 Bearings for MST transaxle?
Nevadablue
Nevadablue
Bearings for MST transaxle? Empty
PostSubject: Bearings for MST transaxle?   Bearings for MST transaxle? Icon_minitimeAugust 11th 2021, 5:38 pm
Will it be worth it? They aren’t expensive, but of course the axle housing must be opened to install them.
Are they worth it? Sure seems better than steel on aluminum... need advice please.
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: Bearings for MST transaxle?   Bearings for MST transaxle? Icon_minitimeAugust 11th 2021, 6:25 pm
I’d do it. Chance to change the oil, good time to do a visual inspection, clean everything, and most importantly it’s cheap insurance.
Nevadablue likes this post
PostSubject: Re: Bearings for MST transaxle?   Bearings for MST transaxle? Icon_minitimeAugust 11th 2021, 9:59 pm
I had a set in one of my locked rears. I don’t remember the part numbers. But I believe they were the same bearing between the MST series case and the 930 cases? Well worth it in the long run. Give everything a once over. Double check all seals and clean gasket area up good and you shouldn’t have any problems with it after that. Knock on wood lol
PostSubject: Re: Bearings for MST transaxle?   Bearings for MST transaxle? Icon_minitimeAugust 11th 2021, 10:52 pm
There is some info in the faq n them. Link in top blue menu bar.
Bearings for MST transaxle? Sig115PROJECTS:
Bearings for MST transaxle? Sig214Bearings for MST transaxle? Sig314
» Make your own front 4 wheel drive axle?
» Bearings For Peerless MST-205
» Peerless 930 Bearings?
» PICS!!! Axle Bearings for MST-205
