 Hi guys newbe :) Need help gearing :)
mrpinhead11
6 posters
mrpinhead11
Hi guys newbe :) Need help gearing :) Empty
PostSubject: Hi guys newbe :) Need help gearing :)   Hi guys newbe :) Need help gearing :) Icon_minitimeFri 08 Feb 2013, 10:01 pm
alright guys so i have a craftsman dlt3000. the only mods i have done are a bumper and big mud tires. it has a 6 speed tranny and a 18.5 briggs Smile i want to change the pulleys so it will run around 15 to 20. i only wanna change the tranny pulley though. any ideas on what size i should get for the tranny pulley? thanks, Brandon
PostSubject: Re: Hi guys newbe :) Need help gearing :)   Hi guys newbe :) Need help gearing :) Icon_minitimeFri 08 Feb 2013, 10:04 pm
1:1 is a good ratio, only thing is dont go smaller then 3" trans pulley - the belt wont have enough wrap around it to spin it correctly.
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: Hi guys newbe :) Need help gearing :)   Hi guys newbe :) Need help gearing :) Icon_minitimeFri 08 Feb 2013, 10:07 pm
Thats the problem i have on my lawn tractor, the belt will just slip, at first i thought the belt was loose but then you can see the belt slipping on the pulley.
http://www.stat10.tk/
Chopperhed
Chopperhed
PostSubject: Re: Hi guys newbe :) Need help gearing :)   Hi guys newbe :) Need help gearing :) Icon_minitimeFri 08 Feb 2013, 10:12 pm
Welcome to the forums.
What size pulleys do you have?
mrpinhead11
PostSubject: Re: Hi guys newbe :) Need help gearing :)   Hi guys newbe :) Need help gearing :) Icon_minitimeFri 08 Feb 2013, 10:17 pm
im not sure what the pulley sizes are now. they're stock, thats all i know. im gonna take a guess and say the fronts a 4 and the rear is a 10ish? i just wanna go about 15 mps thats all
PostSubject: Re: Hi guys newbe :) Need help gearing :)   Hi guys newbe :) Need help gearing :) Icon_minitimeFri 08 Feb 2013, 10:19 pm
If you want around 15mph a 1:1 is the way to go.
mrpinhead11
PostSubject: Re: Hi guys newbe :) Need help gearing :)   Hi guys newbe :) Need help gearing :) Icon_minitimeFri 08 Feb 2013, 10:21 pm
alrighty thanks Smile is there any equation to find out what belt size i use or just use a rope around where the belt would run? oh anyone know what size the output shaft on the tranny is?
PostSubject: Re: Hi guys newbe :) Need help gearing :)   Hi guys newbe :) Need help gearing :) Icon_minitimeFri 08 Feb 2013, 10:33 pm
Its hit or miss. I know most Peerless transaxles I have swapped ran 5/8, while MTD FNR transaxles used 1/2" bore.
You could try this, CornishMorgan sent me it although I havent used it yet. http://www.baumhydraulics.com/calculators/belt_length.htm
A rope would work too. FearlessFront has a tutorial on how to do it.
mrpinhead11
PostSubject: Re: Hi guys newbe :) Need help gearing :)   Hi guys newbe :) Need help gearing :) Icon_minitimeFri 08 Feb 2013, 10:34 pm
yeah i bet its a 5/8 Smile ill just do the rope. i saw the vid, it was very helpfull
Murray modder
Murray modder
PostSubject: Re: Hi guys newbe :) Need help gearing :)   Hi guys newbe :) Need help gearing :) Icon_minitimeSat 09 Feb 2013, 1:30 pm
If your tractor is a twin, (please be a twin) Then you have about the same year as me, and it IS a 1/2
» 930 vs 205 gearing.
» Gearing a F-N-R
» What Pulley ratio should i use for running bigger tires?
» Gearing for 74 Murray question
» Horsepower vs Gearing, how much speed is possible?
