 72 cub cadet
camomanusa
Moose
Craftsman1998
8 posters
Go to page : 1, 2, 3  Next
Craftsman1998
Craftsman1998
72 cub cadet Empty
PostSubject: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 22nd 2014, 8:03 pm
72 cub cadet IMG_20140222_084952_zps05f611bf
How it looked when i got it
72 cub cadet IMG_20140222_085036_zps806f9903
72 cub cadet IMG_20140222_085050_zps8c7311f2
72 cub cadet IMG_20140222_085056_zpsd307d4ba
72 cub cadet IMG_20140222_085104_zps21a837a7
72 cub cadet IMG_20140222_184252_zps19ef3c23
Pulled the engine out of it today
Last edited by Craftsman1998 on February 26th 2014, 1:25 pm; edited 1 time in total
Moose
Moose
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 22nd 2014, 8:06 pm
throw a 6hp china diesle in it and a new coat of paint call it a day :p
camomanusa
camomanusa
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 22nd 2014, 8:07 pm
ull be a cub cadet dealer in no time
Craftsman1998
Craftsman1998
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 22nd 2014, 8:10 pm
We are going to put a different engine in it and make it a plowing tractor. But its shaft driven so i cant put just any kind of engine in it.
Craftsman1998
Craftsman1998
72 cub cadet Empty
Yep Very Happy
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 22nd 2014, 11:52 pm
do me a favor. see if the starter generator works. if it is good, give me the mod #. id be interested in it if it matches the one i need
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 22nd 2014, 11:55 pm
Very cool old iron. what fenders did it have in the rear or was it a model that didnt have them?
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 23rd 2014, 2:26 am
My buddy Brad has that same model tractor. It still starts right up. 12 inch rims on the back right?
that would be a good tractor to put one of these horizontal shaft oppy's I have into
Craftsman1998
Craftsman1998
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 23rd 2014, 9:04 am
The starter generator works ill get the mod number after church today.
Craftsman1998
Craftsman1998
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 23rd 2014, 9:05 am
When i got it it didnt have any im not sure if its a model that has them or not
Craftsman1998
Craftsman1998
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 23rd 2014, 9:06 am
Yeah i think it has 12in rims
Craftsman1998
Craftsman1998
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 23rd 2014, 9:07 am
Ill post some pictures of the engine later today or early tomorrow. it has some problems but with some work it will run. i might part it out.
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 23rd 2014, 10:39 am
Just to let you know youcan quote multiple people in one post
Craftsman1998
Craftsman1998
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 23rd 2014, 10:58 am
Oh... I didnt know that
Craftsman1998
Craftsman1998
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 24th 2014, 2:30 pm
Craftsman1998
Craftsman1998
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 26th 2014, 1:26 pm
72 cub cadet IMG_20140226_105207_zps4135f2d9
72 cub cadet IMG_20140226_105159_zps2d2c7736
Got the engine torn apart
Craftsman1998
Craftsman1998
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeFebruary 27th 2014, 8:47 pm
Craftsman1998
Craftsman1998
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeMarch 2nd 2014, 7:02 pm
I cleaned the inside of the motor out put it back together and cranked it over. But it has no spark i think the coils bad. and i had to do some redneck things to get the motor to run. The head bolts snapped and was loosing compression where the bolts were so i put some weld in it to seal it up and the spark plug hole threads were stripped so i put a spark plug in it and welded it in. I know it dangerous but its only to see if it fires and if it does ill put the money out for parts. It all worked but it has no spark so i need to get a coil or condenser.
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeMarch 2nd 2014, 8:17 pm
let me get this straight... you WELDED the head on and a spark plug in? you probably just ruined that vintage kohler... GURRR 72 cub cadet 2429134702
TroyBilt Pony
TroyBilt Pony
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeMarch 2nd 2014, 8:24 pm
You should of took the head off, extracted the bolt, installed a new bolt. Welding in the spark plug is stupidity, what if its your plug is bad? 2, you definately torqued the plug too much. You could of killed the plug just by welding next to it.
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeMarch 2nd 2014, 8:38 pm
um ......wow.......i just.......i cant even.........what the.......how in the.........beyond belief. Suspect   72 cub cadet 2429134702
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeMarch 2nd 2014, 8:40 pm
welded the plug to the hole? wtf? you ruined the block right there.
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeMarch 2nd 2014, 8:50 pm
OK guys, lets try for helpful.
Craftsman, the head needs to be removable.... welding the hole shut probably permanently attached the head. best hope now is to grind the welded spot down till it comes off... The head is ruined in any case... the plug issue alone cinched that. If you can get it loose, toss the head, it's gone. if some of the shank is visible above the block surface, weld a nut to it and back it out. If it's broken off flush, take it to a machine shop.
We all do dumb things out of desperation, but the welder should stay away from the motor little brother.
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeMarch 2nd 2014, 8:58 pm
x2 on that
Craftsman1998
Craftsman1998
72 cub cadet Empty
PostSubject: Re: 72 cub cadet   72 cub cadet Icon_minitimeMarch 3rd 2014, 8:28 am
Nope wrong The head is bad and 2 head bolts snapped And it was losing compression through the holes so i put weld in them and the spark plug holes were stripped so i welded a spark plug into the hole. Because i didn't want to put out money if it didn't run so its for testing purposes. And i didnt weld the head on and i didnt ruin the engine Just the head but it needs a new one anyway.
72 cub cadet Empty
72 cub cadet
» My new cub cadet
» Old cub cadets
» 1964 ih cub cadet 123 + more
» Cub Cadet 108
» Cub Cadet 4x4
All-Terrain Lawn Tractor Forum :: General Tractor Talk + Pictures/ Videos :: Pics and Videos-
