| | mst vs. 920/930 | |
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5372 Posts : 1311 Location : NW USA
![mst vs. 920/930 Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | 1997 Murray Veteran Member
![mst vs. 920/930 Empty](https://2img.net/i/empty.gif) | Subject: Re: mst vs. 920/930 June 27th 2014, 3:55 pm | |
| the mst is not the same as the 920 serise axles. the gears that the mower gang changed are a 15/35 tooth set, and the mst has 11/39 gearset. and the splines are different, so you can't swap in a set from the gears in the shifting cluster. the cases are similer, but not idenical, and the gear that holds the spiders is thicker in the 920 than in the mst. ![mst vs. 920/930 5-6_sp12](https://i.servimg.com/u/f39/18/62/03/97/5-6_sp12.jpg) | |
| ![Go down](https://2img.net/i/empty.gif) | | camomanusa Member
![camomanusa](https://2img.net/u/2812/37/66/46/avatars/1098-34.jpg)
Age : 25 Join date : 2013-09-15 Points : 4505 Posts : 467 Location : Greensburg, PA
![mst vs. 920/930 Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Angchor Member
![Angchor](https://2img.net/u/2812/37/66/46/avatars/1672-45.jpg)
Age : 67 Join date : 2014-04-14 Points : 4345 Posts : 491 Location : Index, Washington
![mst vs. 920/930 Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | LAWN MOWER MUDDER Established Member
![LAWN MOWER MUDDER](https://2img.net/u/2812/37/66/46/avatars/825-65.jpg)
Age : 23 Join date : 2013-04-08 Points : 5135 Posts : 913 Location : Central Pa
![mst vs. 920/930 Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | camomanusa Member
![mst vs. 920/930 Empty](https://2img.net/i/empty.gif) | Subject: Re: mst vs. 920/930 June 27th 2014, 8:00 pm | |
| ok you guys didn't get it at all. there is no spacer at the end of the cluster, and all trannys have room for 6 speeds. so they are now both 6 speeds! they have a 13:1 high gear ratio instead of 15:1, which means more speed! | |
![mst vs. 920/930 Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Doc Sprocket Site VIP
![mst vs. 920/930 Empty](https://2img.net/i/empty.gif) | Subject: Re: mst vs. 920/930 June 27th 2014, 10:03 pm | |
| Mkay, then! Remind me to show you the 700 I built for my racer, and you can tell ME everything I have rearraged in there, wiseass! ![Wink](https://2img.net/i/fa/i/smiles/icon_wink.gif) | |
![mst vs. 920/930 Empty](https://2img.net/i/empty.gif) | Subject: Re: mst vs. 920/930 June 28th 2014, 9:09 am | |
| haha i was hoping for better pics so you could clearly see what was wrong, but whatever. here are the spacers: ![mst vs. 920/930 5-6_sp14](https://i.servimg.com/u/f39/18/62/03/97/5-6_sp14.jpg) so if you want more speeds just get some gears from a different peerless tranny and find the biggest one with splines and the smallest one with slots for shift keys and put them on the end in place of the spacers. | |
![mst vs. 920/930 Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | mst vs. 920/930 | |
| Who is online? | In total there are 138 users online :: 1 Registered, 0 Hidden and 137 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
