 How to install a PTO rear drive on your tractor
5 posters
FOSWMT
FOSWMT
How to install a PTO rear drive on your tractor Empty
PostSubject: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 19th 2013, 9:23 am
I do not i think have a PTO drive on my Gazelle W11 tractor and am wondering what all the party look like I have found a diagram but wonder if this is how it is done on my machine it did come with an odd tube with horns on it ?
How to install a PTO rear drive on your tractor Kgrhqm10
http://www.friendsofspeckledwood.org.uk
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 19th 2013, 9:27 am
How to install a PTO rear drive on your tractor Kgrhqr10
The Tractor came with one of these and a wallet of eye pins but have no idea what they are for
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 19th 2013, 12:31 pm
I am presuming this is what i need?
How to install a PTO rear drive on your tractor Suskqk10
How to install a PTO rear drive on your tractor Qgfbsu10
And this bottom bit presses into holes on pulley?
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 19th 2013, 2:23 pm
How to install a PTO rear drive on your tractor Sam_4411
Cut a hole and it although its not need at present can se i need three prong holes anyone have any ideas please
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 20th 2013, 9:21 am
Have re-cut PTO access to its neater . Am now wondering how far to cut the back up to allow access for the belt . I presume it will have to be at least 2" from the sides to allow for the bolt holes but I dont know how far up it should be.
The new cut hole from the underside
How to install a PTO rear drive on your tractor Sam_4412
My rear panel currently looks like this :
How to install a PTO rear drive on your tractor Sam_4413
It fits snuggly down to the chassis. I intend to cut this 2" from either side and up far enough to fit a flap . I really could do with some measurements for this?
Also does anyone know anything about pully's types please . It looks like I will have to drop transaxle to remove and fit a different pully . Any Idea whats available and what will work with PTO
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 20th 2013, 11:08 am
Have re measured and I have about 3" from each side before i get into the bottom bolt holes . I have 6 inches vertically to make a hole . I have seen this but it doesnt give you much idea of dimensions.
How to install a PTO rear drive on your tractor Westwo10
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 20th 2013, 11:19 am
I have just learned that there isnt different pullets but a PTO ring which bolts to the pully yet another part to order
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 20th 2013, 11:34 am
This would be what it looked like 3" in leaving the bolt on the back in place The height of this panel is 6" . I am wondering if i can adapt a flap from a lawn mower to cover this pannel
I am thinking this is not as wide as the one I have a photo off Someone must have this on their tractor I could really do with some measurements please?
How to install a PTO rear drive on your tractor Sam_4414
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 20th 2013, 11:49 am
If I take it back to the seam this would loose the one rear bolt hole and would give around an 1" all the way round this looks more like the red tractor picture ? Can you let me know what you think please?
How to install a PTO rear drive on your tractor Sam_4416
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 22nd 2013, 10:36 pm
Sorry you're not getting any replies on this FOS...
I've not seen anyone on here work with PTOs... hope you find the info you're looking for and post it up as the new authority on the subject.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 23rd 2013, 1:05 pm
Hi The Rainbow.
I have been working on this and have cut the rear out and intend on getting some 1/2 " angle iron to go around the outside to neaten hole and prevent snagging. The inner part will become the hinged section with a stay and lock to keep fingers out.
How to install a PTO rear drive on your tractor Sam_4419
I received a Jocky wheel from a 91 Westwood which I think will all fit
How to install a PTO rear drive on your tractor T2ec1611
With the aid of a diagram from the 91 machine I have identified the parts I require
How to install a PTO rear drive on your tractor Westwo11
I have received the PTO connector today
How to install a PTO rear drive on your tractor 86410
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 26th 2013, 11:43 am
Cleaned up blasted flywheel
How to install a PTO rear drive on your tractor Sam_4420
Painted and fitted newly ordered PTO adapter . This still need bolting place. Was placed on transaxle to see how it looked
How to install a PTO rear drive on your tractor Sam_4421
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 26th 2013, 12:16 pm
Ummmm, you should change the name of this thread....
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 29th 2013, 10:45 am
Cant do that not an admin :-) Oh yes lol just did hope thats better
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 29th 2013, 10:49 am
Flywheel bolted to PTO drive
How to install a PTO rear drive on your tractor Sam_4510
Chassis turned upside down to have a look at rust
How to install a PTO rear drive on your tractor Sam_4512
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 29th 2013, 12:01 pm
You can edit your initial post, changing the title.
