| LT4000 Craftsman | |
+7Angchor Ariens YT11 kawasaki220 mr.modified Thunderdivine redlinemotorsportts Craftsman1998 11 posters |
richie thomas Veteran Member
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5146 Posts : 1068 Location : New jersey
| Subject: Re: LT4000 Craftsman August 5th 2014, 7:02 am | |
| - mr.modified wrote:
- Hood scoop or something? That flat hood looks like a good spot for something. Maybe leave the hood intact, but have some nifty stripes or graphics or something.
Yeah i could add a scoop but i dont know how i would do something like that. and i am going to repaint it but i'm not sure what colors or designs im going to use. | |
Age : 27 Join date : 2012-10-31 Points : 5158 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: LT4000 Craftsman August 5th 2014, 11:12 am | |
| make your own muffler or buy a cheap $7 Home depot muffler.
Age : 23 Join date : 2014-01-22 Points : 4565 Posts : 546 Location : north carolina
| Subject: Re: LT4000 Craftsman August 7th 2014, 1:48 pm | |
| ooo i like that did you widen it or is that stock | |
| Subject: Re: LT4000 Craftsman August 7th 2014, 5:08 pm | |
| - kawasaki220 wrote:
- ooo i like that did you widen it or is that stock
no i didn't widen it the axles on the transmission i bought were longer i guess | |
1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5440 Posts : 1311 Location : NW USA
| Subject: Re: LT4000 Craftsman August 8th 2014, 9:19 am | |
| the msts are nice and wide, arn't they? purfect for a racer. | |
B440 Member
Join date : 2014-01-22 Points : 4198 Posts : 226 Location : Thompson, CT
| Subject: Re: LT4000 Craftsman August 8th 2014, 11:54 am | |
| - 1997 Murray wrote:
- the msts are nice and wide, arn't they? purfect for a racer.
Yep the mst made it 9in wider than the stock hydro | |
| Subject: Re: LT4000 Craftsman August 8th 2014, 11:55 am | |
| - B440 wrote:
- Craftsman1998 wrote:
- http://www.amazon.com/V-Belt-Pulley-In-Bore-1GRV/dp/B00868CD4E
can i use a pulley like this for the front? Yes. That is exactly what I have for my front pulley on the Scotts tractor. just make sure you have belt keepers in place because the groove isn't deep and when you give the belt slack, it'll want to drop off the pulley. ok thanks just wanted to make sure before i bought it might go bigger than 6in might do a 7in | |
| Subject: Re: LT4000 Craftsman August 13th 2014, 1:29 pm | |
| i was welding up a pulley for the front and i ran out of welding wire and i bought one for the back | |
| Subject: Re: LT4000 Craftsman August 14th 2014, 1:22 pm | |
| it looks really good so far. FYI our plans on our project might have just changed. | |
Age : 34 Join date : 2013-11-02 Points : 7163 Posts : 2910 Location : New Jersey USA
| Subject: Re: LT4000 Craftsman August 14th 2014, 11:21 pm | |
| Thing i looking pretty good. Especially widened out a little, should be a little more stable that way. If you don't want to listen to a completely open pipe as far as the exhaust goes, you could weld up a nifty muffler or glass pack type deal. Bigger pipe makes for that low throaty sound. | |
| Subject: Re: LT4000 Craftsman August 15th 2014, 2:20 pm | |
| yeah thats a good idea because i don't want it to loud if i'm going to be driving it a lot | |
Age : 27 Join date : 2013-03-18 Points : 7477 Posts : 3131 Location : raleigh nc
| Subject: Re: LT4000 Craftsman August 15th 2014, 8:57 pm | |
| Looking good! Will you need a tentioner to make the belt not hit the shifting fork rod? My 930 has 4-4 pulleys and the belt clears the rod by 1/8", rubs a small amount due to it whipping back and forth | |
| Subject: Re: LT4000 Craftsman August 15th 2014, 9:55 pm | |
| yeah i put a redneck belt on it and noticed the belt hits so im going to need to add a pulley and i made it so i could steer a little. so i could drive it a few feet it seemed quick and i was only in 3rd gear then the belt started slipping then the steering broke lol so tomorrow i might re weld the steering until i can buy a go kart steering shaft. and i put a new needle and seat in the carb and it seems to have cured the leaking carb problem. and i think i fried the writing when i was trying to start it today lol it started with the key earlier today and now it wont so i have to jump the starter | |
| Subject: Re: LT4000 Craftsman August 16th 2014, 2:31 pm | |
| i got it driving does about 30 mph the steering was just thrown together to drive it so im going to buy go kart parts like a steering shaft with a pitman arm some lock collars and a tie rod. And i think i found out my electric problem a fuse blew out so i need to replace it but i think that was my problem. | |
| Subject: Re: LT4000 Craftsman August 16th 2014, 10:55 pm | |
| those fuses are pain in the butt. one moment it works fine, the next nothing.
