| Rear tow / Hitch plate | |
+17matt-man 1993-Sierra-Z71 Murray modder motorizedeverything Doug redlinemotorsportts richie thomas truckin42 Thunderdivine theswampmachine Sears 14/6 romper ydocnitsua6705 daylestoys Bigal dangeroustoys56 Jordan dugan978 21 posters |
truckin42 Veteran Member
| Subject: Re: Rear tow / Hitch plate April 22nd 2013, 1:09 pm | |
| - Thunderdivine wrote:
- I'ma make a Custom trailer for my JD, but that's way ahead.
Yeah i want to make a trailer for my mower but not right now. | |
motorizedeverything Member
Age : 26 Join date : 2013-01-02 Points : 4698 Posts : 356
Murray modder Member
Join date : 2012-11-23 Points : 4798 Posts : 356 Location : Somewher in Va
| Subject: Re: Rear tow / Hitch plate April 27th 2013, 10:06 am | |
not to get off subject, but that is probably the coolest picture Ive seen in awhile. The angle of that thing. | |
1993-Sierra-Z71 Member
Age : 30 Join date : 2013-05-09 Points : 4244 Posts : 29 Location : Central Wisconsin
| Subject: Re: Rear tow / Hitch plate August 19th 2013, 11:34 am | |
| I'm going to make a custom hitch modeled after a trucks. heavy angle iron on the inside side of the chassis and then a reverse drop hitch and then a 2 inch ball. this shows some good ideas for me to do it. | |
matt-man Member
Age : 27 Join date : 2013-07-26 Points : 4388 Posts : 221 Location : North Fort Myers, Florida
| Subject: Re: Rear tow / Hitch plate September 6th 2013, 10:43 pm | |
| I just drilled the center of mine out found a bolt long enough and just bolt it through the factory hole and I just unbolt it when I want to pull a garden trailer | |
Buck Member
Join date : 2017-11-01 Points : 2879 Posts : 282 Location : Eastern Ontario
Crazy_Carl Veteran Member
Buck Member
| Subject: Re: Rear tow / Hitch plate November 14th 2017, 3:09 pm | |
| not really factory i would be fired with my welding , the company would go broke with all the grinding disks i go through, i bouught the recever but built the mount. most of the things i built for the sears is bolt on.
Last edited by Buck Mault on November 14th 2017, 8:43 pm; edited 2 times in total | |
Buck Member
| Subject: Re: Rear tow / Hitch plate November 15th 2017, 7:36 am | |
| Honestly I don’t think those welds look that bad. Yeah there’s going to be spatter from the kind of rod or wire you’re using but your travel speed and bead size look pretty consistent.
I’m a big fan of bolt-on components too. I want to build a bolt-on bumper/receiver for both of my tractors. I have retirement dreams of restoring my C-81 30 or 40 years from now, and I’d much rather unbolt stuff instead of getting out the torches or grinder. | |
Buck Member
| Subject: Re: Rear tow / Hitch plate November 15th 2017, 11:10 am | |
| Nice , for this one its all bolt on but my other 74 sears I just picked up it going to be all weld on ( getting low on bolts lol ) | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5714 Posts : 1402 Location : Central PA
Buck Member
| Subject: Re: Rear tow / Hitch plate November 17th 2017, 2:31 pm | |
| Welds dont unbolt very easily. Never know, might decide you need something else put on there... like a potato cannon! | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5093 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: Rear tow / Hitch plate November 17th 2017, 8:17 pm | |
| What would be a good reason to have to put a potato cannon on there? I might have to use that reason someday. | |
