| Rear tow / Hitch plate | |
+17matt-man 1993-Sierra-Z71 Murray modder motorizedeverything Doug redlinemotorsportts richie thomas truckin42 Thunderdivine theswampmachine Sears 14/6 romper ydocnitsua6705 daylestoys Bigal dangeroustoys56 Jordan dugan978 21 posters |
dugan978 New Member
Join date : 2011-03-07 Points : 5021 Posts : 8 Location : Massachuestts,USA
| Subject: Rear tow / Hitch plate March 7th 2011, 6:14 pm | |
| i need a rear tow hitch plate i do not have the plate on the back and need to build one just something so i can attach a chain, lawn cart, and rope to id like to see a picture of what you have for a hitch | |
Jordan Member
Age : 30 Join date : 2010-10-03 Points : 5352 Posts : 170 Location : Ontario Canada
| Subject: Re: Rear tow / Hitch plate March 7th 2011, 7:49 pm | |
| i just mount a 1 7/8 ball on all my tractors on the stock hitch, and on one of them i have the bagger mount, so i can have a ball like usual but it also has a removable bar in it for chain, rope, or tow strap | |
| Subject: Re: Rear tow / Hitch plate March 8th 2011, 10:19 am | |
| On my White LT12 i reinforced the stock hitch area with a piece of 1/4" angle under it - i bolted it to the stock chassis bolts inside - ive hauled some serious weight with it. Heres one i got with a tractor years ago- i mounted it on my 96 MTD before i took it apart : It was made from a heavy piece of steel - on the MTD i just used two bolts to hold it on the tractor- i still have the hitch in my shed. My GTII also came with a heavy duty hitch . A lil bit of steel and some welding and you can make a good strong hitch. | |
Bigal Member
Join date : 2012-02-04 Points : 4743 Posts : 56 Location : ME
daylestoys New Member
Age : 27 Join date : 2011-09-12 Points : 4834 Posts : 8 Location : Thunder Bay
| Subject: hitch February 29th 2012, 7:11 pm | |
| You should make your own reese hitch thats what i am doing on my mud mower project. | |
ydocnitsua6705 New Member
Age : 32 Join date : 2012-05-25 Points : 4583 Posts : 17 Location : Virginia
Sears 14/6 romper New Member
Age : 25 Join date : 2013-04-20 Points : 4240 Posts : 8 Location : Kingston Mass
| Subject: Re: Rear tow / Hitch plate April 21st 2013, 12:05 am | |
| That seems like a pretty solid hitch I'm doing that soon to my tractor | |
theswampmachine Member
| Subject: Re: Rear tow / Hitch plate April 21st 2013, 1:11 am | |
| I just have a pintle hitch bolted into my back plate. It works fine for me. And holds alot of weight the front end will lift up before it bends the metal | |
Thunderdivine Veteran Member
truckin42 Veteran Member
richie thomas Veteran Member
| Subject: Re: Rear tow / Hitch plate April 21st 2013, 10:07 pm | |
| a peice of 1/4" diamond plate steel with a chunk of 1/2" fork lift blade welded onto it with 1/8" steel bracing, she aint going anywhere lol | |
| Subject: Re: Rear tow / Hitch plate April 21st 2013, 10:15 pm | |
| - richie thomas wrote:
- a peice of 1/4" diamond plate steel with a chunk of 1/2" fork lift blade welded onto it with 1/8" steel bracing, she aint going anywhere lol
Yeah that setup there can work too. | |
| Subject: Re: Rear tow / Hitch plate April 21st 2013, 10:23 pm | |
- it will hold anything that the lifted one will pull lol
Lol thats good. | |
| Subject: Re: Rear tow / Hitch plate April 21st 2013, 10:28 pm | |
| I don't use my hitch spot because I just hook everything to the bumpers haha | |
| Subject: Re: Rear tow / Hitch plate April 21st 2013, 10:30 pm | |
- I don't use my hitch spot because I just hook everything to the bumpers haha
Yeah i do the same thing. But i want to extend my hitch so i can pull stuff. | |
Doug Site Owner
| Subject: Re: Rear tow / Hitch plate April 21st 2013, 11:02 pm | |
| I use the stock hitch on the Rally. 3/16" thick with a flare at the hole works fine. I have a 1-7/xx" ball that fits it but no trailers with a tongue so I leave it off. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: Rear tow / Hitch plate April 21st 2013, 11:07 pm | |
| i used to use the stock one on my old murray, then it bent like straight dow when i pulled our smoker, so i was like, time for a upgrade lol wish i had kept that hitch | |
| Subject: Re: Rear tow / Hitch plate April 22nd 2013, 6:58 am | |
| Yeah we have a big heavy dudy hich and it like 10in long and its a simple design so i might modifiy it to fit my mower. | |
| Subject: Re: Rear tow / Hitch plate April 22nd 2013, 1:09 pm | |
| - Thunderdivine wrote:
- I'ma make a Custom trailer for my JD, but that's way ahead.
Yeah i want to make a trailer for my mower but not right now. | |
