It is the craftsman silver, and i was thinking about adding some black highlights... I was thinking the Silver Surfer or the Wrecker since i will use it as a tow truck... and about spongebob!
Silver surfer would be cool if it was really fast
Ghyde97 Member
Age : 26 Join date : 2014-09-09 Points : 3718 Posts : 63 Location : Jacksonville fl
So I locked my axle today using fearlesses method. Now when I turn the pully in 1st 2nd and sorta in 3rd I can spin in by hand using the pully but not at all by the axles. It is almost impossible to turn the pully by hand in the rest of the gears. Why would this be? The axles only move when you turn the pully not at all turning the tires or putting plyers on the axle. Could someone explain why this is?
Age : 23 Join date : 2013-04-08 Points : 5134 Posts : 913 Location : Central Pa
It is because of the gear ratios inside your transaxle. You can turn the input by hand but can't turn the axles by hand. Usually most transaxles are like that.
Ghyde97 Member
So that's normal and I shouldn't worry about it tearing up the transaxle. It's not a problem that it does that? So I shouldn't worry about it at all?
Ghyde97 Member
What I'm worried about is I can't turn the axles at all even in neutral? It is impossible to turn the axles even with tires on them I can't budge them.
Ghyde97 Member
I got my axle fixed and everything. Something in there was just binding up. Can anyone tell me what kind of axle I have. I know it's a 6speed oil filled pearless.
ZSmachines Member
Age : 25 Join date : 2014-08-27 Points : 3917 Posts : 221 Location : PNW
I did but since I have no clue about transaxles I had no clue of how to read it. I'll go take a picture of it and maybe someone can make some sense of it for me.
Ghyde97 Member
