 Alternator Wiring
2 posters
TheSirDjay
TheSirDjay
Alternator Wiring Empty
PostSubject: Alternator Wiring   Alternator Wiring Icon_minitimeDecember 7th 2016, 1:52 pm
I was just about finished with Fearless Front's simplified wiring system when I noticed two wires coming out from where the alternator should be. Should I hook the black to ground and the red to the solenoid or is it not meant for charging?
Alternator Wiring 04_xpv11
PostSubject: Re: Alternator Wiring   Alternator Wiring Icon_minitimeDecember 7th 2016, 5:38 pm
The red is your DC charge wire. Attach it to the battery terminal of the starter relay (solenoid). The black wire is actually an AC lighting circuit. It will give you 3-5A of AC current. Pretty much only good for incandescent lighting, and one of those arrangements where the slower your engine is spinning (like idle) the dimmer the lights. If you do not intend to use it, you can just leave it capped off.
TheSirDjay
TheSirDjay
PostSubject: Re: Alternator Wiring   Alternator Wiring Icon_minitimeDecember 9th 2016, 8:30 am
Thanks a lot! Now I can finish up the wiring! bounce
Alternator Wiring
» Car Alternator?
» GM Delco Alternator
» Briggs alternator PDF
» Alternator Issues - B&S 12HP
» Engine swap - alternator query
All-Terrain Lawn Tractor Forum :: Technical Forum :: Electrical Related Issues :: Wiring Systems-