Chaos Build
Haspin 2021 thread
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeOctober 29th 2013, 3:19 pm
De rusted and red-oxided underneath was surprised what little rust there was. Next job is to find and buy other parts :
How to install a PTO rear drive on your tractor Sam_4513
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeNovember 9th 2013, 4:54 am
Have been quiet as have been busy the underneath is now painted and rear tranxaxle and new belt fitted. Strangely I found out why the tractor was not changing gear smoothly someone in the past had put a belt on and revered the clutch pulleys so that they could not turn and graded on the clutch mechanism. Have sorted this.
Had a lucky find and have found a lot of the parts from a tractor that was to be broken:
a T1200 i think from 1988. These donor bits look very good:
How to install a PTO rear drive on your tractor Dscn0210
It seems that the PTO gear box had been fitted incorrectly and that the pto shaft had been hitting the pulley and been driven from that. I removed the PTO shaft from the gearbox by first removing the top pulley. The pulley came of with my method i found on Youtube to use candle wax melted into it and drove it out easily . This enabled me to unbolt the PTO gearbox top. I used a puller to pull the top bearing off and drove the other out through the bottom. This has given me the shaft and I have ordered a new one.
You can see the damage this did to the shaft.
How to install a PTO rear drive on your tractor Sam_4610
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeNovember 16th 2013, 11:42 am
Finally got hold of a PTO shaft a new one for £30.00 so put gearbox back together.
How to install a PTO rear drive on your tractor Sam_4710
I used the PTO on the gearbox and a pencil to mark the perimeter of the bolt holes I took a bolt out to use a smaller hole and lost it in the garage . Will be off shopping on
Monday again at some point. I then used the gearbox to mark holes and checked they was parallel to the chassis with a square before centre punching and drilling out.
How to install a PTO rear drive on your tractor Sam_4711
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeNovember 17th 2013, 4:31 am
Holes drilled and chassis painted again.  Spoke to my supply at westwood spares who say spacers are not on their catalog anymore as its to old . Spent yesterday going through all of their catalogs to see if i could find the two spacers they have on any of their catalogs the answer is no so have sent and email requesting sizes of the two that they have.
Have decided to make a working drawing of the pulleys to see what spacers i would require in case i have to make them.
How to install a PTO rear drive on your tractor Drawin10
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeNovember 17th 2013, 6:35 am
Holes cut 8mm . I think I need a 17mm bottom spacer and a 28mm jockey wheel spacer.
How to install a PTO rear drive on your tractor Sam_4712
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeNovember 17th 2013, 1:27 pm
Definately a good looking project! looks neat!
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor Icon_minitimeNovember 18th 2013, 2:11 pm
Cleaned up the Jokey wheel
How to install a PTO rear drive on your tractor Sam_4713
FOSWMT
FOSWMT
PostSubject: bolted in gearbox and made spacers   How to install a PTO rear drive on your tractor Icon_minitimeDecember 18th 2013, 1:17 pm
I re-assembled PTO Gear box with bolts and found some spacers on ebay which would raise the gearbox up 10mm This with a washer gave me the correct height. I bent an 8.8 HT bolt to make the belt guard. I made it longer and inserted it in back rather than front.
How to install a PTO rear drive on your tractor Sam_4813
I bolted this down giving me the size of the spacers i Needed to find
Having been told that the Spacers for the pulley arm where obsolete. I decided I would have to make them I used the pulley inserts that are available cutting them down to fit.
How to install a PTO rear drive on your tractor Sam_4811
I milled these on a small lathe but thus could be done by a drill and file.
How to install a PTO rear drive on your tractor Sam_4812
FOSWMT
FOSWMT
PostSubject: Jockey whel mounted   How to install a PTO rear drive on your tractor Icon_minitimeDecember 18th 2013, 1:26 pm
I used the spacers i had created from the pulley spacers to make up the jokey wheel this mounted up fine I greased thoroughly. I had used 10mm bolts all around instead of the standard bolts I hoped this would make it stronger.
How to install a PTO rear drive on your tractor Sam_4910
I received the accessory adapter back from the zinc platers it looks fabulous
How to install a PTO rear drive on your tractor Mounto10
I replaced the body work to check clearance and bolted it down.
How to install a PTO rear drive on your tractor Sam_4911
» Ideas for rear suspension for off-road tractor.
» Has anyone made a rear engine mower for offroad?
» Stop rear drive belt from breaking!
» Murray Rear Engine Tractor
» Do you drive a lawn tractor or ride it?
