| Craftsman/Kohler ABSolenoid | |
Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4416 Posts : 491 Location : Index, Washington
| Subject: Craftsman/Kohler ABSolenoid August 16th 2014, 3:49 pm | |
| Has anyone here dealt with the craftsman/kohler antibackfire solenoid? This is not your ordinary ABS which has a needle sticking out the end that you can just cut off. Here is a pic of the solenoid. Here is a repost of a drawing I made that kind of explains the solenoid. To explain... Most B&S carbs have a tube that goes up from the center of the bowl. There is a jet in there, that the needle from your ABS fits into. When the solenoid is activated, the needle is drawn down, allowing gas to enter the carb. When the power is turned off, the needle snaps back upward, and seals that jet, so no gas can enter the carb. Well, on this one, that jet is a part of the solenoid body. Here is another pic with the jet removed. I have several thoughts here, about what I could do. 1. I could get a bolt, and drill it. But then I'd have to have exactly the right length bolt. I'd have to drill it sideways for the gas to enter. Then I'd have to drill it lengthwise. Then I'd have to tap that hole for the jet. That's a bit more precision work than I'd like to do. 2. I could drill through this one, where the gas is supposed to enter. But I think the 'pin' in the middle is too large. I'd drill through, but the pin would still be there. 3. I could apply 12 volts. Then while the pin is in the retracted position, drill another hole, across, in a cross pattern with the original supply holes. And push as small a pin as I can, through that hole. Then cut it off flush, so I can screw the solenoid back in. Kind of liking option number 3 the best. It'll be difficult, but not as difficult as option 1. And not as permanent or damaging as option 2. If I ever want to go back to using the solenoid, all I have to do is remove my pin. Has anyone done anything different with this type? | |
| | | Angchor Member
| Subject: Re: Craftsman/Kohler ABSolenoid August 17th 2014, 12:46 am | |
| Ok, here is the solution I have gone with. What I did was to apply 12 volts to draw the pin back. Then I picked a drill bit that was a little bit smaller than a piece of 12ga romex copper wire. Drilled a hole in just one of the sides. Took a piece of the copper wire. Filed a point on it so it was like a nail. Then drove it into the hole I had drilled. Kept pounding until the copper had expanded and was good and stuck. Like a rivet, but it takes up a lot less room, so blocks less flow. Then cut the copper off flush. It's worth a try. I have no idea how soon I am going to be trying to start this engine again. When I do, I'll be trying this out. Reason for doing this is because I do not want to be relaint on having a battery on board. I'll have a battery, anyway. But the charging system on that engine does not work. If the battery runs down, I want to be able to either jump start it, or push start it, or recoil start it, and just drive it home. I figured this would be easier and cheaper than tearing apart the charging system and buying parts. LOL | |
| | | | Angchor Member
| Subject: Re: Craftsman/Kohler ABSolenoid August 17th 2014, 3:05 am | |
| was a couple years ago, but i think so, got a pic of the shroud? ill tell you if its the same engine | |
| | | Angchor Member
| Subject: Re: Craftsman/Kohler ABSolenoid August 17th 2014, 3:25 am | |
| - richie thomas wrote:
- was a couple years ago, but i think so, got a pic of the shroud? ill tell you if its the same engine
I think you had the other kind of solenoid. There is no way to "just cut this off". | |
| Subject: Re: Craftsman/Kohler ABSolenoid August 17th 2014, 4:39 am | |
| mine was the blacktop and a 16 hp, motor had amazing torque for a single, loved it, sold it about 6 months ago to a buddy | |
| | | Doc Sprocket Site VIP
| Subject: Re: Craftsman/Kohler ABSolenoid August 17th 2014, 8:00 am | |
| Been awhile since I had such a Kohler in my hands. Am I safe to assume that you could not simply remove the plunger entirely? Because when I come across this type here, it's a simple matter of opening it up and removing the plunger and spring. | |
| | | Angchor Member
| Subject: Re: Craftsman/Kohler ABSolenoid August 17th 2014, 4:30 pm | |
| - Doc Sprocket wrote:
- Been awhile since I had such a Kohler in my hands. Am I safe to assume that you could not simply remove the plunger entirely?
Thank you VERY much! You are safe to assume that. The picture you link is exactly the same solenoid. Howsomever... That is probably the original solenoid. And what I have must be the aftermarket version. It is made in such a way that it cannot be taken apart. | |
| | | | Ariens YT11 Established Member
Age : 27 Join date : 2012-10-31 Points : 5161 Posts : 745 Location : The Wyo-Braska Panhandle
| | | | Sponsored content
| Who is online? | In total there are 21 users online :: 0 Registered, 0 Hidden and 21 Guests
