| | 14.5 OHV Crankcase Breather Tube | |
+4willis923 Doc Sprocket Lawren Wimberly gearheadmike 8 posters | Author | Message |
gearheadmike Member
![gearheadmike](https://2img.net/u/2812/37/66/46/avatars/211-4.jpg)
Age : 34 Join date : 2011-11-18 Points : 5132 Posts : 392 Location : west chazy ny
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: 14.5 OHV Crankcase Breather Tube February 10th 2014, 8:12 pm | |
| Ok so have a custom breather setup on my 14.5 and no longer using the plastic breather assy that bolts to end of carb. Which now I have the issue of the crankcase breather hose not having anywhere to hook to. I think the only job of the breather hose is to allow un used gasses/oil out to the carb to be burnt? I thinking of attaching the hose to a homemade "puke tube" (like the 50's & 60's cars had) and let it run out under the frame? Do you think this would work? | |
| ![Go down](https://2img.net/i/empty.gif) | | Lawren Wimberly Established Member
![Lawren Wimberly](https://2img.net/u/2812/37/66/46/avatars/1273-1.jpg)
Age : 57 Join date : 2013-12-21 Points : 4731 Posts : 744 Location : Salem Illinois
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 10th 2014, 8:32 pm | |
| yup mike, but the carb may need adjusting. It was designed to burn that crapola that comes outta the crankcase. I'd simply stick a breather cap on it and let it be
| ![Go down](https://2img.net/i/empty.gif) | | Doc Sprocket Site VIP
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 10th 2014, 9:05 pm | |
| It has been my experience that the mixture does not need adjustment when removing the PCV. The crankcase is subject to pressure changes, from the piston(s) moving up and down. The case MUST be vented to atmospheric pressure, or else seals will blow, and other bad karma. Some treehugger back when, decided that releasing those hydrocarbons straight into the atmosphere, would nearly instantly catapult us into the next ice age, and therefore decided to attempt to burn them by directing them back into the combustion chamber via the carb.
In reality, it doesn't matter WHAT you do with it, as long as it remains vented. Many (including myself) stick a cheap inline automotive fuel filter on the end to keep crap out, and pretty much call it good.
The can comes into play if you have too much oil, are running abnormally high RPM, or tend to operate on extreme angles. Back in earlier times, a crankcase vent hose was simply run stright down, and pointed at the ground. | |
| ![Go down](https://2img.net/i/empty.gif) | | gearheadmike Member
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 10th 2014, 9:30 pm | |
| Ok i thought so i had a snowblower and basicly just had a tube facing the base. Im just gunna run a dump tube so its not getting all over my engine. | |
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | willis923 Veteran Member
![willis923](https://2img.net/u/2812/37/66/46/avatars/835-97.jpg)
Age : 27 Join date : 2013-04-10 Points : 5687 Posts : 1408 Location : Galway NY
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 11th 2014, 9:23 am | |
| - Doc Sprocket wrote:
- The can comes into play if you have too much oil, are running abnormally high RPM, or tend to operate on extreme angles. Back in earlier times, a crankcase vent hose was simply run stright down, and pointed at the ground.
thats how the breather on my tecumseh is, on my bolens. it'll occasionally spit up a little, and at higher RPM's it will blow smoke out (serious blow by on the piston/rings). it just fires down onto the frame and ground | |
| ![Go down](https://2img.net/i/empty.gif) | | B440 Member
![B440](https://2img.net/u/2812/37/66/46/avatars/1432-32.jpg)
Join date : 2014-01-22 Points : 4130 Posts : 226 Location : Thompson, CT
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 11th 2014, 10:10 am | |
| I had excess oil in one of the B&S I was working on; It was quite hilarious after running it for a bit to be enveloped in a massive smoke screen when the PCV puked oil back into the intake. | |
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | the54 Member
![the54](https://2img.net/u/2812/37/66/46/avatars/1357-49.jpg)
Age : 30 Join date : 2014-01-12 Points : 3952 Posts : 51 Location : Ontario Canada
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 15th 2014, 5:36 am | |
| From what I've learned venting the PCV is a cheap little HP gainer they used to use on the old cars and what not that wont hurt the engine in any way. I also have it vented on a few of my tractors.
The other day I was reading a section in a Briggs engine manual and it had said not running the breather to the carb will shorten the lifespan of the engine. I don't know if its some bogus trying to say your better off running it through your cab or if it has been tested and shown to actually lower the lifespan. Usually the book has some interesting tips and stuff but that caught my eye.
