| need help with wiring | |
Madmowers New Member
| Subject: need help with wiring November 16th 2014, 4:31 pm | |
| I rewired my mower the fearless front way but when I push my start button I hear the sillonoid click and nothing happend any ideas on what's wrong | |
Join date : 2012-12-21 Points : 6546 Posts : 2101 Location : Norway, Europe
| | | | Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7321 Posts : 2914 Location : Ontario Canada
| Subject: Re: need help with wiring November 16th 2014, 6:30 pm | |
| We're definitely going to need more information in order to be of ANY help to you. | |
Age : 28 Join date : 2013-04-10 Points : 5764 Posts : 1408 Location : Galway NY
| Subject: Re: need help with wiring November 16th 2014, 7:05 pm | |
| sounds like you have a bad starter. or bad connection, or even an incorrect connection
| | | ratcatcher Member
Join date : 2014-04-10 Points : 3923 Posts : 32 Location : essex, UK
| Subject: Re: need help with wiring November 16th 2014, 9:55 pm | |
| firstly, try putting a screwdriver across the two terminals on the solenoid, if you are still getting the same "click" then it's your battery that is at fault, flat or under powered? or bad earth if holding the screwdriver across starts the mower, then it's the solenoid at fault, just buy a replacement | |
| Subject: Re: need help with wiring November 16th 2014, 10:22 pm | |
| If the solenoid clicks, your wiring is correct uo to that point. Now.... on the solenoid is two large terminals. One should go to battery positive, the other to the starter. Correct? Othe then that, make sure your negative cable from the battery to the frame has a very good connection. If that all checks out, then its likely the solenoid or the starter.
To test the solenoid, short the two big terminals together witha screwdriver. If engine now cranks, solenoid bad. If no change, then its not likely the solenoid.
To test the starter, grab a booster cable, and connect one end to battery positive. Now, with the clamp on the other end of that booster cable, tap the lug on the starter. If engine cranks, starter good. | |
| Subject: Re: need help with wiring November 16th 2014, 10:42 pm | |
| - Doc Sprocket wrote:
- To test the starter, grab a booster cable, and connect one end to battery positive. Now, with the clamp on the other end of that booster cable, tap the lug on the starter. If engine cranks, starter good.
make sure the starter is either on the engine, or grounded with the other clamp. to ground it, clamp the neg to the battery, and the other end onto the mounting plate of the starter, with the positive, connect to batt positive and tap the lug on the starter, like doc said | |
| | | ratcatcher Member
| Subject: Re: need help with wiring November 17th 2014, 5:43 am | |
| ok, I get it, no point in the brit trying to help, my advice just repeated twice and no need for that extra information either | |
| Subject: Re: need help with wiring November 17th 2014, 6:51 am | |
| - ratcatcher wrote:
- ok, I get it, no point in the brit trying to help, my advice just repeated twice and no need for that extra information either
Ahh, don't worry about it. Even with the repetition, it's helpful. SOmetimes folks word things differently, and perhaps something one of us says (even if it's fundamentally the same thing) will get the job done. | |
| Subject: Re: need help with wiring November 23rd 2014, 4:33 pm | |
| I put a screwdriver across the terminals and nothin happend I'm thinking it's the ground I had a booster box hooked to the battery cables but when the screw driver crosses the terminals I don't hear a click | |
| Subject: Re: need help with wiring November 23rd 2014, 5:29 pm | |
| - Madmowers wrote:
- I put a screwdriver across the terminals and nothin happend I'm thinking it's the ground I had a booster box hooked to the battery cables but when the screw driver crosses the terminals I don't hear a click
try putting the booster right onto the starter. positive on the lug and the ground onto the frame somewhere. make sure the metal is free of paint and rust. when you cross the terminals, it wont click, because youre bypassing the guts of the solenoid. | |
| | | | Carshowkid Member
Age : 25 Join date : 2014-07-22 Points : 4174 Posts : 347 Location : Downers Grove Illinois
| Subject: Re: need help with wiring November 23rd 2014, 11:46 pm | |
| - Madmowers wrote:
- It will start if I hook it straight to the starter
so I think if I understand correctly... Means you got a bad solenoid | |
| Subject: Re: need help with wiring November 24th 2014, 1:23 am | |
| sounds to me like a bad cable or bad connection somewhere. go over everything with a fine toothed comb. i would get a tube of di-electric grease and grease all the major connections. | |
| | | ratcatcher Member
| Subject: Re: need help with wiring November 24th 2014, 10:10 am | |
| it can be one of two things, your battery (not enough juice) or the solenoid, stop using the booster pack, as this is not helping to identify your problem
1st, try running a wire from your battery straight to the starter, does it then fire up?? if not it would be your battery at fault 2nd, hook your booster up to the solenoid now when you hit the button, does it fire up the mower, if yes, then you have proved your solenoid is ok, but not your battery if it wont fire up this way, then you know your solenoid is at fault | |
| Who is online? | In total there are 29 users online :: 0 Registered, 0 Hidden and 29 Guests
