 Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]
mowerjunkie03
tater195
Crafty
TedTheDestroyer
sadeoo7
rarbaugh07
rstolz
STUNTMAN JON
MasonMcK
redzz02
tscustoms
Rockinator
cablguy2
40 posters
Go to page : Previous  1 ... 9 ... 14, 15, 16 ... 18 ... 22  Next
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Empty
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 12th 2018, 10:32 pm
Nice machine work on the head. i’ve seen a lot of people either running heavier weight oil or diesel engine oil in their small engines. Why did you decide to go with a heavier oil?
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 12th 2018, 10:39 pm
Most likely to take up the clearances in this older engine. I think it’s getting close to retirement from what I understand. Maybe at the end of the summer?
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 12th 2018, 11:42 pm
Thanks and yeah, just went with a bit heavier stuff this time because I'll be at haspin running for hours in the heat. Figured go a tad thicker than usual. It doesn't seem to use much oil or smoke, but it has a lot of hours on it from when it was on the walk behind mower it used to power.
My eventual plan for after haspin is to build an I/C engine and use a pumper carb like a tillotson. Something that won't dump gas out the vent every time there's a little vibration. When I changed the oil after haspin last time and also recently this time, I noticed aluminum filings in the oil. Not heavy flakes or anything, just very fine aluminum mixed in. This time is wasn't that heavy, but it had less run time between changes this time. I think some is normal but I'd rather not see much at all. I think most of it probably comes from the cylinder wall. It's also possible that my previous airbox issues let some haspin dust through in 2016 which may have accelerated cylinder wear a bit.
From what I can see above the piston today with the head off, it's fairly well worn but no serious gouges. The original cross hatching is barely visible in places. The spark plug was pretty decent, no serious carbon build up from burning a lot of oil. So I don't think anything is going to change really quick with that. The extra compression from the new head may be a little harder on things, but we'll see.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 13th 2018, 12:20 pm
Nice milling work on the head. That should improve the performance of the Briggs.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 13th 2018, 8:14 pm
Thanks. Hopefully gain at least a little bit. Either way, it's just cool to try it.
An 8hp head is almost the biggest one I can fit in my mill. Just because there's not much more travel to the table.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 14th 2018, 9:01 pm
Greased all the joints and oiled up everything. Did a short test run to try things out and the jackshaft brake works perfect. It will go right into gear if you hit it before shifting. Only issue is the band broke where I had it bolted together. But I have a wider piece to use so all I need to do it cut another band to the right size and it should hold together this time. The brakes work 100% better with the flat side of the belt on the hub too. Everything seems to be good to go.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Img_6695
Have it back at home now and I might take it to a swap meet to ride around on saturday just to test things a bit further before haspin.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 14th 2018, 9:10 pm
Hey how do those band/belt brakes work when wet? Dunno if this was asked awhile ago but I’m kinda curious
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 14th 2018, 9:23 pm
Very nice!  Can't wait to see the video at haspin tearing it up!
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Sig115PROJECTS:
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Sig214Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Sig314
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 16th 2018, 3:29 pm
Previously I didn't notice much performance issues with the brakes when wet. Maybe a different story with the flat side down but who knows. I was happy with the extra stopping power, they work way better this way. As good as any brakes I would say. We'll have to see how they go on hills.
And thanks mightyraze, I'll be trying to get as much footage as I can!
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 16th 2018, 6:22 pm
Good to hear that your shifting woes are over Wink Should be good fun at Haspin.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 16th 2018, 7:20 pm
Yeah I think it should work really good, especially once I get used to it. I should have done that a long time ago, just never got to it. Now all the temporary stuff I had rigged up for haspin 2016 is finally fixed up. Only things I would still like to add is a back up light and maybe a 12 volt outlet in the dash. And it needs a small tool box somewhere. Maybe under the seat opposite of the battery, there's some space there.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 16th 2018, 7:23 pm
Sweet deal! Definitely looking forward to seeing some pictures and videos of the Haspin riding.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 16th 2018, 8:31 pm
Same, can't wait!
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 17th 2018, 4:44 am
a M60 ammo can would work well on the otherside of your seat
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 18th 2018, 11:50 pm
Thanks guys and yeah an ammo box would be great on the other side. Only issue is I think they are a bit too tall to fit under the seat. And probably even if it fit, the lid swinging open wouldn't clear too well either. I may eventually have to make my own box if I can't find anything else. But one way or the other, I really do need a permanent spot for a tool kit, even if it's just basic stuff.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 19th 2018, 12:27 am
Looking good as always. What engine is it?
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 19th 2018, 8:08 am
I'll try to find a picture, on my old utility trailer i had a 25mm can on it to hold straps and stuff. It was to tall so I cut it down and welded the bottom back on and it had 2 latchs, i converted it to hold downs so I didn't need 5" on each side to open the lid
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 19th 2018, 6:31 pm
Thanks. Muckmudd, the engine is a 7hp briggs and stratton originally. I call it an 8hp because that's what all the newer ones are.
Buck mault, sure if you can find a pic that would be good. Sounds like a good idea to convert the lid.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 19th 2018, 7:47 pm
Yeah it looked a little small to me but If it works it works. Just wasn't too sure if it kinda sunk into the frame.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 20th 2018, 12:33 am
It is a bit under powered yeah. But it gets the job done. Steep hills require crawling up in 1st gear low range. If I ever decide to build a Simplicity Adventure II, I'll go with a bigger engine.
Here's a video review of all the latest mods.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 30th 2018, 1:42 am
Picked up this old sears suburban for more parts. It has the correct spindles and all that stuff for the simplicity.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Img_6734
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Img_6733
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 30th 2018, 6:16 am
Nice, it's always good to have spare parts Wink Could put that Teccy on the Simplicity to give her more oompphh if the mounting holes were the same.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 30th 2018, 9:23 am
please send me the tranny!!!!!
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 30th 2018, 10:10 am
Those engines are heavy though mattD, cast iron block. I think a lot bigger too. Actually, the guy who gave it to me wants the engine and wheels back. I always get stuff from him, he's got all kinds of mower stuff. He had a few suburbans but now he's clearing out some of his older stuff.
And bigasmowers, I need the trans!
Actually I was thinking I could build a second simplicity if I ever found another one to get parts from. Who knows though.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 30th 2018, 10:35 am
One of our big mods last year was back up lights on all the tractors, gets mighty dark in them woods!
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 15 Icon_minitimeMay 30th 2018, 10:36 am
Yeah that would definitely be cool to see!
Page 15 of 22Go to page : Previous  1 ... 9 ... 14, 15, 16 ... 18 ... 22  Next
» TSCUSTOMS Dirty Burban [2016 Build-Off Finalist]
» Tractorhead's Roper Romper [2016 Build-Off Finalist]
» Chase Towns's Daisy FMC [2016 Build-Off Finalist]
» Maine Mud Mower's "Not the Norm" [2016 Build-Off Finalist]
» redzz02 Drift Missile [2016 Build-Off Finalist]
