 LT4000 Craftsman
Angchor
Craftsman1998
11 posters
Craftsman1998
LT4000 Craftsman - Page 3 Empty
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 20th 2014, 5:37 pm
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 20th 2014, 11:06 pm
Nice!
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 21st 2014, 9:25 pm
LT4000 Craftsman - Page 3 IMG_20140821_202321_zpsefe5ae9b
Pulled the engine out of it so i could stand the tractor up easier and pulled out the front axle
LT4000 Craftsman - Page 3 IMG_20140821_202336_zpsd4651185
Started patching holes in the frame that i don't need because they can be weak spots and could start cracking the frame when doing 50 mph and i didn't clean up the welds on the bottom yet going to finish it tomorrow
LT4000 Craftsman - Page 3 IMG_20140821_202358_zps3b0fc528
started reinforcing the frame because when i was driving i noticed some frame flex dont want that
LT4000 Craftsman - Page 3 IMG_20140821_202431_zpsc5904536
What the patched holes look like from the top
LT4000 Craftsman - Page 3 IMG_20140821_202440_zps0e5332f7
only some of the holes patched doing more tomorrow
LT4000 Craftsman - Page 3 IMG_20140821_202449_zps40f5d083
notched out the center plate so my shifter would fit
LT4000 Craftsman - Page 3 IMG_20140821_202508_zps32db0dba
LT4000 Craftsman - Page 3 IMG_20140821_202518_zpsec26461d
My front axle its 21 in long so im going to get a 1 1/2 x 3 piece of square tubing to replace it and i'm going to get it 22 in long so it will widen it 1in
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 22nd 2014, 6:58 am
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 26th 2014, 1:18 pm
LT4000 Craftsman - Page 3 IMG_20140826_130422_zps35bb88de
The metal i'm going to use to make my front axle came in the mail. Need to buy some spindles and spindle brackets and need to drill a hole in the middle of this axle for the bolt
LT4000 Craftsman - Page 3 IMG_20140826_130448_zps3d867aeb
LT4000 Craftsman - Page 3 IMG_20140826_130436_zps5b5ad82a
Angchor
Angchor
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 26th 2014, 4:30 pm
Where did you get that and how much did it cost?
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 26th 2014, 6:30 pm
I ordered it From speedy metals Link: https://www.speedymetals.com/default.aspx
The metal cost $20 and it cost $20 to ship so $40 dollars for that front axle
Angchor
Angchor
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 26th 2014, 8:20 pm
Thank you. And wow! that's an expensive piece of metal tubing!
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 26th 2014, 9:59 pm
Cross bracing the frame like that should stiffen things up a lot I would imagine. Pretty beefy looking front axle too. What kind of spindles and stuff are you thinking about using?
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 26th 2014, 10:08 pm
Excellent! id put like 5-8 degrees caster on the spindles when you weld them on. And the steering arms that come with them should be modified for acerman affect, so it will turn wayyyy better.
Take time welding the spindles on! Not a race. Clean up the metal and maybe look at different forms of welding to weld it on nice and solid. It's the difference between you and the pavement.
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 27th 2014, 7:25 am
5-8 degrees positive caster? And i'm buying spindles from bmi karts or some go-kart place online not 100% sure yet
Last edited by Craftsman1998 on August 27th 2014, 10:33 am; edited 1 time in total
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 27th 2014, 8:21 am
5-8 degrees positive camber?
No, he means caster, look HERE and HERE for your front axle advice.
The front axle on my rally has 10* positive caster, ackerman set-up, no toe, and no camber.  It handles really well on and off road. Remember grind the end of your spindle into a point so you can get really good penetration on your welds.
Again.
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 27th 2014, 10:35 am
Oops i meant to put caster lol and how do i measure 10 degrees caster?
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 27th 2014, 11:22 am
I leveled my axle in a bench vise and used an angle finder to get 10*.  Make sure your axle is squared off first (thus the vise).  You should be able to get an angle finder at any major hard ware store. (Northern Tool, TSC, etc...)
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 27th 2014, 12:46 pm
Ok thanks
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 27th 2014, 1:29 pm
LT4000 Craftsman - Page 3 IMG_20140827_113248_zps6ba0ec68
Added some reinforcement to the dashboard because it likes to rattle and move around at high speeds
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeAugust 29th 2014, 7:14 am
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeSeptember 15th 2014, 1:13 pm
LT4000 Craftsman - Page 3 IMG_20140915_110406_zps7d7ac2c5
Welded the transmission brackets to the frame The welds aren't pretty but there strong ill clean them up with the grinder.
And i can weld better than that its just it was a tight area and it was hard to see how much of a puddle i was making to know how fast to move the welding gun.
