| Running a Transaxle Backwards | |
+3redlinemotorsportts 1997 Murray B440 7 posters | Author | Message |
B440 Member
Join date : 2014-01-22 Points : 4201 Posts : 226 Location : Thompson, CT
| Subject: Running a Transaxle Backwards April 2nd 2014, 10:23 am | |
| If I face an axle backwards, and then spin the pulley counterclockwise (looking down at the pulley), will it still operate normally? | |
| Subject: Re: Running a Transaxle Backwards April 2nd 2014, 10:30 am | |
| I think it will, if that is clockways rotation stock. also, the john deere gx95 runs the transaxle bakwards and it is run by the back side of the belt | |
| Subject: Re: Running a Transaxle Backwards April 2nd 2014, 10:36 am | |
| No the tires will pull backwards. It would all be backwards because the tires are pumping you backwards instead of forward. | |
| | | B440 Member
| | | | TroyBilt Pony Established Member
| Subject: Re: Running a Transaxle Backwards April 2nd 2014, 3:07 pm | |
| - B440 wrote:
- Right, but I've spun the axle 180 degrees, so forward is backwards and vice versa.
Don't know why you would but it should.. | |
| | | rarbaugh07 Member
Age : 36 Join date : 2014-01-22 Points : 4074 Posts : 117 Location : Logan, iowa
| Subject: Re: Running a Transaxle Backwards April 2nd 2014, 3:33 pm | |
| It shouldn't matter I run mine so the input shaft faces forward and reverse rotation to make it shaft drive. If your worried about it just open up the case and see how the gears and case is built. | |
| Subject: Re: Running a Transaxle Backwards April 2nd 2014, 4:29 pm | |
| Is'nt that the normal operation, counterclockwise? if so it'll run backwards. If you change the direction of the input and rotate it, - it will run normal again. | |
Age : 57 Join date : 2013-12-21 Points : 4802 Posts : 744 Location : Salem Illinois
| Subject: Re: Running a Transaxle Backwards April 3rd 2014, 4:13 pm | |
| It should be fine... The only diff internally will be that you will be wearing the BACK side of the teeth.... Since the teeth in these are symmetrical and straight cut, no problem... with helical cut gears, you need to make sure that there are thrust bearings on the opposite side of the gears, as they will be pushing (creeping on their shafts) in the other direction.
Like I said, our straight cut geared tranny's don't care which direction they go. | |
| | | B440 Member
| Subject: Re: Running a Transaxle Backwards April 3rd 2014, 9:39 pm | |
| Ok, that's what I thought. I was looking at the steerable transaxle and it would be smarter to face it backwards if used in a 4x4 project because the case sticks out too far when facing it forwards. | |
| Who is online? | In total there are 45 users online :: 0 Registered, 0 Hidden and 45 Guests
