| | Rear Engine Rider | |
Bigal Member
![Bigal](https://2img.net/u/2812/37/66/46/avatars/268-67.jpg)
Join date : 2012-02-04 Points : 4672 Posts : 56 Location : ME
![Rear Engine Rider Empty](https://2img.net/i/empty.gif) | Subject: Rear Engine Rider April 7th 2015, 3:58 pm | |
| I have a rear engine toro and would like some idea, pictures, or comments on what to do with it. Thanks | |
| ![Go down](https://2img.net/i/empty.gif) | | LAWN MOWER MUDDER Established Member
![LAWN MOWER MUDDER](https://2img.net/u/2812/37/66/46/avatars/825-65.jpg)
Age : 23 Join date : 2013-04-08 Points : 5135 Posts : 913 Location : Central Pa
![Rear Engine Rider Empty](https://2img.net/i/empty.gif) | Subject: Re: Rear Engine Rider April 7th 2015, 4:14 pm | |
| Does your toro have a peerless 700 and chain drive axle? If it does I'd totally change sprockets, lower it, steering, brakes, and make it go fast. Or just a general offroad rig with ATV tires, mild gear change, and reinforced stuff like frame and steering.
Show us some pictures of it. | |
| ![Go down](https://2img.net/i/empty.gif) | | Bigal Member
![Rear Engine Rider Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | crafsmankiller Member
Age : 26 Join date : 2012-10-18 Points : 4819 Posts : 412 Location : livingston texas
![Rear Engine Rider Empty](https://2img.net/i/empty.gif) | Subject: Re: Rear Engine Rider April 7th 2015, 6:39 pm | |
| I have one kinda like that.. word of advice, dont let the chain get loose. If it falls of itll most likely twist and then itll brake soon after that . | |
![Rear Engine Rider Empty](https://2img.net/i/empty.gif) | Subject: Re: Rear Engine Rider April 7th 2015, 7:14 pm | |
| Good tip. I havent road mine in a long time. It came with a 8hp briggs and it has showed its better days. So im planning on putting a 11hp from my tractor in my profile pic. In this toro. I perfer this this toro better. Its still stock and i just want to start on a clean slate, because of the many screw ups on my craftsman. | |
![Rear Engine Rider Empty](https://2img.net/i/empty.gif) | Subject: Re: Rear Engine Rider April 7th 2015, 8:32 pm | |
| Youll also find the rer drive better/are more fun to drive then a regular mower. You might want to put carrier bearing on the axle on each side of the differential to support the axle.
And those 8hp flatheads are rreally hard to kill. Mine burns more oil than gas and it still runs. | |
![Rear Engine Rider Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Rear Engine Rider | |
| Who is online? | In total there are 132 users online :: 1 Registered, 0 Hidden and 131 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
