 Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]
mowerjunkie03
tater195
Crafty
TedTheDestroyer
sadeoo7
rarbaugh07
rstolz
STUNTMAN JON
MasonMcK
redzz02
tscustoms
Rockinator
cablguy2
40 posters
Go to page : Previous  1 ... 5 ... 7, 8, 9 ... 15 ... 22  Next
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Empty
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 4th 2016, 11:48 pm
Thanks. As long as I can stay working on it the next couple weekends it'll be there.
I finished welding up the gas tank. This is just a view from inside showing the pickup tube. The hole I torched out and patched over at the bottom. The angle it is in the picture is about the angle it will be at in the tractor. I just have to rinse it out with gas then dry it out good and coat.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5132_zpsu4ynzlwe
Hood rack welded up except the brackets to bolt it to the hood. I could have just put some hooks on the hood to attach straps to, but this is mainly to keep your gear from rubbing the paint off the hood. It'll be bolted about a 1/4" up off the hood. Made from steel rod.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5133_zpspzxqfvhv
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 9th 2016, 9:08 pm
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5142_zpsjf4bssw0
Rod and levers for rear brakes with skid plate bracket welded to it.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5143_zpsy2v5xqeq
Aluminum skid plate, 3 bolts in front, two bolts in rear. I was going to try removing the sticker part of the sign with paint stripper (it's really hard to get off) but I kind of think it looks neat like that, so I might leave it for now. You won't notice it unless you flip over anyway.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5144_zpsolmjtm0b
Skid plate is tucked in pretty close to the lowest part of the transmission, so your not loosing much ground clearance. The only thing that's still exposed now is the link rod from the steering column to the forward steering pivot. If you get half over a log the steering rod could get bent. I may run a couple of bars down the middle of the machine to prevent that. One would be on the front axle and another from the front axle pivot to the rear skid plate.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5145_zpshskpmrqf
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 12th 2016, 10:42 pm
Nice stof sign.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 13th 2016, 7:03 pm
Oh yeah.
Started working on a muffler. Just a simple single baffle or whatever you might call it. In through the center pipe, through the holes into the big pipe, and out a short tail pipe. The main body of the muffler is a 3" pipe, end caps are some big washers I had laying around. The muffler will probably be welded one piece to the rest of the exhaust just to save time. I'm going to try finishing anything mechanical on this thing this weekend, so I can paint next weekend and then finish the wiring.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5146_zpsnf1hrdly
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 13th 2016, 10:21 pm
Nice skid plate. Are you going to paint it?
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 14th 2016, 5:29 pm
Thanks, I think I'm just going to leave it as is. Paint probably wouldn't stick to good, the coating is like a plastic sticker.
Muffler done. Made a couple brackets to bolt it to the frame. Tail pipe is angled under the frame slightly to keep water from splashing up when in a stream.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5149_zpsikhhigmu
Mounts just under the right foot board.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5151_zpsepat5wlb
If you remember from page two, I had two of those oil reservoir tanks. One I made into the gas tank. I cut the end off the other one today and shortened it to make my air box. Bolted to the hood with a couple 1/4" bolts. Two 1/4" bolts welded to the box will hold the cover on. Cut holes through the box with a hole saw and then welded the short pieces of pipe on. Snorkel of course will go on the top one. The plastic flexible tube will go to the carb.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5152_zpscolczxpk
Plastic tube will go under the edge of the hood. Cover for the air box will probably be aluminum with a silicone gasket. Once everything is fitted I'll cut out a foam filter. Hood rack now painted also. The plan is to start on paint next weekend if all goes well.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5154_zpsb5ehwgmh
sadeoo7
sadeoo7
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 14th 2016, 6:40 pm
wow i really like the fab work on the airbox and the muffler ! good job !
http://gdftech.com
TedTheDestroyer
TedTheDestroyer
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 14th 2016, 7:18 pm
I like that airbox, how are you going to keep water from getting in it?
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 14th 2016, 9:14 pm
How will it filter air? Just gonna fill it with foam?
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 14th 2016, 11:19 pm
Thanks! Filter will be a foam element with some open spaces around the inlet and outlet. I'll have more pics in the next few days. Snorkel tube will extend up from the upper tube about 4-6". You'll be able to run in water about up to the hood. I figure you've gotta leave some room for waves.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 17th 2016, 9:57 pm
Brake rod being welded on the side of the original simplicity dash.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5166_zpsvsj9y4fo
Brake band setup with the hub and wheel removed of course. The brackets are wide enough to run two thinner belts side by side or a wider one.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5167_zpsw24ohxcn
Left side of the tractor, brake handle welded to the shaft. Shaft goes under the frame to the other side operating the band on the other hub. Still need something to hold the brake lever from going too far forward. Maybe a spring to hold it forward onto the stop so it doesn't flop around on rough terrain. Brakes should be done tomorrow. I got sent the wrong fuel pump, correct one is on the way.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5168_zps2ba7nh7a
TedTheDestroyer
TedTheDestroyer
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 17th 2016, 10:01 pm
What is that band you are using for the brake from? I'm looking to make brakes that stop my tractor because if i miss a gear downhill i'm toast Smile
Crafty
Crafty
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 18th 2016, 12:13 am
It appears to be a section of serpentine belt.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 18th 2016, 4:27 pm
Yeah, just a serpentine belt from a car. I had the idea after seeing how sometimes pulleys freeze up on cars and the belts take a lot of abuse before burning off. In some cases anyway. The idea of a rubber lining isn't all that weird, they do have cheap go cart bands with rubber linings (which people say are junk). It's more of an experiment than anything. I'm not worried about wear all that much, I can replace the bands pretty easy. The belt seems to stretch a bit more than I thought, but it does clamp down on the hub pretty good. Time will tell how well they'll work. Haspin is only about 3 weeks away, no time to redesign for that. Afterwards if needed it won't be too hard to rig it up for different linings or even a whole new brake system.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 18th 2016, 11:45 pm
Air box painted, lid done. Probably use wing nuts later.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5180_zpsm1eyif7o
Decided to just put the foam in the center. Gasket is permatex black silicone. Seal is not perfect, I'll put some strip caulk on it to seal it up better before I use it, which is like a tacky putty type stuff.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5183_zpsxtrq7xgd
Air box on the hood. Snorkel tube more or less how tall it will be. Eventually my idea was to make a fancy head with a screen so it looks like a jeep snorkel, but I might not have time before haspin. Still a lot to do.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5184_zpsv2gygcch
This pic showing how the air box is connected to the carb. Plastic washing machine hose (or whatever it's from) is connected to the plastic Tecumseh carb adapter with a piece of radiator hose that fits over both of them. Still need to make a brace so the weight of all the stuff flopping around doesn't hurt the intake bolts or pull the plastic adapter off the carb. Things will probably need to be sealed up with silicone to make sure it's water tight before going into any deep water.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5188_zpsyglbvxgk
In other news, brakes are now finished. Clutch springs mounted, so the clutch is now 100% done. Few things here and there to do before paint this weekend. Tail light, dash light, various wire holders, throttle, snorkel tube brace, tie rods, shifter lever cut and re-weld (too close to belt guard in high gear).
