| rear engine racer | |
Yard Ape New Member
Age : 28 Join date : 2015-02-23 Points : 3592 Posts : 19 Location : homer city pa
| Subject: rear engine racer Tue Aug 04, 2015 9:19 pm | |
| i plan making this '90s rer a racing mower with solid 3/4 inch axle. remove vertical shaft engine and use a horizontal shaft engine (side shaft). droping front axle to make it sit level. clean frame and body sand and paint it metallic. 10x4-4 tires all around. upgrade steering and new brakes. foot throttle. tether kill switch. custom straight pipe exhaust. [img] [/img] [img] [/img] | |
| Subject: Re: rear engine racer Wed Aug 05, 2015 1:49 pm | |
| Should be neat, not too much rear engine stuff around. | |
| | | Doc Sprocket Site VIP
| | | | Yard Ape New Member
| | | | LAWN MOWER MUDDER Established Member
| Subject: Re: rear engine racer Thu Aug 13, 2015 10:09 pm | |
| Looks good so far man! Can't wait to see the finished product! | |
| | | MatthewD Veteran Member
| Subject: Re: rear engine racer Mon Aug 17, 2015 6:40 am | |
| Neat! What engine are you using? Cool tires! Wouldn't 4" rims be a little small? Maybe not. | |
| | | jonnya Member
Age : 49 Join date : 2014-08-19 Points : 3860 Posts : 95 Location : Norfolk, England, UK
| Subject: Re: rear engine racer Wed Sep 02, 2015 1:22 am | |
| I'm looking forward to following your build, looks fun. It's in a similar vein to my build, mine staying ratty though. You found an engine for yours yet? | |
| Who is online? | In total there are 29 users online :: 1 Registered, 0 Hidden and 28 Guests torgoMost users ever online was 412 on Sat Jan 07, 2023 6:59 am |
