| project Mowheeler. | |
goesman Member
Age : 45 Join date : 2012-01-18 Points : 4850 Posts : 119 Location : Salem, Mo.
| Subject: project Mowheeler. March 15th 2014, 8:28 pm | |
| I am calling this one Mowheeler. Its a Murray Wide body crossed with a Honda 250ex. All i am using off the 250ex is the front end and the rear shock. My brother gave me the 4 wheeler frame and it went into surgery today. The wide body was given to me by a guy from church that also runs a local small engine shop. So far i have the front end tacked in place. The hood is real close to fitting but i will need to do some trimming on it to clear the shocks. The rear is getting a swing arm suspension with a axle that i will be machining (soon hopefully). Steering is going to be direct steer with handle bars (maybe). Hopefully i get this done in time for the July 4th parade. | |
Age : 57 Join date : 2013-12-21 Points : 4802 Posts : 744 Location : Salem Illinois
| Subject: Re: project Mowheeler. March 15th 2014, 8:30 pm | |
| Looks good so far... I'm gonna be really interested in what you do with the rear
| | | goesman Member
| Subject: Re: project Mowheeler. March 15th 2014, 8:32 pm | |
| Hopefully what i have in my head will translate to steel. I have built this thing 50 times in my head laying in bed. | |
| Subject: Re: project Mowheeler. March 15th 2014, 8:58 pm | |
| One bad (in a good way!) machine! 700 gearbox for the swingarm? I guess i have to wait and see. | |
| | | mrkadage Member
Age : 35 Join date : 2014-01-12 Points : 4075 Posts : 103 Location : queensland, Australia
| | | | goesman Member
| Subject: Re: project Mowheeler. March 17th 2014, 6:50 pm | |
| I manged to get the hood mounted and some what trimmed up today. I figured out what the width of the rear end will be. Now i have a real good idea what this thing is going to look like. now my garage needs cleaned up. | |
| | | goesman Member
| Subject: Re: project Mowheeler. March 17th 2014, 11:26 pm | |
| I think this is what the swing arm is going to end looking like. | |
| Subject: Re: project Mowheeler. March 18th 2014, 12:12 am | |
| If you use a atv rear axle and bearing supports I don't see a problem, but if you use pillow blocks and a go kart axle, it would have to be thick so it doesn't bend.
Last edited by redlinemotorsportts on March 18th 2014, 11:21 am; edited 2 times in total | |
| | | goesman Member
| Subject: Re: project Mowheeler. March 18th 2014, 8:10 am | |
| Axle is going to be 1.25 inch chromolly solid shaft. should be really strong. I was thinking of using the flanged bearings.
Thanks, Daniel | |
| | | goesman Member
| Subject: Re: project Mowheeler. March 22nd 2014, 1:02 pm | |
| I was able to order a bunch of parts today. Ordered a axle and bearings, bearings for the steering and all the metal i need to build the swing arm. Once all that gets in and i am able to make a trip to my dads machine shop things should go pretty quick on this thing. | |
| | | goesman Member
| Subject: Re: project Mowheeler. March 23rd 2014, 3:46 pm | |
| This is the motor i am going with. its a little 125 out of a 86 honda trx125 four wheeler. It has a 4 speed trans with reverse. Its small and not very heavy and should be great for what i want to do with the mowheeler. | |
| | | Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5149 Posts : 1068 Location : New jersey
| Subject: Re: project Mowheeler. March 23rd 2014, 4:41 pm | |
| I have the same engine there a tough engine and quiet too. | |
| | | goesman Member
| Subject: Re: project Mowheeler. March 23rd 2014, 9:36 pm | |
| And thats the whole reason i am going with that motor. There is a bunch of trails that i am planning on taking this thing that could be an easy 50 miles of riding in one day. i need it to be tough. | |
| Who is online? | In total there are 10 users online :: 1 Registered, 0 Hidden and 9 Guests RichieRichOverdriveMost users ever online was 412 on January 7th 2023, 7:59 am |
