 How to install a PTO rear drive on your tractor
5 posters
Go to page : Previous  1, 2
FOSWMT
How to install a PTO rear drive on your tractor - Page 2 Empty
PostSubject: Jockey whel mounted   How to install a PTO rear drive on your tractor - Page 2 Icon_minitimeDecember 18th 2013, 1:26 pm
I used the spacers i had created from the pulley spacers to make up the jokey wheel this mounted up fine I greased thoroughly. I had used 10mm bolts all around instead of the standard bolts I hoped this would make it stronger.
How to install a PTO rear drive on your tractor - Page 2 Sam_4910
I received the accessory adapter back from the zinc platers it looks fabulous
How to install a PTO rear drive on your tractor - Page 2 Mounto10
I replaced the body work to check clearance and bolted it down.
How to install a PTO rear drive on your tractor - Page 2 Sam_4911
http://www.friendsofspeckledwood.org.uk
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor - Page 2 Icon_minitimeDecember 18th 2013, 1:33 pm
do you have a attachment for this tractor on why your doing this? I've been wondering....
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor - Page 2 Icon_minitimeDecember 18th 2013, 1:37 pm
Not yet am intending to yes or will make something am considering converting a Shredder from a Countax
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor - Page 2 Icon_minitimeDecember 18th 2013, 3:18 pm
Fitted Adapter bar need a wigget to hold it up . How to install a PTO rear drive on your tractor - Page 2 Sam_4913
Am considering a Countax mechanism to do this as the existing leavers requires slots cut for them to function. These also have their operational parts under the chassis were they are subject to damp and rust. I am hoping the Countax PGC Lift Linkage  I have purchased will do a better job it may need some work to integrate it.
How to install a PTO rear drive on your tractor - Page 2 Pgc_li17
Am waiting for this to arrive as the 2009 tractor had the same chassis and mine and this similar mechanism
FOSWMT
FOSWMT
PostSubject: Re: How to install a PTO rear drive on your tractor   How to install a PTO rear drive on your tractor - Page 2 Icon_minitimeDecember 28th 2013, 9:45 am
Rear lift from Countax T1600 turned up and is in great condition have took of the flap and de revited it and cleaned up all of the bright work. Am thinking that I may replace the Westwood lift for this as the countax accessories are more available still.
» Ideas for rear suspension for off-road tractor.
» Has anyone made a rear engine mower for offroad?
» Stop rear drive belt from breaking!
» Murray Rear Engine Tractor
» Do you drive a lawn tractor or ride it?
