 Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]
mowerjunkie03
tater195
Crafty
TedTheDestroyer
sadeoo7
rarbaugh07
rstolz
STUNTMAN JON
MasonMcK
redzz02
tscustoms
Rockinator
cablguy2
40 posters
Go to page : Previous  1 ... 5, 6, 7 ... 14 ... 22  Next
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Empty
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 16th 2016, 5:54 pm
Nice Progress, Won't that clutch be on the "wrong" side of the ideal side aka the tight side of the belt. Or wont it matter?
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 16th 2016, 9:58 pm
Thanks, actually the input on the sears transmission runs backwards in relation to the wheels. So that is the slack side of the belt.
Just a quick mock up to get an idea where things will fit later. The rear belt idler spring an tensioner is now pretty much done. Hood will be a little lower than this I think. Either way, it won't look so tall after I get the bumper on.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5006_zpswlgtjpuf
Decided to just use the stock sears seat spring for now. Blue seat is from the GTR 4 zero and happened to be sitting close by.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5004_zpsuyficwsu
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 16th 2016, 10:13 pm
You and your steel seats.
rarbaugh07
rarbaugh07
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 16th 2016, 10:19 pm
Looks like you're trying beat redlines rock bouncer more than making an overland type vehicle. Lol either way it's pure awesomeness.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 17th 2016, 9:24 am
Looks great! Need more power tho man! Very Happy
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 17th 2016, 11:11 am
Thanks. Always trying to beat redline regardless... We'll see how it turns out. I have no idea where the battery and gas tank are going to fit. Once I get most of the other stuff in place, I'll be able to look for a spot. And doug, steel seat is all part of the high tech design. Can't be riding around in wet conditions with soggy seat foam. I'm not 100% on a steel seat yet, but it would be nice in streams.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 17th 2016, 11:17 am
I actually think that a steel seat suits that tractor. Not too sure about the over hanging front end though, but maybe will look better once the winch/bumper is on.
cablguy2
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 17th 2016, 9:25 pm
This build is coming along nice. I like it. I need to back out I can't build that nice, lol. Seriously good looking build.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 17th 2016, 10:17 pm
Thanks. Yeah the front end should look less weird once the bumper is on. Current status is engine mount holes drilled, trans to jackshaft belt installed. I think I'm going to bolt on a seat and mount the foot plates now so I can figure my clutch linkages better.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 18th 2016, 5:26 am
Nice!
Just wondering how you're gonna work the pivoting hood deal because of the bumper? I'm gonna have the same problem.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 18th 2016, 1:56 pm
Hood will just bolt on in this case. I might make hood pins, but I think a bolt on setup would be easier to make. Pins need to be aligned a bit more and then you should have rubber or something under the hood so it doesn't rattle. On my last simplicity, I just cut those pins off on the front of the grill so they stuck straight down, then had holes for them to set in. Held that one down with rubber bungies, but they get dry rotted after awhile.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 18th 2016, 9:37 pm
Snowmobile hood tie downs would work good. Made of a better rubber compound.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 20th 2016, 9:32 am
Ah right okay. Are you not doing a double pulley clutch, or is there not enough room?
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 20th 2016, 6:45 pm
Snowmobile hood holders would work. I'll have to see where things end up. I think I might have room for a double pulley clutch. I decided to put the foot plates on first so I can make the clutch pedal and then work backwards with the linkages from there. A couple of supports in front of the jackshaft will hold the clutch rod and also brace up the jackshaft plate. Clutch is next on the list.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5007_zpsxwmcfh3v
A section of 1" box steel comes out from the frame to hold the original simplicity plates. I did cut the brackets off the plates that used to hold the stock clutch rod and pedal. I thought I would use the simplicity pedal for the gas, but I think I'll just make my own. Rub rails aren't done yet. I'm adding a second rail a couple inches higher and bracing everything together.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5008_zpsa4dsuga0
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeMarch 31st 2016, 9:00 pm
Clutch work. Two of the same rectangle pieces that I used for the front suspension will help hold the jackshaft plate and the clutch shaft. I cut one of the 3/4" spindles from the stock front axle and then cut it in half.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5040_zpsbdew5tic
An arm will get welded from the shaft to the pulley I'm holding. Then a linkage rod will run down to the clutch pedal on the other end of the shaft.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5042_zpsqkhssiwm
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeApril 3rd 2016, 3:27 pm
Nice work! Lots of fab work going on Very Happy
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeApril 3rd 2016, 9:35 pm
Thanks. Making some slow progress.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeApril 4th 2016, 1:40 pm
Yeah, looking really good though. By the way are there 2 clutches or is the rear one just a tensioner?
