 Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.
Moose
donaldcon
TedTheDestroyer
11 posters
Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Empty
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeFebruary 17th 2016, 4:54 pm
If its not fluorescent pink im going to be disappointed.
Moose
Moose
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeFebruary 22nd 2016, 3:08 pm
Green :V like Od green
Braden.H
Braden.H
PostSubject: Can't wait   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMarch 30th 2016, 9:32 pm
This is awesome I can't wait I have been building a wheel horse 211-3 Rock crawler and I can't wait to test it out and hang out if any body has more information on it let me know and I would love to meet some of you guys be for we get there so if and body is going g please let me know
Braden.H
Braden.H
PostSubject: Speed   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMarch 30th 2016, 10:10 pm
okay I need help how do yall make your mowers go so fast I need some tips and advice please help
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMarch 31st 2016, 9:54 pm
Click on the links below in my signature.
Braden.H
Braden.H
PostSubject: Can't wait   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeApril 1st 2016, 10:41 am
Do you guys only meet once a year
donaldcon
donaldcon
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeApril 1st 2016, 4:04 pm
Braden. We ride in ohio once a month. The mowrons join us occasionally too.
There is alot to making a tractor go fast safely. I'd suggest staying under 20mph unless lowered with upgraded steering.
You should be able to achieve that with a larger engine pulley, could also go smaller trans pulley but that could lead to belt slippage
Braden.H
Braden.H
PostSubject: Thank you   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeApril 1st 2016, 11:01 pm
Thank you for the advice
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeApril 2nd 2016, 7:39 am
Haspin is once a year.
Braden.H
Braden.H
PostSubject: Thank you   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeApril 2nd 2016, 7:50 am
OK so do you guys meet at haspine once a year but in Ohio annually
Braden.H
Braden.H
PostSubject: Ideas   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeApril 2nd 2016, 11:53 am
Ok so I am building a rock crawler Mower for haspine if any one has advice it will help thank you
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeApril 4th 2016, 9:41 am
Braden, here's our Haspin tractor recommendations from earlier in the thread... enjoy!
Stretch44875 wrote:
On to mowers.  Ours have been built over the years to handle this park, and even after years of mods, they still break.
Some recommendations for mods... Nothing is required, but you will have a lot more fun!:
Speed.  Even though ours go 45, we rarely go fast at haspin.  We'll do some drag races on the dirt drag strip, but if you can do 10-15 mph, you'll keep up just fine on the trails.
Bumpers/tow hooks.  Ours are a little low on the front sometimes.  But to be able to grab the hoop on the front and lift/pull, or to be able to push each other out is great.
Belt keepers.  You can find more about our gate style keepers in the builds listed in my signature.
Foot or hand throttles without governors.  This is a personal preference, others keep the governors and do just fine.  We've had issues where the governor would give full throttle attempting to maintain rpm on a steep hill, causing a flip.  If you're good with your clutch you can control it.
Tie rods/spindles.  If you're not going crazy with jumps and hitting stuff, stock tie rods and spindles can last.  I recommend reinforcing the spindles with welded gussets, and using 1/2in tie rods.
Brakes.  We have upgraded to bigger brakes, but stock ones can work, you just need to keep them clean and adjusted.
Note on driving down hills - Use low gear at idle to slide down some of the steep stuff.  This will allow the rear end to spin some, so you have some control.  Also brakes are notorious for failing here, so save them for when you really need them.
Other Recommendations:
Starting.  We have both recoil and electric start on most of our machines.  I'd bring an extra rope, or an entire spare recoil assembly.  If using electric start, make sure you have a good battery.
Good tires.  ATV or AG tires do help, but we have some tractors with turfs that do fine.
Lights!  We go on night rides every night!  If your engine has a lighting circuit (most older briggs), that works pretty good so your battery doesn't get drained.  LED lights connected to the battery work as well.  Taillights help too.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Braden.H
Braden.H
PostSubject: thank you   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeApril 4th 2016, 9:45 am
thank you so much this will help a ton cant wait for haspine.
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMay 4th 2016, 10:58 am
Stretch and I are really ramping up the work to get ready for Haspin! Lots of bus upgrades and the typical huge pile of tractor maintenance... We have already scrapped the idea of having the jeep buggy or mini dozer there this year due to time constraints. How's everyone else as far as readiness? Just over a month to go!
Chaos Build
Haspin 2021 thread
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMay 4th 2016, 11:37 am
Baja sears is more or less ready to run, not gonna change much on that. Simplicity of course needs to be finished but should make it. I've heard rumors that Doug Fackler isn't going to have a running tractor and is possibly bringing alternative vehicles. Also heard Redlinemotorsports thinks he has something more important to do for June. Still need to look over the transport vehicle a bit, but everything should be ok.
donaldcon
donaldcon
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMay 4th 2016, 1:03 pm
My 2 tractors as well as my atv are good to go.
Depending on travel arrangements I might have a 4x4 truck there too.
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMay 4th 2016, 9:40 pm
Yea, gravely wont be done in time. Ill probably be bringing the MB200 and XT250. Might get a new camera camera to take pictures.
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMay 4th 2016, 10:25 pm
Rock on guys! Let me know if any of you are interested in T-Shirts, as I need to start thinking about getting an order in, and will need to know how many/what size.
Chaos Build
Haspin 2021 thread
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMay 5th 2016, 9:06 am
I just got the OK from the wife to go to this, so Im in, I need to change the oil in the wheel horse, and Ill be ready to ride! Ill be heading up with offroadohio
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMay 5th 2016, 6:03 pm
Id be down for a T, size L.
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMay 5th 2016, 9:06 pm
I already special ordered my simplicity T shirts before I knew you guys made haspin shirts. My T shirt budget for the year has already been used up!
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMay 5th 2016, 10:01 pm
No such thing. T shirts are life.
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMay 6th 2016, 9:00 am
Im doing a ton of rides, both truck and mower right around this event, so my budget will be totally busted. No T shirt for me. Sad
donaldcon
donaldcon
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMay 19th 2016, 7:12 am
So who is actually coming
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMay 19th 2016, 9:38 am
Stretch and I are, along with Stretch's son and one of his friends.
So that's 4 from North central Ohio.
Chaos Build
Haspin 2021 thread
PostSubject: Re: Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang.   Haspin 2016, June 8th-12th, Mowercycle(mowrons!) gang. - Page 3 Icon_minitimeMay 19th 2016, 5:07 pm
As long as nothing comes up. Myself, Doug, and my father should be there. Still the plan anyway.
Page 3 of 5Go to page : Previous  1, 2, 3, 4, 5  Next
»  Haspin 2017, June 7th-11th, Mowercycle (mowrons!) gang.
» Haspin 2018, June 6th-10th, Mowercycle (mowrons!) gang. [ATLTF Official Event]
» Heads up: Mower cycle gang at Haspin 2013
» Meet the mowrons, of the mowercycle gang! (Video)
» Haspin 2014! June 11th - 15th
All-Terrain Lawn Tractor Forum :: Community Networking :: Social Events & Scheduled Events :: Past Events-
