| One quick question | |
boss4457 New Member
| Subject: One quick question May 27th 2014, 11:21 pm | |
| So if I can't change the pulley in the rear end.Should I change the pulley on the motor to a bigger one or smaller for more speed.Thanks | |
| | | | kawasaki220 Established Member
Age : 23 Join date : 2014-01-22 Points : 4568 Posts : 546 Location : north carolina
| Subject: Re: One quick question May 28th 2014, 8:52 am | |
| if you want more power put a smaller pulley but it will make it slower big pulley fast small pulley slow | |
| Subject: Re: One quick question May 28th 2014, 1:57 pm | |
| if u cant get that pulley of u can put bigger tires on the rear and it will go faster | |
| Subject: Re: One quick question May 28th 2014, 3:55 pm | |
| - kawasaki220 wrote:
- if you want more power put a smaller pulley but it will make it slower
big pulley fast small pulley slow youre incorrect. a big to a small will give alot of speed, but a small to a big will give low speed and high torque. you gotta take the ratios into consideration | |
| | | Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4416 Posts : 491 Location : Index, Washington
| Subject: Re: One quick question May 28th 2014, 5:29 pm | |
big pulley fast small pulley slow youre incorrect. a big to a small will give alot of speed, but a small to a big will give low speed and high torque. you gotta take the ratios into consideration I think you both said the same thing. | |
Age : 25 Join date : 2013-04-05 Points : 4959 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: One quick question May 29th 2014, 10:16 am | |
| Have you tried heating the transaxle pulley up to loosen it up? | |
| Subject: Re: One quick question May 30th 2014, 11:14 am | |
| - boss4457 wrote:
- So if I can't change the pulley in the rear end.
Should I change the pulley on the motor to a bigger one or smaller for more speed.Thanks Bigger | |
| Who is online? | In total there are 35 users online :: 1 Registered, 0 Hidden and 34 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
