 transfer case locking help
Caddy_V3
Caddy_V3
transfer case locking help Empty
PostSubject: transfer case locking help   transfer case locking help Icon_minitimeMarch 22nd 2016, 2:16 pm
Hi I am tring to lock my transfer case on my snaper lt 12. the main problem is it is a spur gear stile. normal all the info is on a normal spider gear one. for a wile i thought i needed to weld the axles where they are nearly flush.
note this is not my image it just is a photo of the differential.
transfer case locking help Mvc-0110
Rockinator
Rockinator
PostSubject: Re: transfer case locking help   transfer case locking help Icon_minitimeMarch 22nd 2016, 7:22 pm
I would think if the gears operate anything like the peerless 633a's (the gears have the same arrangement) you could just weld the two sets of gears together. Im not positive on this though, since pretty much every diff/transmission/transfer case is different in some way
PostSubject: Re: transfer case locking help   transfer case locking help Icon_minitimeMarch 23rd 2016, 3:34 pm
Weld the small gears together, thats best way
mudman604
PostSubject: Re: transfer case locking help   transfer case locking help Icon_minitimeMay 20th 2016, 11:39 am
you could also invert one ove the small gears per pair.
» 122419X for a trans/transfer case
» Cracked tranny case
» Toro lx425 tranaxil transfer and more.
» Is there any way to repair a cracked peerless 700 case
» in case you didnt know
