| trany whine | |
mudman604 Member
Age : 26 Join date : 2014-12-03 Points : 3778 Posts : 110 Location : hudson FL
| Subject: trany whine December 14th 2015, 3:29 pm | |
| so, Im back after some time, and the reason, is interesting. a weekend ago, i broke my tractor, i found the left wheel about 4-5 inches out more than it should, the double C clips came off and let it slide out, the weedless locker still held, cus i drove it before i realized the problem. i take it apart, weld the gear to the axle, find some nice scoring in a non bearing area, any way, RTV it, let it dry, put ABOUT 20 oz of gear oil, cuz there was some surprising amount of where marks in other places, and put it in. NOW it drives fine, but there is a loud whine to it that was not there before. it only happens when the engine is driving, if im at speed, clutch IN (engaged IDK which is which) i get the whine, BUT if i pull out the clutch, and coast, its quiet. i do think there is a little bit of internal pressure due inserting the plug, but i cant figure it out. what could be causing this? | |
| Subject: Re: trany whine December 14th 2015, 7:09 pm | |
| Not sure why it would make more noise now than before. Maybe a shaft or something warped slightly from welding. As long as everything turns easy though, I don't think it would be anything to worry about. | |
| | | mudman604 Member
| Subject: Re: trany whine December 21st 2015, 8:28 am | |
| IDK, iv been driving it every once in a while, and nothing wrong. i might be getting used to it. the only thing i welded the spider gear to the shaft, tacking it 3 times, then finishing up the beads. but it works perfect. but hey, only tell tail is time! | |
| | | rarbaugh07 Member
Age : 36 Join date : 2014-01-22 Points : 4074 Posts : 117 Location : Logan, iowa
| Subject: Re: trany whine December 22nd 2015, 3:18 pm | |
| Did you switch from grease to gear oil? | |
| | | | | trany whine | |
| Who is online? | In total there are 36 users online :: 0 Registered, 0 Hidden and 36 Guests
