 lets see your grass cutter!
RCG
bbuckler
Craftsman1998
8 posters
lets see your grass cutter! Empty
PostSubject: lets see your grass cutter!   lets see your grass cutter! Icon_minitimeDecember 18th 2013, 11:17 am
lets see your grass cutter! I'll start with the one that I've broke the tranny on four times lets see your grass cutter! Icon_eek
my dad's Ryobi (MTD) lets see your grass cutter! Projec57
17.5 hp (31 ci) briggs lets see your grass cutter! Projec58
Craftsman1998
Craftsman1998
PostSubject: Here is mine   lets see your grass cutter! Icon_minitimeDecember 19th 2013, 6:42 pm
bbuckler
bbuckler
PostSubject: Re: lets see your grass cutter!   lets see your grass cutter! Icon_minitimeDecember 19th 2013, 7:14 pm
I bought new in august.
Craftsman1998
Craftsman1998
PostSubject: Re: lets see your grass cutter!   lets see your grass cutter! Icon_minitimeDecember 19th 2013, 8:24 pm
mine is a lt1000 i bought for 100 bucks
RCG
RCG
2016 Build-Off Finalist
PostSubject: Re: lets see your grass cutter!   lets see your grass cutter! Icon_minitimeDecember 19th 2013, 8:47 pm
http://www.Mudmower.com
PostSubject: Re: lets see your grass cutter!   lets see your grass cutter! Icon_minitimeDecember 30th 2013, 11:25 pm
1968 Sears 6 hp Custom
Features an aluminum mowing deck with 90 degree bevel gear drives... Engine isn't original, some writing in the manual suggests a replacement engine was purchased 1-15-1982 for $263. Excellent fuel mileage, one tank of gas lasts you as long as your gloved hands can stand the vibration from the steering wheel (few hours maybe?).
lets see your grass cutter! Img_3030
Who needs the hastle of electic start, battery and assosiated wiring problems? Pull start only on this puppy. What's truely custom is my custom cardboard shield that keeps cut grass from covering the flywheel screen.
lets see your grass cutter! Img_3031
Tractor with manuals and the help of an older gentleman with some ramps to load it: $100 from a local small engine swap meet. Needed a carb cleaning and some fuel lines, but it works.
lets see your grass cutter! Img_3032
The gear drives are the weak link. You don't want to hit too many rocks or stumps sticking out of the ground. I already had one apart after I caught an unoticed stump and a c-clip came off inside one of the gear boxes. Everything is back together for this seasons mowing. Although I did buy a murry select for $200 as a backup (with electic start).
PostSubject: lets see your grass cutter!   lets see your grass cutter! Icon_minitimeDecember 31st 2013, 10:05 am
nice! where do you find all of these old tractors?
PostSubject: Re: lets see your grass cutter!   lets see your grass cutter! Icon_minitimeDecember 31st 2013, 10:47 am
i have 2 primary mowers. the first is my toro walkbehind that i use commercially. it is powered by a 20 horse Kohler command V-twin. in dire need of a rebuild. it ticks, knocks, burns more oil than my bolens (ol smokey) and dosent like to start. it has a 44 inch deck, with a 5.5 horse briggs intek OHV trac vac motor, which blows all the clippings into a trash barrel on the front of the mower. it dose ok for its age. it is driven hydraulically, there is 2 pumps, 2 flow valves and 2 hydraulic motors, one for each wheel. the hour meter reads over 3366.7 hours. the other is a 2004 huskee supreme powered by a 18.5 briggs ELS. it is junk. it spends more time torn down than working. it has just over 360 hours on it. it never starts, overcharges, wont run, just JUNK... 42 inch mower deck, FNR tranny. those are my 2 grass cutters. heres a vid of the proline.
PostSubject: Re: lets see your grass cutter!   lets see your grass cutter! Icon_minitimeDecember 31st 2013, 12:12 pm
Some stuff I get at a swap meet in Pennsylvania. But I know a guy that has a bunch of mower stuff that he picks up here and there, so I buy stuff from him sometimes.
PostSubject: Re: lets see your grass cutter!   lets see your grass cutter! Icon_minitimeDecember 31st 2013, 3:18 pm
She don't want her picture on the net (grin)
lets see your grass cutter! 2012-03-19_15-58-19_24-1
PostSubject: Re: lets see your grass cutter!   lets see your grass cutter! Icon_minitimeJanuary 5th 2014, 11:26 am
^^lol
lets see your grass cutter! Lawnch10
I took the deck off for some reason I dont remember... I guess thats what happens. maybe I took the deck off to replaces some belts...
I then proceeded to break off the seat bracket shortly after lol.
Craftsman1998
Craftsman1998
PostSubject: Re: lets see your grass cutter!   lets see your grass cutter! Icon_minitimeJanuary 5th 2014, 11:42 am
» Got the grass cutter out!
» grass cutter romp
» "Scrappy" MTD 18/46 14 Speed Grass Cutter
» Homemade Brush cutter
» Lets see those Rigs with meaty mud tires
