 how to install grease nipples?
arild365
arild365
how to install grease nipples? Empty
PostSubject: how to install grease nipples?   how to install grease nipples? Icon_minitimeMarch 14th 2010, 8:37 pm
hey guys i wanted to know if any of you could make a vid on how to instalol grease nipples. I have a few things i need to put some on but dont know how.
PostSubject: Re: how to install grease nipples?   how to install grease nipples? Icon_minitimeMarch 15th 2010, 10:04 am
where abouts? Y have to make sure they wont interfere with anything inside. Its not too hard- just drill a hole slightly smaller then the tap, tap it out, add a lil threadlocker to the zerk n tighten it down.
I bot the zerks first, then a tap - i used the tap in my electric drill . You can use zerks in any metal .
Chunk
Chunk
PostSubject: Re: how to install grease nipples?   how to install grease nipples? Icon_minitimeMarch 15th 2010, 1:03 pm
I need to figure out where to put them on my tranny. I want one on the input shaft too! Never done it before though
PostSubject: Re: how to install grease nipples?   how to install grease nipples? Icon_minitimeMarch 15th 2010, 9:55 pm
I was looking for somewhere to put one on my transaxle - everything was just too close to the case or unacessable from underneath .
I think ill do that to more of my transmissions - i found out today i bot some of that heavy duty grease ( like the green wheel bering grease ) for the grease gun- that stuff should work awsome in the transmissions- better then the red stuff cause its super thick.
When my tractors come due for maintence ill start adding zerks to em- better put more of those on my list- im almost out of em!
Chunk
Chunk
PostSubject: Re: how to install grease nipples?   how to install grease nipples? Icon_minitimeMarch 16th 2010, 3:59 am
It's really my input shaft I want to do. Im not sure how easy it will be though. Need to make sure it's all really smooth inside still. Probably will have to cut the nipple down a bit too.
PostSubject: Re: how to install grease nipples?   how to install grease nipples? Icon_minitimeMarch 16th 2010, 4:33 pm
dont cut too much off the zerk- theres a tiny spring and ball in there- it keeps the dirt out and the grease in- if y could find a small nut to lock it down before it goes too far in would be okay.
Chunk
Chunk
PostSubject: Re: how to install grease nipples?   how to install grease nipples? Icon_minitimeMarch 16th 2010, 5:46 pm
Didnt think of that. That would work much better!
» How do you grease a transmission if there is no grease nipple?
» How to install a PTO rear drive on your tractor
» Anyone know how to install a pulse fuel pump on my 13 HP diamond performance flathead briggs?
» grease or oil?
» Transaxle oil/grease
