| Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] | |
+36mowerjunkie03 biggasmowers muckmudd Buck Double W Cross Ranch Crazy_Carl Lawren Wimberly RichieRichOverdrive CraftsmanQuad19 tater195 Doc Sprocket MightyRaze AllisKidD21 TheBeal MatthewD mr.modified kawasaki220 Crafty TedTheDestroyer sadeoo7 TheRainbowBoxer rarbaugh07 prancstaman rstolz 1997 Murray Thunderdivine STUNTMAN JON MasonMcK redzz02 tscustoms Rockinator cablguy2 Stretch44875 redlinemotorsportts Doug Creepycrawler 40 posters |
![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] April 13th 2016, 8:59 pm | |
| Welding in the extensions for the bumper. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5069_zpss8tihh8v](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5069_zpss8tihh8v.jpg) Bumper installed. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5071_zpsdmpjhrfb](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5071_zpsdmpjhrfb.jpg) Everything fits pretty good. Needed the bumper out in front of the winch enough that trees would hit the bumper first, but not too far or it would restrict how much angle you could have on the winch cable. The way it is now you can go about 45 degrees before the cable scrubs the bars in the bumper. If you really need to, you could just let it drag, just digs the heck out of it is all. I think usually your working in a generally forward direction anyway. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5072_zpsqnr3aacc](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5072_zpsqnr3aacc.jpg) Designed the bumper to fit these LED lights. They should be pretty well protected in there. Could even weld some more thin rods across in front of the lights. Undecided if there will be a couple more lights up near the steering wheel on the sides of the hood. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5073_zpsxopkkw4r](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5073_zpsxopkkw4r.jpg) | |
![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 Empty](https://2img.net/i/empty.gif) | |
MatthewD Veteran Member
Thunderdivine Veteran Member
![Thunderdivine](https://2img.net/i/fa/i/avatars/gallery/Cine_Seigneur_des_anneaux/Lotr_129.jpg)
Join date : 2012-12-21 Points : 6469 Posts : 2101 Location : Norway, Europe
![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] April 15th 2016, 5:58 pm | |
| Thanks. I jumped up and down on the frame some when I first got the brackets done. If I really bounce on it hard I can almost hit the stops but not quite. Should be perfect. It will flex without affecting the other side. Next couple things on the list: Rear hood support, finish clutch, fuel tank. Gas tank is going to end up in the rear like the baja sears due to space restrictions, but not stick out nearly as far. I'll still be able to use the stock hitch and it shouldn't stick out past the rear tires. | |
cablguy2 Member
![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] April 17th 2016, 9:45 pm | |
| Thanks. I got the gas tank mount/rear bumper started and also eliminated the gas filler hole in the hood since it was close to the spark plug boot with the hood level. I cut around the filler hole and then welded a square of steel under it. Still have to fill it in with some body filler to smooth it out. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5078_zps6o7sdg9b](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5078_zps6o7sdg9b.jpg) Gas tank will get tucked in here. 16 gauge square tube for a rear bumper welded to some angle iron. Still needs an extra brace on each side to beef it up in case I get ran into or back into a tree. Also need to weld the filler neck to the tank. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5080_zps8en8gmiy](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5080_zps8en8gmiy.jpg) Bumper high enough to clear the off road trailer at the bottom of hills or steep angles. Tail light will probably end up top center of the bumper. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5079_zpse2qfsq3a](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5079_zpse2qfsq3a.jpg) | |
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5372 Posts : 1311 Location : NW USA
Stretch44875 Administrator
![Stretch44875](https://2img.net/u/2812/37/66/46/avatars/314-28.jpg)
Age : 49 Join date : 2012-04-05 Points : 5627 Posts : 959 Location : Mansfield, Ohio
![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] April 24th 2016, 9:51 pm | |
| We're getting there, but I still don't have a clutch or the carb mounted. This week I have off, so I should be able to get a lot done if I don't waste too much time doing other things. At least now almost everything is roughed out with all the major stuff except the battery where it needs to be. On the other hand almost nothing is 100% done. Everything has small things that need to be taken care of. But I should be ready for Haspin. | |
![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] April 25th 2016, 5:23 pm | |
| Clutch from the top. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5093_zpsi6jhyy0n](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5093_zpsi6jhyy0n.jpg) Clutch 99% done. Might need a sleeve or extra bracing of some sort to prevent that threaded rod from flexing. But at least the arm is on there and everything is lined up now. You can see a second piece of steel with a second hole under the pulley. That's just another place to bolt the pulley if the belt stretches too much or if I don't have things figured quite right since the rod is welded in place. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5094_zpsmdarnje4](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5094_zpsmdarnje4.jpg) Found this plastic adapter for the carb. Snorkel tube will slide over that and lead to the airbox at the rear of the hood. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5097_zpsrnxfsc65](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5097_zpsrnxfsc65.jpg) | |
![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] April 26th 2016, 6:58 pm | |
| Pretty much finished the rub rails. Just added a brace on both sides. On this side the brace is at a slightly different angle since part of the frame is gone to make room for the tensioner pulley. I welded the ends of the tube shut and rounded it off as much as possible so it doesn't take a chunk out of someones leg. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5100_zpsgkzb2fy5](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5100_zpsgkzb2fy5.jpg) Start of a battery tray under the seat. It's a close fit, but I think the terminals should clear ok. I can put a stop on the seat if I have to so it can't come in contact with the battery or maybe I'll make that part of the battery hold down. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5099_zpsquh9vtes](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5099_zpsquh9vtes.jpg) Welded in these rods in front of where the headlights will go. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5102_zps9n7qmkhp](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5102_zps9n7qmkhp.jpg) Also added a couple of rods to the rear bumper for extra support and made the structure which will hold the hood, visible just in front of the steering column. I think the air box is going to end up on the side of the hood. Main issues now are brakes and dash. For the dash there are a lot of weird angles and the belt system to cover up, so that might be a bit interesting. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5104_zpssn8jigqg](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5104_zpssn8jigqg.jpg) | |
