 mounting 3/4 shaft centrifugal clutch
dwcopple
mounting 3/4 shaft centrifugal clutch  Empty
PostSubject: mounting 3/4 shaft centrifugal clutch    mounting 3/4 shaft centrifugal clutch  Icon_minitimeJuly 17th 2014, 6:41 pm
I just got a 5hp Briggs for my kart project and am gonna run a #35 3/4 shaft cent clutch but it seems the shaft is pretty long on this engine.  Do I need to shorten it or can the clutch just slide to where I need it?
mounting 3/4 shaft centrifugal clutch  IMG_20140717_175720_952_zpsedivg9gu
mounting 3/4 shaft centrifugal clutch  IMG_20140717_180917_104_zps0odzraos
PostSubject: Re: mounting 3/4 shaft centrifugal clutch    mounting 3/4 shaft centrifugal clutch  Icon_minitimeJuly 17th 2014, 7:09 pm
you probably COULD run it like that, but it seems silly. I would cut it back maybe an inch, but be really careful to make it straight. you also gotta keep in mind- how far back do the threads run?
rarbaugh07
rarbaugh07
PostSubject: Re: mounting 3/4 shaft centrifugal clutch    mounting 3/4 shaft centrifugal clutch  Icon_minitimeJuly 18th 2014, 6:33 am
Use spacers to locate the clutch where you need it.
dwcopple
PostSubject: Re: mounting 3/4 shaft centrifugal clutch    mounting 3/4 shaft centrifugal clutch  Icon_minitimeJuly 18th 2014, 9:29 am
yeah, probably gonna have to try that I guess. GD it, it's never easy is it??? Evil or Very Mad
» Centrifugal Clutch set up
» Centrifugal clutch idea.
» Can you could put a centrifical clutch on a vertical shaft mower
» Would a torque converter or a centrifugal clutch with a 12hp or higher motor be able to turn the tires at 15 mph without bogging down the motor?
» Vertical Shaft Engine on Horizontal Shaft Mower
