| 930 vs 205 gearing. | |
Jamus Established Member
Age : 45 Join date : 2010-06-28 Points : 5800 Posts : 511 Location : Southern WV
| Subject: 930 vs 205 gearing. December 5th 2014, 10:39 pm | |
| Would the gearing from a peerless 930 (rear steer by the way) match a MST-205? I know they are similar. I'd like to build a 4wd but don't have identical matching transaxles. | |
| | | Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7776 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: 930 vs 205 gearing. December 5th 2014, 11:31 pm | |
| I dont believe so. However, the spiders are the same on the rear axles. Meaning, find two matching 205 transaxles, swap the 930 axles into one of the 205s and viola. Or find another 930. MSTs are better though, IMO. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
Age : 23 Join date : 2013-04-08 Points : 5203 Posts : 913 Location : Central Pa
| Subject: Re: 930 vs 205 gearing. December 6th 2014, 1:11 pm | |
| Maybe you don't have to find another axle. All you need is to have the same gear ratios in each of them. Open 'er up and start counting teeth, if they don't match you may be able to find a parts tranny and just swap in the gears and the final drive so that they are the same... | |
| | | Doc Sprocket Site VIP
| Subject: Re: 930 vs 205 gearing. December 6th 2014, 3:58 pm | |
| - LAWN MOWER MUDDER wrote:
- Maybe you don't have to find another axle. All you need is to have the same gear ratios in each of them. Open 'er up and start counting teeth, if they don't match you may be able to find a parts tranny and just swap in the gears and the final drive so that they are the same...
Yep. All the common trannies were available with multiple gearsets. Whether you end up with a match, is a total crapshoot. Unfortunately, the 900 series uses different gears than the MST series, so remember that when sourcing donor boxes. | |
| Subject: Re: 930 vs 205 gearing. December 7th 2014, 10:00 am | |
| I didn't think it would be that easy, haha. Thanks guys. To add to the mismatch, the 205 is a 5-speed obviously, and the 930 is a 6-speed. I had seen where Puppetkicker on youtube used a 205(or 206) with the steering knuckles off the 930 to match gearing. | |
| | | Doug Site Owner
| Subject: Re: 930 vs 205 gearing. December 7th 2014, 3:14 pm | |
| Puppet did what I mentioned. He swapped the axle shafts. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