![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] April 27th 2016, 9:57 pm | |
| Brakes are going to be super low tech this time. Around each wheel hub will be a band, either rubber or an actual go kart band. Instead of a foot brake, most likely I think I'll have a hand lever. The issue is that the hub's diameter is pretty small, so your not going to have as much leverage to work with. Basically, less braking effort. The main reason for doing it this way this time is just to avoid adapting a rotor. On the baja sears, I had to make studs that held the rotor behind the hub. Also, the whole brake setup on the baja sears was heavy and overkill for the relatively low speeds your traveling at. Today I worked on making a guard for the belts. Needed it sealed up good to keep water from dumping in your lap when your in a stream. I thought about making a bolt on guard, but it was easier to just weld everything together. Guard also helps brace the jackshaft plate. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5106_zpsobq5vatn](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5106_zpsobq5vatn.jpg) Plenty of room for getting the belt on and off easily. The rear belt shouldn't need much attention anyway. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5108_zpsktonoevm](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5108_zpsktonoevm.jpg) Outter cover is aluminum which fits on 4 pegs. Pegs are drilled for clips like hood pins. The forward belt will be partly covered, but it's far forward enough where you can't really reach it while in the seat. The cover makes a great place for stickers. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5109_zpsmxxr8s6p](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5109_zpsmxxr8s6p.jpg) | |
Rockinator Member
![Rockinator](https://2img.net/u/2812/37/66/46/avatars/2502-41.jpg)
Age : 23 Join date : 2016-01-16 Points : 3335 Posts : 164 Location : Canada
![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] April 28th 2016, 8:48 pm | |
| Thanks. Finished up the dash. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5114_zpswiopoh57](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5114_zpswiopoh57.jpg) Plenty of room for switches or whatever you want to put in. I think I'll put a light under the edge of the hood which will shine out on the dash at night. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5115_zpshppxwxig](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5115_zpshppxwxig.jpg) Battery will clear no problem. Made a battery hold down. Still needs one more edge welded on to keep the battery from sliding towards the wheel. Still need to weld up the fuel tank and make a strap to hold it. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5116_zps7zkoqxmi](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5116_zps7zkoqxmi.jpg) Front axle flipped upside down. I had planned on making a full skid plate over the steering, but the steering pivot is removed from the bottom, so I would have to bolt on a plate. Also there is only a small area where you can weld supports on the wishbone without getting in the way of steering rods. I decided to just make this guard that sticks down a little lower than the tie rods. This way you end up with a little better ground clearance than a full skid plate and it should help in most cases, unless you get into really jagged rocks. At least at speed a rock shouldn't clear the tie rods right off the bottom of the tractor. I still need to order some better rods. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5118_zpsuobdlkzk](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5118_zpsuobdlkzk.jpg) | |
![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] April 29th 2016, 9:51 pm | |
| Got the paint off the gas tank and welded the filler neck on. Still need to add the pickup tube and cover over a couple holes. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5127_zpszdvcl44i](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5127_zpszdvcl44i.jpg) Strap finished. Front bolts on the seat spring bolt. Rear has an adjuster that goes through a bracket welded on the bottom of the bumper. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5126_zpswzxsphlw](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5126_zpswzxsphlw.jpg)
TheBeal Veteran Member
![TheBeal](https://2img.net/u/2812/37/66/46/avatars/967-1.jpg)
Age : 29 Join date : 2013-06-06 Points : 5643 Posts : 1402 Location : Central PA
![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] May 1st 2016, 4:57 pm | |
| I thought about it but I think it should be ok without any extra bracing. I bought a quart of POR 15 fuel tank sealer. All I need to do with the tank is make sure it's cleaned out good, then weld that hole closed. Then just coat the inside and paint the outside. | |
TheRainbowBoxer Moderator
![TheRainbowBoxer](https://2img.net/u/2812/37/66/46/avatars/326-23.jpg)
Age : 49 Join date : 2012-04-23 Points : 5627 Posts : 1091 Location : Galion, OH
![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 Empty](https://2img.net/i/empty.gif) | Subject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] May 4th 2016, 11:48 pm | |
| Thanks. As long as I can stay working on it the next couple weekends it'll be there. I finished welding up the gas tank. This is just a view from inside showing the pickup tube. The hole I torched out and patched over at the bottom. The angle it is in the picture is about the angle it will be at in the tractor. I just have to rinse it out with gas then dry it out good and coat. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5132_zpsu4ynzlwe](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5132_zpsu4ynzlwe.jpg) Hood rack welded up except the brackets to bolt it to the hood. I could have just put some hooks on the hood to attach straps to, but this is mainly to keep your gear from rubbing the paint off the hood. It'll be bolted about a 1/4" up off the hood. Made from steel rod. ![Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist] - Page 7 IMG_5133_zpspzxqfvhv](https://2img.net/h/i1377.photobucket.com/albums/ah56/mrmodified1/IMG_5133_zpspzxqfvhv.jpg) | |
