| shroud question (again, i know, lets beat a dead horse) | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6394 Posts : 1434 Location : east dublin georgia
| Subject: shroud question (again, i know, lets beat a dead horse) March 19th 2014, 10:40 pm | |
| ok guys, here is my idea, i need all yall engine guru's to answer. these motors are air-cooled,naturally aspirated engines, correct?(unless you got one of dem dere fancy watercooled honda's) im thinking of eliminating the shroud off my motor, and installing a fan off a big atv, and have it mounted at the front of the engine bay, if that works for atv's and utv's it should work for my mower right? | |
Age : 28 Join date : 2013-04-10 Points : 5755 Posts : 1408 Location : Galway NY
| Subject: Re: shroud question (again, i know, lets beat a dead horse) March 19th 2014, 10:59 pm | |
| the only way i would ever consider that, is if i installed a temp gauge. even then i wouldnt trust it. yes, my ATV is air cooled, however, the oil is insanely thick, AND, it has its own oil line going to the valve train, to keep that happy, not to mention an oil cooler. if it was me, i would leave it on.. thats just me though, besides, is there really any advantages to it? | |
| | | | Lawren Wimberly Established Member
Age : 57 Join date : 2013-12-21 Points : 4799 Posts : 744 Location : Salem Illinois
| Subject: Re: shroud question (again, i know, lets beat a dead horse) March 20th 2014, 12:24 am | |
| It can be done safely, though you will have to duct the air, even if it's with the hood. Easiest way to do this is to close in the sides so that the air is Forced in the front, and out the back/bottom. A simple tin deflector on the hood, to direct the air downward through the fins will help. To shroud, or not to shroud is a hotly (pardon the pun) debated topic, and only YOU can decide for your engines... Almost all of the "Experts" agree that it's dangerous to mess with the stock cooling system without some serious consideration. | |
| Subject: Re: shroud question (again, i know, lets beat a dead horse) March 20th 2014, 12:46 am | |
| - Lawren Wimberly wrote:
- It can be done safely, though you will have to duct the air, even if it's with the hood. Easiest way to do this is to close in the sides so that the air is Forced in the front, and out the back/bottom. A simple tin deflector on the hood, to direct the air downward through the fins will help. To shroud, or not to shroud is a hotly (pardon the pun) debated topic, and only YOU can decide for your engines... Almost all of the "Experts" agree that it's dangerous to mess with the stock cooling system without some serious consideration.
the cub has hood skirts that totally enclose the engine bay area, so it would be tunneled | |
| Who is online? | In total there are 24 users online :: 0 Registered, 0 Hidden and 24 Guests