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 19th 2016, 2:16 pm
Looking good! Have you run the engine yet?
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 19th 2016, 5:01 pm
Thanks! Not with this carburetor no. But it was a running engine before when removed from the walk behind mower it was on. It has a lot of hours on it. I have two or three carbs that will fit. One (I think the one on it now) has a smaller venturi. I was going to try that one first for better (hopefully) throttle response. I still need to make gaskets and the exhaust, then I can test run it. The fuel pump came in the mail, so now I have pretty much everything I needed to order. Just a couple of simplicity "S" stickers from vintage reproductions still on the way.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 19th 2016, 8:24 pm
Tail light bracket and guard done.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5191_zpsgrq5q42o
My idea is to run the tail light through a two way switch. Flipped one way will be direct voltage to the light, the other will run through a turn signal flasher so the light will blink.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5192_zpskzlyorvo
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 19th 2016, 10:35 pm
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 20th 2016, 10:45 pm
Plenty of time left. Finish the exhaust and any critical welding before paint this weekend. Finish up some more small bolt on parts during the week. Wiring next weekend. Then any last minute stuff and adjustments on the weekend on June 4-5. Then load onto the trailer monday afternoon June 6th for haspin. If anything gets messed up too bad I'll just put in a couple of late nights during the week to get it straightened out. Main issue is if the clutch is going to work correctly. I'll probably do a test fit sometime before painting just to make sure everything is where it needs to be. There are two places to bolt the clutch pulley on the clutch arm for adjustment, should have plenty of movement to work right.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 22nd 2016, 10:57 am
Smoking right along! Clutches can be a pain, lol...
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 22nd 2016, 2:19 pm
The start of the exhaust pipe laying on the hood. This post brought to you by coca cola.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5193_zpsfq8kuw3z
One piece exhaust finished.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5194_zpszep7fecg
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5195_zps0vorkd2o
Installed with plenty of clearance to work on belts ect. Shocks removed with suspension all the way down on the frame to make sure the front tire will clear the pipe. Alternator belt tensioner installed. It will be spring loaded.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5197_zpshyol2vvx
Pipe bends out away from alternator.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5198_zpsc9vrewgr
As of now the throttle is partially done. It rained this weekend so no painting yet. Might be able to paint a few small parts inside this afternoon. I'll get things ready for painting during the week.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5196_zpsplnjibl6
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 22nd 2016, 6:18 pm
Manifold and snorkel arangement.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5200_zpsazjzu6b6
Transmission out to modify the high/low range shifter, which I forgot about. Throttle pedal installed. Intake manifold just needs a bracket to hold the cable and return spring.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5201_zpszshgl49s
High/low shifter in it's new location. Torched a hole through the top of the frame. It's a semi tight fit between the battery and belt guard, but you should be able to use it. Original location was maybe 3-4" forward. I only remembered that I never put the lever back in when I saw it looking for something else.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5202_zpsnjp0p4q2
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 22nd 2016, 11:02 pm
Haven't had much time for taking video, but here's a quick walk around of the machine in it's current state.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 24th 2016, 9:57 pm
Taped up one of the front wheels and painted gloss black.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5213_zpsqwfqkais
Grill primed grey. As of now the grill is painted white, hood painted orange, and some other small parts painted black. Brake linkage rods, carb brace, exhaust pipe, alternator belt tensioner, and drive belt guide. This weekend should see the frame painted and then the start of assembly for Haspin.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 IMG_5212_zpssr4tyaav
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 8 Icon_minitimeMay 25th 2016, 11:45 am
Looks good. Looking forward to how the paint it turns out.
Page 8 of 22Go to page : Previous  1 ... 5 ... 7, 8, 9 ... 15 ... 22  Next
» TSCUSTOMS Dirty Burban [2016 Build-Off Finalist]
» Tractorhead's Roper Romper [2016 Build-Off Finalist]
» Chase Towns's Daisy FMC [2016 Build-Off Finalist]
» Maine Mud Mower's "Not the Norm" [2016 Build-Off Finalist]
» redzz02 Drift Missile [2016 Build-Off Finalist]