LT4000 Craftsman - Page 3 IMG_20140915_110425_zps81f9ec03
LT4000 Craftsman - Page 3 IMG_20140915_105536_zpsfbeb0967
LT4000 Craftsman - Page 3 IMG_20140915_110357_zps9a12a8f9
LT4000 Craftsman - Page 3 IMG_20140915_123739_zpsc4cb2809
Welded the corners of the frame too
LT4000 Craftsman - Page 3 IMG_20140915_123757_zps28614c32
LT4000 Craftsman - Page 3 IMG_20140915_123730_zpsfa47530c
Started stripping paint off the frame because i'm going to be welding up stuff for the steering
LT4000 Craftsman - Page 3 IMG_20140915_123801_zps94b648ab
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeSeptember 15th 2014, 2:03 pm
nice.
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeSeptember 15th 2014, 5:47 pm
Nice job, nice welds! - Keep it up cheers
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeSeptember 22nd 2014, 10:23 pm
LT4000 Craftsman - Page 3 IMG_20140918_154947_zps124b56e2
LT4000 Craftsman - Page 3 IMG_20140918_154954_zps0e8f16a3
Started priming spots that i wont be modifying so it doesn't rust
LT4000 Craftsman - Page 3 IMG_20140922_150156_zps5610b259
LT4000 Craftsman - Page 3 IMG_20140922_150206_zpse59d672a
LT4000 Craftsman - Page 3 IMG_20140922_150301_zps32fc0e2b
LT4000 Craftsman - Page 3 IMG_20140922_150310_zpsef8dc066LT4000 Craftsman - Page 3 IMG_20140922_150314_zps9297f94a
LT4000 Craftsman - Page 3 IMG_20140922_1503241_zpse016c67b
I locked my mst 205 thats going to be used for off roading. My plan is 2 have 2 transaxles one locked for off roading then unlocked 206 or 820 for high speeds and each tranny will have different pulley sizes for different speeds and ill swap them out when i need them. the reason i'm not using a locked transmission is because i don't want a weld breaking at high speeds but i want pos for offroading which is why i'm going to use 2 transmissions. And my sisters tractor had a  6 spd spicer so i pulled it out and put this mst in it to test it before i use it in the racing tractor. but it will be awhile before the tractors done. and so far it works very well might lock the spicer for a spare.
LT4000 Craftsman - Page 3 IMG_20140922_1503491_zpsd4d74ed1
LT4000 Craftsman - Page 3 IMG_20140922_150356_zps13528c64
welding in holes that aren't going to be used
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeSeptember 23rd 2014, 3:45 pm
Looking pretty good. Nice lift brackets.
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeSeptember 23rd 2014, 4:23 pm
Cool filling in the holes, makes it look more clean. Flap disk is great for taking down welds to a butt smooth finish (Dont ask)
I bought this but havnt used it yet, but figured id show you. ive used old flywheels as a backing to plug/spot weld, works great.
http://www.harborfreight.com/welding-spoon-66785.html
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeSeptember 24th 2014, 1:38 pm
I bought this but haven't used it yet, but figured id show you. i've used old flywheels as a backing to plug/spot weld, works great.
Butt smooth finish lol and i am going to flap disk it i just need to buy some. And i actually used a piece of copper pipe to fill in the holes i stuck it in a vice and flattened it out works beautifully.
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeOctober 16th 2014, 3:22 pm
My neighbor gave me a kawasaki bike front end so i took the parts i needed of it. and he gave me to bikes one im using for parts and the other im selling.
LT4000 Craftsman - Page 3 IMG_20141016_144425_zpsee1cc8af
So i took all the switches of the kawasaki handlebar because its to big and i put them on the bike handle bar which i'm going to use and if i like it ill keep it on the tractor if i don't like it ill put a steering wheel back on.
LT4000 Craftsman - Page 3 IMG_20141016_144434_zps3cf123df
LT4000 Craftsman - Page 3 IMG_20141016_144440_zpsb5e6dc44
I might use the twist throttle not sure
LT4000 Craftsman - Page 3 IMG_20141016_144452_zps36a0dcfd
Got mirrors a speedometer which i dont think ill be able to use and a tach that i might be able to use.
LT4000 Craftsman - Page 3 IMG_20141016_144504_zpse650b4ad
LT4000 Craftsman - Page 3 IMG_20141016_144507_zps4196c083
LT4000 Craftsman - Page 3 IMG_20141016_144524_zpsd124e834
And heres the tractor sitting in pieces lol
LT4000 Craftsman - Page 3 IMG_20141016_144551_zps1bb86693
and my neighbor gave me a diamond plate tool box this is just the lid of it so ill be doing some cool stuff with this
oh and i forgot to take a picture of them but i got directional lights too
PostSubject: Re: LT4000 Craftsman   LT4000 Craftsman - Page 3 Icon_minitimeOctober 16th 2014, 3:40 pm
Nice man, gotta love free parts.
LT4000 Craftsman
» Craftsman lt4000
» craftsman lt4000
» Ford lgt 165 /craftsman lt4000
» Craftsman Lt4000 mild off-roader
» craftsman lt4000 rear end switch
