| TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] | |
+11MatthewD Off Road Domination redzz02 STUNTMAN JON jonnya MasonMcK marmower donaldcon Rockinator cablguy2 tscustoms 15 posters |
tscustoms Member
![tscustoms](https://2img.net/u/2812/37/66/46/avatars/2217-14.jpg)
Age : 23 Join date : 2015-02-25 Points : 3547 Posts : 54
![TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] Empty](https://2img.net/i/empty.gif) | Subject: TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] February 1st 2016, 3:29 pm | |
| this is my 2016 atltf build off mower its a 75 sears st16 that is going to be a off road mower thing I am going to do to it 25in vampires on the back 19in front tires 14hp predator leds winch bumper fix the hood possibly a new lower peace possibly a locked trans custom throttle new pan seat cut the back plate and a black and gray paint job ![TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] Gopr0316](https://i.servimg.com/u/f68/19/37/14/46/gopr0316.jpg) ![TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] Gopr0317](https://i.servimg.com/u/f68/19/37/14/46/gopr0317.jpg) thanks TSCUSTOMS
cablguy2 Member
![TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] Empty](https://2img.net/i/empty.gif) | |
Rockinator Member
![Rockinator](https://2img.net/u/2812/37/66/46/avatars/2502-41.jpg)
Age : 23 Join date : 2016-01-16 Points : 3335 Posts : 164 Location : Canada
tscustoms Member
donaldcon Member
![donaldcon](https://2img.net/u/2812/37/66/46/avatars/2291-72.jpg)
Age : 38 Join date : 2015-04-28 Points : 3883 Posts : 397 Location : Roseville, OH
marmower Member
![marmower](https://2img.net/u/2812/37/66/46/avatars/2413-17.jpg)
Age : 23 Join date : 2015-10-23 Points : 3298 Posts : 46 Location : Michigan
![TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] Empty](https://2img.net/i/empty.gif) | Subject: Re: TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] February 1st 2016, 8:36 pm | |
| This looks like its gonna be a awesome build man. those vampires are definitely gonna perform awesome ive got a pair on my 68 Simplicity. But may i ask, why do you use honda clone engines? | |
tscustoms Member
![TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] Empty](https://2img.net/i/empty.gif) | Subject: Re: TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] February 1st 2016, 9:34 pm | |
| - marmower wrote:
- This looks like its gonna be a awesome build man. those vampires are definitely gonna perform awesome ive got a pair on my 68 Simplicity. But may i ask, why do you use honda clone engines?
Thanks I use the clones because they are cheap good engines and I can get parts any where I would use real Hondas but there to much and to much to fix and I like the old kholers also | |
MasonMcK Member
![MasonMcK](https://2img.net/u/2812/37/66/46/avatars/2172-89.jpg)
Age : 24 Join date : 2015-01-26 Points : 3611 Posts : 96 Location : Carroll County, Maryland
![TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] Empty](https://2img.net/i/empty.gif) | Subject: Re: TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] February 1st 2016, 10:10 pm | |
| You should swap a Kohler K series into one of your future Sears builds. No one ever does that swap and it seems pretty easy. Plus Kohlers can be built extensively and have tons of torque. Good luck! | |
jonnya Member
Age : 48 Join date : 2014-08-19 Points : 3786 Posts : 95 Location : Norfolk, England, UK
![TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] Empty](https://2img.net/i/empty.gif) | Subject: Re: TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] February 2nd 2016, 1:50 am | |
| - tscustoms wrote:
Thanks I use the clones because they are cheap good engines and I can get parts any where I would use real Hondas but there to much and to much to fix and I like the old kholers also I'm also using a Honda clone in my build (I'm doing my photos/entry etc at the weekend - watch this space) for similar reasons. Bits are easier to get in the UK, especially tuning parts as they are used extensively in karting whereas Briggs engines arent. Only standard (Briggs) bits are readily available, but are relatively expensive (They are imported bits to the UK). I've often ordered small parts from the US as it often works out cheaper! I have about 15 or so Briggs engines (nearly all vertical shaft) but as I am building a speed machine this year, decided on a clone. | |
donaldcon Member
tscustoms Member
![TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] Empty](https://2img.net/i/empty.gif) | Subject: Re: TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] February 2nd 2016, 7:46 am | |
| - MasonMcK wrote:
- You should swap a Kohler K series into one of your future Sears builds. No one ever does that swap and it seems pretty easy. Plus Kohlers can be built extensively and have tons of torque. Good luck!
Thanks I am planning on it I have a 14hp k series that was made for pulling I never fished the tractor so the engine never made it in its a big bore | |
tscustoms Member
tscustoms Member
STUNTMAN JON Member
![STUNTMAN JON](https://2img.net/u/2812/37/66/46/avatars/2511-24.png)
Age : 39 Join date : 2016-01-22 Points : 3260 Posts : 100 Location : Belfast Northern Ireland
![TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] Empty](https://2img.net/i/empty.gif) | Subject: Re: TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] February 4th 2016, 3:41 pm | |
| - jonnya wrote:
I'm also using a Honda clone in my build (I'm doing my photos/entry etc at the weekend - watch this space) for similar reasons. Bits are easier to get in the UK, especially tuning parts as they are used extensively in karting whereas Briggs engines arent. Only standard (Briggs) bits are readily available, but are relatively expensive (They are imported bits to the UK). I've often ordered small parts from the US as it often works out cheaper! I have about 15 or so Briggs engines (nearly all vertical shaft) but as I am building a speed machine this year, decided on a clone. you ever use a guy called gx tuning in England? i was speaking with him before christmas about getting some arc stuff but he's very hard to get a hold of now lol TS - i like your shed/garage man lol looks awesome | |
tscustoms Member
Rockinator Member
STUNTMAN JON Member
donaldcon Member
![TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] Empty](https://2img.net/i/empty.gif) | Subject: Re: TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] February 5th 2016, 10:39 am | |
| Those 25s should clear the fenders. I'm running those fenders on mine with 26s and no rubbing.
Though vamps are a bit more aggressive than my tires are.
Can't wait to see this thing finished | |
tscustoms Member
![TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] Empty](https://2img.net/i/empty.gif) | Subject: Re: TSCUSTOMS Dirty Burban [2016 Build-Off Finalist] February 5th 2016, 1:53 pm | |
| - offroadohio wrote:
- Those 25s should clear the fenders. I'm running those fenders on mine with 26s and no rubbing.
Can't wait to see this thing finished I have no rubbing there close to the fenders but no rubbing. | |
tscustoms Member
redzz02 Site VIP
![redzz02](https://2img.net/u/2812/37/66/46/avatars/36-47.jpg)
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 29 Join date : 2010-05-12 Points : 6302 Posts : 899 Location : PA pittsburgh and pymatuning
Off Road Domination Member
![Off Road Domination](https://2img.net/u/2812/37/66/46/avatars/2534-11.jpg)
Age : 22 Join date : 2016-02-17 Points : 3208 Posts : 74
tscustoms Member
MatthewD Veteran Member
