 How well would this work?
Craftsman1998
ThatOneTeen
8 posters
ThatOneTeen
How well would this work? - Page 2 Empty
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 2:47 pm
LAWN MOWER MUDDER wrote:
ThatOneTeen wrote:
If my tape is correct My belt is about 10 inchs? I dont know if that is correct or not tho
That isn't right.  You need to make a mark on the belt then you need to measure around the belt until you get back to the mark. Should be around 70''- 95'' (that is the ballpark of sizes for lawn mower belts).
typo, I ment to say 100 not 10
ThatOneTeen
ThatOneTeen
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 2:51 pm
Is 100" out of the ballpark?
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 3:40 pm
What kind of tractor is it??
ThatOneTeen
ThatOneTeen
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 3:41 pm
murray hydro
CornShuck4CE
CornShuck4CE
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 5:49 pm
murray hydro
Yea boy i run a murray with an 820 with a 5 inch on trans and a 6 on motor. With a couple of ideler pulleys onit and its only 95". If your running all stock pulleys it will probably be shorter than that somewhere in da 90-92 i would say.
ThatOneTeen
ThatOneTeen
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 5:51 pm
murray hydro
Im running stock pulleys on the trans and motor. I have 1 idle pulley in the top left corner of the picture i posted. I dont know how I would find a 92'' belt tho, you think you could point me in the right direction
CornShuck4CE
CornShuck4CE
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 5:53 pm
If my resurch is correct a murray hydro like my grass cutter takes an 88" belt.
ThatOneTeen
ThatOneTeen
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 5:56 pm
Where could I find one of them? This murray used to look like this :
How well would this work? - Page 2 93589911
CornShuck4CE
CornShuck4CE
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 6:27 pm
Tracter supply has murray belts. But i recamend getting a husky kevlar belt from there.
ThatOneTeen
ThatOneTeen
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 6:30 pm
I live in a suburb. the closest tractor supply is 44 miles away :l Happen to know what size it is? I can look online
CornShuck4CE
CornShuck4CE
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 6:33 pm
10.50 on ebay
ThatOneTeen
ThatOneTeen
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 6:34 pm
CornShuck4CE wrote:
10.50 on ebay
Link me please?
CornShuck4CE
CornShuck4CE
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 6:41 pm
This is the   The belt on ebay
ThatOneTeen
ThatOneTeen
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 6:46 pm
That is the 88'' correct?
ThatOneTeen
ThatOneTeen
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 6:48 pm
I currently have that belt with me now, I need a smaller size belt. I am thinking a 91 if they make them
CornShuck4CE
CornShuck4CE
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 7:17 pm
That is 88 a stock murray widebodyLT belt for a hydro. And a 91 is longer. If your going to buy a belt. And its not stock. Then you need to find an old belt cut it and run it around your pulleys with clutch pressed in and run the belt around the pulleys not really tight but not real loose and overlad the belt ends an zip tie em together take em off still in a loop and go to an automotive store and ask them to mesure it. And thay have belts just aint gonna last as long. But if you feel confedent on your mesuring. Hold the end of your tape to the mark on the belt  and work your way around back to your mark and thats what you need
ThatOneTeen
ThatOneTeen
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 7:53 pm
Hydros dont have clutchs.
The belt that I have is a 91'' from what I understand from that ebay post. It is a few inchs too big, I am looking to buy a belt that is snug between the engine pulley and the pulley on the trans.
ThatOneTeen
ThatOneTeen
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 8:01 pm
Sorry If I am not being clear enough,
I dont have any of the idle pulleys other then the 1 in the picture. I want to hook the belt to the engine pulley and I want to hook the belt to the trans pulley. Simple as that. What Im looking for is a belt that I can do that with.
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 9:06 pm
I would say cut the belt you have now, route it around the pulleys tight, and then zip tie it and then measure it, but im not sure how you could do that without a correct belt measuring tool. Wheres the original belt? Or are you making the wheelbase shorter?
And p.s. welcome to atltf- ive talked to you on diygk  Wink
ThatOneTeen
ThatOneTeen
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 9:35 pm
I remember you on DIYGK aswell,
The original belt broke about a year ago and this this has sat and I got it about a month ago, The friend that I got it from has the broken belt, I guess it wont hurt to ask him if I can use it for testing purposes. I am not making the wheel base shorter, It used to have idle pulleys that would take off a few inchs of the belt but I lost them in the breakdown of the tractor.
CornShuck4CE
CornShuck4CE
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 9:37 pm
Woah wait a minut. Im a murray fan really like em. My offroader is a murray widebodyLT an my grass cutter the same cept its a hydro and they do have clutches.
ThatOneTeen
ThatOneTeen
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 9:39 pm
Mine has a brake pedal and a pedal that engages the hydro, Is yours an automatic or manual hydro?
ThatOneTeen
ThatOneTeen
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 9:45 pm
Im not even sure if they have manual hydros lol just sounded like something that existed.
I am out in the garage right now on my little laptop and I thought about something, Could I just cut the frame and extend it a few inchs? it would be alot cheaper than buying a new belt since I already have the angle iron and such.
CornShuck4CE
CornShuck4CE
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 9:46 pm
 scratch Manual or auto hydro. I think you need to study up a lil bubba. The brake pedel operates the break and the clutch. And a pedel on the oposite side runs the hydro. The clutch arm part of the mower has been removed if it dont have one the plate on top of the frame in front of the trans is where its suppose to be. Under the plate.
ThatOneTeen
ThatOneTeen
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 9:48 pm
yeah im talking out of my imagination. Ive got the plate its on the ground right now. I just lost the 2 pulleys that would go on that plate. I looked online and it doesnt look like I can buy a whole new plate eather
CornShuck4CE
CornShuck4CE
PostSubject: Re: How well would this work?   How well would this work? - Page 2 Icon_minitimeJune 20th 2014, 9:49 pm
Im sorry bubba your funny. What you gonna do when that belt wares out and you need another one. An cant find one the same lingth. Cut it and do it again.?
» clutch doesnt work and pulleys wont work
» Will this work?
» !!! BODY WORK !!!
» How would this work?
» Will it work?