Just thought id post it on here to see what people would think about it. | |
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 15th 2014, 6:52 am | |
| - the54 wrote:
- From what I've learned venting the PCV is a cheap little HP gainer they used to use on the old cars and what not that wont hurt the engine in any way. I also have it vented on a few of my tractors.
Horsepower gainer? One would have to go a long way to convince me of that. The crankcase MUST be vented, to relieve the pressure of pistons' downtravel, and relieve the vacuum of uptravel. In a 2-stroke, the engine makes use of these "side-effects". In a 4 stroke, this would cause seals to pop, dipsticks to blow out, etc. - Quote :
- The other day I was reading a section in a Briggs engine manual and it had said not running the breather to the carb will shorten the lifespan of the engine. I don't know if its some bogus trying to say your better off running it through your cab or if it has been tested and shown to actually lower the lifespan.
I call total BS on this one. That's an emissions thing (running it to the carb) and what we have here, is some creative propaganda- designed to scare you into being a good little treehugger. | |
| ![Go down](https://2img.net/i/empty.gif) | | Moose Established Member
![Moose](https://2img.net/u/2812/37/66/46/avatars/1358-86.jpg)
Age : 35 Join date : 2014-01-12 Points : 4877 Posts : 919 Location : Defiance, Ohio
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 15th 2014, 11:40 am | |
| Like everyone else Id just run it out somewhere else just point it at the ground and maybe just maybe if I really like the engine itll get a brass diffuser plug just to keep bugs out and whathaveyou | |
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 15th 2014, 4:29 pm | |
| - the54 wrote:
The other day I was reading a section in a Briggs engine manual and it had said not running the breather to the carb will shorten the lifespan of the engine. thats absolute rubbish. my 74 tecumseh runs like a friggen top other than a bit of smoke. came stock with the breather just dangling off the block pointing at the ground | |
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 15th 2014, 4:37 pm | |
| yup, fartknockin rubbish
It SHOULDA read "removing this breather tube may help prevent carbon buildup on your pistons" | |
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 15th 2014, 6:00 pm | |
| If you pull a slight vacuum on the crankcase, which is what routing the pcv into the intake does, it can help make power, but you'll never notice something like that on these engines. | |
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Lawren Wimberly Established Member
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 15th 2014, 6:49 pm | |
| Doc, he is technically right... the vacuum helps decrease resistance of the piston on the downstroke; But so does allowing the crankcase to VENT. The HP gain is so negligible that I wouldn't even consider it worth the trouble to add a joint on the intake. It was ridiculous Propoganda, perpetrated by the manufacturers to comply with EPA regs. | |
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 15th 2014, 7:44 pm | |
| Well- with THAT I will agree.Any difference WOULD be entirely negligible- to the point that you would need an INCREDIBLY sensiteive test instrument to detect the difference. Anybody claiming to feel it on the butt-dyno is full of hogwash. I've never washed a hog. What's the deal with that? ![Wink](https://2img.net/i/fa/i/smiles/icon_wink.gif) | |
| ![Go down](https://2img.net/i/empty.gif) | | mr.modified Veteran Member
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 15th 2014, 8:40 pm | |
| Here's my crank case vent tube on my simplicity. I route the breathers toward the ground on most motors I mess with. ![14.5 OHV Crankcase Breather Tube Img_3222](https://i.servimg.com/u/f57/18/60/28/82/img_3222.jpg) You can see that the fog of oil from various engine leaks has been cleaned off right below the carb. I still haven't added a fuel shut off valve... | |
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | Subject: Re: 14.5 OHV Crankcase Breather Tube February 17th 2014, 5:30 pm | |
Horsepower gainer? One would have to go a long way to convince me of that. The crankcase MUST be vented, to relieve the pressure of pistons' downtravel, and relieve the vacuum of uptravel. In a 2-stroke, the engine makes use of these "side-effects". In a 4 stroke, this would cause seals to pop, dipsticks to blow out, etc. I see what you mean and I would never plug the vent due to positive crank case pressure. Im just saying that the blow by mixing with fuel doesnt make for a fuller combustion compaired to fresh air with the vent tube disconnected. Lol yea the engine damage thing over time does seem like a tree hugger scam! | |
![14.5 OHV Crankcase Breather Tube Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | 14.5 OHV Crankcase Breather Tube | |
| Who is online? | In total there are 113 users online :: 0 Registered, 0 Hidden and 113 Guests
