| Tecumseh OHV Engines | |
+5B440 Angchor dwcopple Doc Sprocket jack9102 9 posters | |
B440 Member
| Subject: Re: Tecumseh OHV Engines July 5th 2014, 12:09 pm | |
| A junk mower makes a good test stand. Don't need anything but the frame and fuel tank. Maybe some cables, battery etc. if you want to get fancy.
Old picnic table would work too, or any large wooden table. | |
| | | ZSmachines Member
Age : 25 Join date : 2014-08-27 Points : 3989 Posts : 221 Location : PNW
| Subject: Re: Tecumseh OHV Engines October 19th 2014, 10:57 pm | |
| Well I just picked up an old craftsman with this exact same motor. It is doing the exact same thing!!! Feed it some ether and she backfires. That is the end of that. Has GREAT compression. I have done a small bit of research and found that this is a common problem. Different people swear to different things, and I have heard that it could have loose valve seats, or could have carbon buildup on the intake valve or on the intake valve seat. I just can't decide whether to pull the head or not... | |
| | | Frankenvarna Member
Join date : 2014-10-08 Points : 3727 Posts : 27 Location : Southern Illinois
| Subject: Re: Tecumseh OHV Engines October 19th 2014, 11:31 pm | |
| Have you checked the valve adjustment? If not I would start there. | |
| | | ZSmachines Member
| Subject: Re: Tecumseh OHV Engines October 20th 2014, 12:45 am | |
| Yes I have checked everything I can without removing the head. | |
| | | Doc Sprocket Site VIP
| Subject: Re: Tecumseh OHV Engines October 20th 2014, 4:00 pm | |
| - ZSmachines wrote:
- Yes I have checked everything I can without removing the head.
Does that include the timing key? | |
| | | ZSmachines Member
| Subject: Re: Tecumseh OHV Engines October 22nd 2014, 7:20 pm | |
| Do you think it could be that? It is a mower from an auction that I got for 25$ so that i am not destroyed if I can't get the heffer to run, I just have never had a Tecumseh before and would like to run one and learn about them more. Knowledge is power ya know! I personally think that there is just carbon buildup on my intake valve so it can't shut all the way, but the weather has not been cooperating and I have no shop space for it so I have not pulled the head yet. I will check the flywheel key though. Are these motors good even though?
| | | ZSmachines Member
| | | | ZSmachines Member
| Subject: Re: Tecumseh OHV Engines October 24th 2014, 1:51 am | |
| Well hot dang Doc ya did it again!! Pulled my flywheel and yep the flywheel key was. Sheared right in half and the flywheel had rotated about a half an inch on he crankshaft! That would explain the backfiring!!! Now will the flywheel key out of a briggs motor work? I really hate puttin an aluminum key back in it... But a huge thank you ya saved me many hours worth of work there Doc. I might even name this build Mule! Lol | |
| | | ZSmachines Member
| Subject: Re: Tecumseh OHV Engines November 6th 2014, 6:53 pm | |
| So, Long Overdue, But I got a stainless flywheel key, and an adjustable main jet. The teccy purrs like a kitten! | |
| | | chevy8988 Member
Age : 24 Join date : 2014-08-17 Points : 3859 Posts : 93 Location : Fulton, Kentucky
| Subject: Re: Tecumseh OHV Engines March 16th 2015, 1:17 am | |
| Would two Briggs and Stratton carbs fit on my Tecumseh 18hp OHV v-twin dual carb?? | |
| | | Timrsnakess Member
Age : 23 Join date : 2014-01-12 Points : 4003 Posts : 31 Location : Westchester,NY
| Subject: Re: Tecumseh OHV Engines March 26th 2015, 6:48 am | |
| I have a question about my 10hp Tec flathead; how can I get more power with simple mods like swapping carburetors? it has a 12hp OHV carb on it now and i cant seem to get it tuned right | |