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeApril 5th 2016, 9:50 pm
Just going to be one clutch. The rear one is just a tensioner. I'll put a guard around the rear belt tensioner pulley and the rear belt.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeApril 6th 2016, 7:33 pm
But will kit keep up with the mtd??? Sure its got me in range, but high performance stuff doesnt go far anyways.
^^^^ Other people know... tongue tongue Razz
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeApril 11th 2016, 8:41 pm
Some recent progress on the MTD killer.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5057_zps8lu7jxgk
Steering mount adjustment so the joint clears the wishbone.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5058_zpstii9kxb7
Clutch pedal and linkages.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5060_zpsnyr6jlbx
Alternator brackets, looking forward from where the engine sits.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5061_zpskdhdajg4
Brackets with alternator looking from the front.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5063_zpsiwq9qnvx
Hood semi mounted and winch bolted in place.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5064_zpshiul5q6j
Front bumper welded up but not hooked to the frame yet. Should protect the winch from brush pretty good.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5065_zps5pmwl7jj
Super heavy duty brackets for recovery hooks. These are the brackets from the sear axle cut down and welded two wide.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5066_zps6tcnpioq
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeApril 11th 2016, 10:58 pm
I wonder if theres a way to weigh both our rigs when we meet up again. mines going to weigh more being opposed i bet, but im curious.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeApril 12th 2016, 7:52 am
Lot of cool looking progress..
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeApril 12th 2016, 5:24 pm
Cool looking clutch pedal. Pretty beefy looking linkages too. Front bumper looks great. With all this steel and fab work I dont think 7 horsepower will be enough! Very Happy Very Happy
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeApril 13th 2016, 1:23 pm
Thanks guys. I don't know how much it'll weigh. Hopefully the 7-8hp engine will do it. I think it'll be ok, just on steep hills or mud you'll be in low gear. High gear will mostly just be for smoother spots where you have a chance to get rolling. Most of what's on the machine now is the heavy stuff. Still need a battery somewhere too. The clutch pedal is actually the stock simplicity tie rod or link rod between the wheels. Then the pivot is one of the simplicity spindles with the other spindle cut in half up top to hold the clutch rod/shaft. Hopefully it will have enough travel to operate the clutch correctly, should be ok.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 Icon_minitimeApril 13th 2016, 8:59 pm
Welding in the extensions for the bumper.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5069_zpss8tihh8v
Bumper installed.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5071_zpsdmpjhrfb
Everything fits pretty good. Needed the bumper out in front of the winch enough that trees would hit the bumper first, but not too far or it would restrict how much angle you could have on the winch cable. The way it is now you can go about 45 degrees before the cable scrubs the bars in the bumper. If you really need to, you could just let it drag, just digs the heck out of it is all. I think usually your working in a generally forward direction anyway.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5072_zpsqnr3aacc
Designed the bumper to fit these LED lights. They should be pretty well protected in there. Could even weld some more thin rods across in front of the lights. Undecided if there will be a couple more lights up near the steering wheel on the sides of the hood.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 6 IMG_5073_zpsxopkkw4r
Page 6 of 22Go to page : Previous  1 ... 5, 6, 7 ... 14 ... 22  Next
» TSCUSTOMS Dirty Burban [2016 Build-Off Finalist]
» Tractorhead's Roper Romper [2016 Build-Off Finalist]
» Chase Towns's Daisy FMC [2016 Build-Off Finalist]
» Maine Mud Mower's "Not the Norm" [2016 Build-Off Finalist]
» redzz02 Drift Missile [2016 Build-Off Finalist]
