Peerless 930 Bearings?
+6 Nevadablue
my1987toyota
Angchor
10 posters
Author Message Angchor Member
Age : 67Join date : 2014-04-14Points : 4413Posts : 491Location : Index, Washington Subject: Peerless 930 Bearings? April 28th 2014, 10:12 pm Doc, I think it was you that found bearings that would fit the peerless 930, to support the axles. Can you tell me what bearings those are? I was cutting the knobs on my tires today, and noticed that there is a HUGE amount of play in the 'drivers side' axle, on mine!
1997 Murray Veteran Member
Age : 26Join date : 2013-11-13Points : 5440Posts : 1311Location : NW USA Subject: Re: Peerless 930 Bearings? April 30th 2014, 2:09 pm here are some of the manufacturor's #: the correct part number from NAPA is 7-04140 spindle bearing. I think DU however stands for 3/4" ID so when ordering specify 6203-3/4. peerless part M83899, JD8535, AM122158, 780119, 37-9500, 37-0200, 106085, 106084, 106085, 106085, and 106084. •ID: 3/4", OD: 1-19/32", Height: 15/32". Ref. #6203-2RS 3/4. Fits Dixon & Toro/Wheel Horse. Replaces AMF/Dynamark/Noma #(s) 12325; Bearing #(s) 6203-2RS 3/4, 6203-RS 3/4; Dixon #(s) 6151, 539125582; Tecumseh #(s) 780119; Toro/Wheel Horse #(s) 10-6084, 10-6085, 37-0200.
Doug Site Owner
Age : 29Join date : 2012-12-24Points : 7776Posts : 3047Location : Lebanon County, PA Subject: Re: Peerless 930 Bearings? April 30th 2014, 2:16 pm In the future, if you want to contact a specific member use the PM function. Or just word your question so it is more generic and not specifically calling on ome specific person as lots of people may have the information. Thanks.
Head Forum Administrator ** Chat Moderator ** Facebook Page Admin ATLTF Facebook Page ** Chatbox ** How To Upload Pictures _X_ FORUM ANNOUNCEMENTS _X_ Have a question? Ask me! Type in "@Doug" in your post! Your ATLTF Staff: Administrators: @Doug, @MightyRaze, @"Doc Sprocket", @Stretch44875 Moderators: @TheRainbowBoxer, @AllisKidD21, @Brianator, @RichieRichOverdrive
Age : 26Join date : 2013-11-13Points : 5440Posts : 1311Location : NW USA Subject: Re: Peerless 930 Bearings? April 30th 2014, 2:26 pm yeah, and doc had the berings from an 800 that he used. i used ones from a 910 in a 205 ( similar to a 930)
Doc Sprocket Site VIP
Age : 51Join date : 2013-04-21Points : 7312Posts : 2914Location : Ontario Canada Subject: Re: Peerless 930 Bearings? April 30th 2014, 5:31 pm Well, yeah- there's that...
I'm still gathering parts numbers- while the axle bearings from an 800 will work, they are a lot more expensive than need be.
my1987toyota New Member
Age : 43Join date : 2014-05-05Points : 3872Posts : 23Location : Clearwater Florida Subject: Re: Peerless 930 Bearings? November 7th 2014, 5:22 pm well I just found this topic because of the same problem with my 930. Since I am locking my axle I will be adding the bearings as well .I just typed in peerless bearing 780119 into the search on ebay and bought them for 11$ for 2 shipping included .
They are aftermarket but who cares.
Nevadablue Established Member
Join date : 2021-07-01Points : 2194Posts : 854Location : Nevada Subject: Re: Peerless 930 Bearings? February 13th 2022, 8:36 pm Necro post…
These are the bearings to go in the outer axle housings, correct? To replace the non-existent bearings from the factory?
That is, they go over the axle and into the recess in the housing here, right?
MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 15653Posts : 10975Location : Oklahoma Fastman Member
Age : 16Join date : 2021-06-15Points : 1444Posts : 178Location : Southern Oklahoma Subject: Re: Peerless 930 Bearings? February 15th 2022, 10:57 am Nevadablue wrote: Necro post… These are the bearings to go in the outer axle housings, correct? To replace the non-existent bearings from the factory? That is, they go over the axle and into the recess in the housing here, right? i have always enjoyed building rear ends but as soon as i looked at this i got a headache... lol
Brianator Mod erator
Age : 45Join date : 2019-07-02Points : 4542Posts : 2385Location : Ontario, Canada Subject: Re: Peerless 930 Bearings? February 15th 2022, 4:08 pm It's interesting they would have a space for them and not utilize it... cheap bastards! Lol
Join date : 2021-07-01Points : 2194Posts : 854Location : Nevada Subject: Re: Peerless 930 Bearings? February 15th 2022, 6:01 pm Same as in the MST axles. I guess that some heavy duty models had the bearing?
Cheap? Make a FNR transaxle and a simple variable pulley and do away with the complicated gear box all together. But… then build a hydrostat. LOL
so, does anyone know for sure if this is the correct bearing?
Where’s that
@RCG guy?
RCG Member
2016 Build-Off Finalist
Join date : 2013-01-05Points : 4835Posts : 438 MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 15653Posts : 10975Location : Oklahoma Subject: Re: Peerless 930 Bearings? February 15th 2022, 6:31 pm 7-04140 spindle bearing is another option I have read more than just here for the 930 axle locations.
Like 2
Join date : 2021-07-01Points : 2194Posts : 854Location : Nevada Sponsored content
Permissions in this forum: You cannot reply to topics in this forum
Who is online? In total there are 21 users online :: 0 Registered, 0 Hidden and 21 Guests None Most users ever online was 412 on January 7th 2023, 7:59 am
