| 4360-180 (broken tooth) | |
garvy New Member
Age : 107 Join date : 2016-08-01 Points : 3047 Posts : 8 Location : florida
| Subject: 4360-180 (broken tooth) August 18th 2016, 2:45 pm | |
| I have a spicer that broke a tooth. I took it apart because it didn't want to shift while running and adjusting the brake didn't fix it. I found a tooth in bottom of the pan. I would like to replace it but will probably need to wait for tax return. I was thinking that I could turn it into a five speed with two neutral. if I take the bad gear and grind off all the teeth then restack them the bad set in the first speed position then maybe that would work for what I need and basically be able to move it when needed. im not exactly sure which is first and sixth gear. I think the broken gear is third but if im wrong I guess it is fourth. also: is it normal for the spider gears to hang out one side? what does the 180 mean in the model number? any help would be very much appreciated. | |
Join date : 2015-02-02 Points : 5093 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: 4360-180 (broken tooth) August 18th 2016, 7:11 pm | |
| On flywheels when the teeth get chewed up, you grind it smooth and weld it up to put metal back on the tooth, then file the weld to make a new tooth. If you got a welder, you could weld it up an then file a new tooth on it.
Looks like 3rd gear. | |
| | | garvy New Member
| Subject: Re: 4360-180 (broken tooth) August 18th 2016, 9:19 pm | |
| I don't have a welder anymore I had to sell them, however the more I think about it the more I think my original idea would be more problem than it is worth. then I thought maybe a second spacer I assume it is for neutral then I could still put the gear on the input side up front and replace the bad gear with a spacer and have an extra long neutral. Dana Spacer edit: just looked on ebay and I can get the gear about the same price. but then I still don't see what is hanging up the shift keys while it is running. | |
| Who is online? | In total there are 37 users online :: 0 Registered, 0 Hidden and 37 Guests
