 B@S oppy help
5 posters
mudman604
B@S oppy help Empty
PostSubject: B@S oppy help   B@S oppy help Icon_minitimeMarch 15th 2015, 7:07 pm
i say a post on this before, cant find it now, but i got a twin that runs on one cylinder. the other one will some times fire, ive switched plugs, and done some testing with disconnecting the boots. so what i found is the RC (right cylinder) does not fire. now, i get it running, and some times i can take the boot of the RC, and nothing changes, but some other times, the whole engine will die. and the LC will always kill it. its obvious its not firing on the RC SOMETIMES. some times i will adjust it to run rich, and when i rev it, i get black smoke out both sides, or when at full throttle, it will some times run smooth, and sometimes not as smooth. it is the magneto right? i read that they do that sometimes?
B@S oppy help Empty
PostSubject: Re: B@S oppy help   B@S oppy help Icon_minitimeMarch 15th 2015, 7:19 pm
The magneto fires EVERY revolution, and sends spark to both plugs. Therefore, each cylinder gets spark on both the compression and exhaust cycles. If one is getting intermittent spark, most likely candidate is a bad plug wire.
If not the wires or plugs, check compression on intermittent cylinder and see if a valve is leaking or hanging.
mudman604
B@S oppy help Empty
PostSubject: Re: B@S oppy help   B@S oppy help Icon_minitimeMarch 15th 2015, 7:40 pm
it gets good compression on both cylinders, by hand that is, i don't have a tester. ill check the wire thought, if i dont find any thing, i will swap a mags between my fun motor and this new work motor.
B@S oppy help Empty
PostSubject: Re: B@S oppy help   B@S oppy help Icon_minitimeMarch 15th 2015, 7:42 pm
Inspect the insulation very carefully. If any cracks are found, wrap wire with 2-3 layers of electrical tape. That will buy another season or two of use.
mudman604
B@S oppy help Empty
PostSubject: Re: B@S oppy help   B@S oppy help Icon_minitimeMarch 15th 2015, 8:26 pm
thx
mudman604
B@S oppy help Empty
PostSubject: Re: B@S oppy help   B@S oppy help Icon_minitimeMarch 16th 2015, 8:31 pm
nothing wrong with wires, the mag was a bit rusty thought, here is the new thing i found, when running at idle, i runs on left cylinder, if i disconnect ether spark wires from plugs, the engine dies. if i fully choke it at idle, it starts to die, then it starts running on the left cylinder. (rather nicely) if i adjust the jet to run rich, it runs on left, lean, on right. at full throttle, it will sometimes run on both. i checked the manifold and valve, it opens what would seen to be a good amount to run fine. WTF! could i be the carburetor?
B@S oppy help 2429134702 B@S oppy help 2429134702 B@S oppy help 2429134702 B@S oppy help 2429134702 B@S oppy help 2429134702 B@S oppy help 2429134702 B@S oppy help 2429134702 B@S oppy help 2429134702 B@S oppy help 2429134702 B@S oppy help 2429134702 B@S oppy help 2429134702 B@S oppy help 2429134702 B@S oppy help 2429134702 B@S oppy help 2429134702 B@S oppy help 2429134702
B@S oppy help Empty
PostSubject: Re: B@S oppy help   B@S oppy help Icon_minitimeMarch 17th 2015, 10:24 am
Buy new plugs and go from there. I suspect it is still a ignition problem, coil might be bad
802 Customs
802 Customs
B@S oppy help Empty
PostSubject: Re: B@S oppy help   B@S oppy help Icon_minitimeMarch 17th 2015, 1:32 pm
I'd say replace the plugs w/ champion RJ19LM, if you find a damaged plug wire NGK makes a plug wire splicer for around 9 bucks I believe, but at that point you need more plug wire and a boot so it may be cheaper to replace the coil if you don't have wire and a boot lying around. The splicer works well, I used it on a snowmobile and it still works great.
New coil: http://www.amazon.com/Oregon-33-345-Ignition-Replacement-Stratton/dp/B0009XHKDS/ref=sr_1_1?ie=UTF8&qid=1426616985&sr=8-1&keywords=394891
NGK plug wire splice: http://www.amazon.com/NGK-J-1-Racing-Cable-Splicer/dp/B0018JXIXI/ref=sr_1_1?ie=UTF8&qid=1426616913&sr=8-1&keywords=ngk+plug+wire+splicer
B@S oppy help Empty
PostSubject: Re: B@S oppy help   B@S oppy help Icon_minitimeMarch 17th 2015, 6:09 pm
It might be worth inspecting (replacing?) your intake manifold gaskets. A vac leak could cause similar mayhem.
802 Customs
802 Customs
B@S oppy help Empty
PostSubject: Re: B@S oppy help   B@S oppy help Icon_minitimeMarch 17th 2015, 7:39 pm
A little rtv silicone would do the trick.
98svtcobra
B@S oppy help Empty
PostSubject: Re: B@S oppy help   B@S oppy help Icon_minitimeMarch 18th 2015, 10:14 am
While everything that has already been mentioned is right, when we had intermittent misfire issues like you described it was a coil replacement and new plugs that saved the day.
mudman604
B@S oppy help Empty
PostSubject: Re: B@S oppy help   B@S oppy help Icon_minitimeDecember 22nd 2015, 7:05 am
YOU GOT IT DOC!! it was awhile ago, and IDK why i did nit reply earlier, but it was the gaskets.
B@S oppy help Empty
B@S oppy help
» B&S 18 HP Oppy Questions
» 18hp oppy?
» 42 c.i. oppy carb
» Realistic max rpm for 18.5 oppy with few mods? Save me from myself!
» Briggs Oppy foot throttle with governor
