Empty](https://2img.net/i/empty.gif) | Subject: Re: 97ish cub cadet December 5th 2016, 7:01 pm | |
| the craftsman in the background has a hydrostat also. not sure what year or model but its a trooper, i drowned it a few weeks ago and put new oil and gas in it and it fired back up no problem...i check water levels now before i dive in... And the transaxel is a sorta good but sorta bad deal. the long lever was for the pedal so you wouldent have to use youre foot, but people use it as a speed controll which its ment to be mashed. this wears out the clutch packs from what ive read but a washer added to the disks fixes it like a shim. its not slipping too bad in the mud and water but when i have decent tires on going up hills i have to put it in 1st. ill be shimming it when i weld the spider gears which is a must for this thing. | |
![97ish cub cadet Empty](https://2img.net/i/empty.gif) | Subject: Re: 97ish cub cadet December 5th 2016, 7:05 pm | |
| and yes the drive shaft comes off the flywheel into a hydro pump clutch deal which goes to a geared transaxel from what i understand from reading.
![97ish cub cadet Empty](https://2img.net/i/empty.gif) | Subject: Re: 97ish cub cadet December 6th 2016, 8:06 am | |
| Looking at your profile pic, it doesn't look like you waited long to beat on it. How's it do? | |
![97ish cub cadet Empty](https://2img.net/i/empty.gif) | Subject: Re: 97ish cub cadet December 6th 2016, 1:17 pm | |
| A tough hydro! Finally my life is complete. LOL, hope you have fun with it. Wish there were more shaft driven lawn tractors out there. | |
![97ish cub cadet Empty](https://2img.net/i/empty.gif) | Subject: Re: 97ish cub cadet December 6th 2016, 2:59 pm | |
| its pretty decent its got its moments that it shines and moments when it sits like a turd. it needs more wheelspeed in the mud but does good on trails plowing over stuff. i need to replace a valve stem and i can test its lengthened wheelbase sometime today | |
![97ish cub cadet Empty](https://2img.net/i/empty.gif) | Subject: Re: 97ish cub cadet December 12th 2016, 1:00 am | |
| so today i found out i lied about it being a hydro... i thought sense it had the pedal and was called a hydrogear it was a hydro. Instead what i thought was the pump is actually 2 clutch packs (forward/reverse) which is why it has the pedal. ive taken the clutch housing apart to shim the clutch packs and wow its an interesting transaxel. hope i can go up hills again after this. all and all today was a good day. almost got my wheels turning again and got lucky and picked up a 18.5hp twin opposed cylinder for 10 bucks just needs a carb figured why not. if it runs i may start on a custom frame mower and slap this (i think) peerless 600 series with the 18.5hp. | |
![97ish cub cadet Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | 97ish cub cadet | |
| Who is online? | In total there are 25 users online :: 1 Registered, 0 Hidden and 24 Guests SlipperzMost users ever online was 412 on January 7th 2023, 7:59 am |
