| The MTD has achieved bass | |
+6Thunderdivine WilliesBuilds redlinemotorsportts Doc Sprocket Doug WellThatsSurprising 10 posters | Author | Message |
WellThatsSurprising Member
Age : 27 Join date : 2012-04-30 Points : 5004 Posts : 407 Location : East Bethel, MN
| | | | Doug Site Owner
| | | | Doc Sprocket Site VIP
| Subject: Re: The MTD has achieved bass May 17th 2014, 9:16 pm | |
| Oh... My... GAWD! Bahahahahahahaaaaaa!!!!!! - WellThatsSurprising wrote:
Then to lower the front I just flipped the axle and re-welded the spindles. I understand that this is a horrible way to do it but since this thing will never go above 10MPH it'll be fine.
Are you kidding? That's PERFECT for a lowered honda parody build! Face it... The general populace has NO idea what they're doing with these things, such as cutting the coils to lower the car without any regard to the horrible geometry it creates. Don't change a thing! | |
| Subject: Re: The MTD has achieved bass May 17th 2014, 9:40 pm | |
| - Doc Sprocket wrote:
- Oh... My... GAWD! Bahahahahahahaaaaaa!!!!!!
Are you kidding? That's PERFECT for a lowered honda parody build! Face it... The general populace has NO idea what they're doing with these things, such as cutting the coils to lower the car without any regard to the horrible geometry it creates. Don't change a thing! I even heated up the spindles with a torch and kicked the top of the tire a bit for some hella sick negative camber, yo. | |
| Subject: Re: The MTD has achieved bass May 17th 2014, 9:59 pm | |
- Defiantly needs stance. Like 45degree tire angles. I love this thing.
When I throw a straight axle on I might put U-joints on the ends and weld up some pillow blocks so I can stance the rear too. | |
| | | Doug Site Owner
| Subject: Re: The MTD has achieved bass May 18th 2014, 12:02 am | |
| Dont forget to stretch the tires on the rims and add front fenders that the tire will rub on every turn or bump. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: The MTD has achieved bass May 18th 2014, 12:06 am | |
| - Doug Fackler wrote:
- Dont forget to stretch the tires on the rims and add front fenders that the tire will rub on every turn or bump.
They already do rub against the bumper and frame because the ghetto lowering. | |
| | | WilliesBuilds Member
Age : 29 Join date : 2013-06-19 Points : 4566 Posts : 329 Location : Florida
| | | | Thunderdivine Veteran Member
| | | | crafsmankiller Member
Age : 27 Join date : 2012-10-18 Points : 4890 Posts : 412 Location : livingston texas
| | | | 1997 Murray Veteran Member
| Subject: Re: The MTD has achieved bass June 19th 2014, 11:29 pm | |
| The original seat wasn't that comfortable and since I had a spare seat I decided to do something about it. Three bolts holding it down to the stock seat mounting plate. Put the backrest back on only to find that the mounting rails bumped up against the crossover when it was down. Moved it over a couple inches and it clears just fine. I'm not really worried about it hitting anything because this thing is just for cruising and laughs. And tah-dah! One comfy MTD with the battery box still easily accessible. I removed the gas tank too in preparation for the switch over to an electric drivetrain. | |
| | | N1ck Member
Age : 24 Join date : 2014-06-08 Points : 3900 Posts : 74 Location : North Central Arkansas
| | | | Sponsored content
