 How do I put lights on a tractor with no battery?
arild365
SoaresMudder94
7 posters
SoaresMudder94
SoaresMudder94
How do I put lights on a tractor with no battery? Empty
PostSubject: How do I put lights on a tractor with no battery?   How do I put lights on a tractor with no battery? Icon_minitimeJanuary 8th 2011, 11:16 am
Hey there guys. I'm wondering if I can put a light onto my tractor? Its a pull start with no battery or anything, Is it possible to get a light to work off the motor?
PostSubject: Re: How do I put lights on a tractor with no battery?   How do I put lights on a tractor with no battery? Icon_minitimeJanuary 8th 2011, 12:19 pm
The only way would be to use a battery to power the lights- pull starts dont come with a stator under the flywheel unless it came with an electric starter on it- stator charges the battery, most have a separate circut inside ( second wire) to run the lights off the motor, bad thing about those is the lights will brighten and dim as the revs go up and down.
SoaresMudder94
SoaresMudder94
PostSubject: Re: How do I put lights on a tractor with no battery?   How do I put lights on a tractor with no battery? Icon_minitimeJanuary 8th 2011, 10:06 pm
wouldnt the battery die relle quickly? if i ride at night? like if im out romping all day nn come home during the darkess how long would the battery last on a regualr lawn mower battery?
arild365
arild365
PostSubject: Re: How do I put lights on a tractor with no battery?   How do I put lights on a tractor with no battery? Icon_minitimeJanuary 8th 2011, 10:46 pm
well lights dont use very much power. Id think that two regular light and a normal lawn tractor battery, It would last at least 2-4 hours. Just a guess. Dont sue me if im wrong! Razz
SoaresMudder94
SoaresMudder94
PostSubject: Re: How do I put lights on a tractor with no battery?   How do I put lights on a tractor with no battery? Icon_minitimeJanuary 8th 2011, 11:01 pm
I think i will deffently test that out!. ill put err fully charged nn time how long itll last xD
Jordan
Jordan
PostSubject: Re: How do I put lights on a tractor with no battery?   How do I put lights on a tractor with no battery? Icon_minitimeJanuary 9th 2011, 1:38 pm
look for lights that take little power though
i dont have any headlights on mine so i got the great idea of taking the bulbs out of a scrap car we had and i put one on my tractor, as soon as i turned it on it was nice and bright but it instantly killed the motor because it was drawing so much power it took the spark away
Trcustoms
Trcustoms
PostSubject: Re: How do I put lights on a tractor with no battery?   How do I put lights on a tractor with no battery? Icon_minitimeJanuary 9th 2011, 8:23 pm
A lawn tractor batt and two LED head lights would last probably all day or more.
Dustin138
Dustin138
PostSubject: Re: How do I put lights on a tractor with no battery?   How do I put lights on a tractor with no battery? Icon_minitimeJuly 18th 2011, 11:22 am
LED lights are probably the best choice because they use very little power.
PostSubject: Re: How do I put lights on a tractor with no battery?   How do I put lights on a tractor with no battery? Icon_minitimeJuly 23rd 2011, 7:14 am
You could get one of those marine batteries or an optima battery - those things take a beating - just remember to throw it on the charger overnight .
LED's are the best low voltage light - plus are super bright - i hooked up a set of blue LED's on my 85 craftsman - could see that thing quite a distance away- i bota set 5 LED clear lights on clearance at an autoparts store- havent hooked em up yet tho.
MSteele323
PostSubject: Re: How do I put lights on a tractor with no battery?   How do I put lights on a tractor with no battery? Icon_minitimeAugust 1st 2011, 12:29 am
just do NOT install a strobe light! Me and V8mike93 found this out the hard way. Also if you use any fog lamps use a low watt bulb.
https://www.youtube.com/user/msteele323?feature=mhw5
» What do you think of my new lights?
» Craftsman GT 18 Mudding Tractor Head Lights and Basket
» Is it a good idea to switch the old battery for a car battery?
» Battery ah
» 01 murray hydrostatic drive trail/rockcrawler
All-Terrain Lawn Tractor Forum :: Technical Forum :: Electrical Related Issues :: Lights and Switches-
